How to write a nicely formatted post in Discourse/Forum
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It’s especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
  • Hit the </> button in Discource Post Toolbar.
  • Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your text, …
For a Block of text
  • one line with 3 “back-ticks” (usually the key under Esc),
  • one empty line hitting Enter
  • one more line with 3 “back-ticks”
  • press Up Arrow to go in the empty line and Paste clipboard contents (Ctrl+V)
Example:
Write this
Text from terminal output
to get this
For Inline text
  • one “back-tick” at the beginning and one at the end of a word/phrase
Example:
Write this
Use `sudo pacman -Syu` to update your system
to get this
Use sudo pacman -Syu to update your system
Quoting paragraph (which is often wrongfully used for terminal output) :
  • Start the paragraph with >
Write this
> My smart answer
to get this
My smart answer
  • To combine paragraphs and/or empty lines, use > in empty lines between
> Nice idea
> One more idea
Nice idea
One more idea
Section titles
Start paragraph with 1 up to 5 # followed by a space, like
# Top level
Top level
## 2nd level
2nd level
### 3rd level
3rd level
Separate sections with a horizontal line
  • Create an empty line (with Enter) followed by a line with 3 dashes, or 3 asterisks
or
Create lists
Numbered list
Start the line with a number, a dot and a space
1. First
2. Second
3. Third
  1. First
  2. Second
  3. Third
Bulleted list
Start the line with an asterisk or a dash, followed by a space
* Think
- Draw
* Paint
- Ask
  • Think
  • Draw
  • Paint
  • Ask
Disable special characters preceding it with backslash \
This is \*not bold*
This is *not bold*
End Note: Most of the above can be used with
Select text and click a button at the Post Toolbar’
You can see their keyboard shortcuts hovering the mouse on each button
Now you can’t say I didn’t know how to format my post contents properly :wink:
Cannot switch to X11 after switching to Wayland
I can't install garuda linux
Chrome takes too long to open
[Help] nvidia drivers
Phone not connecting
FAQ and Tutorials Table of Contents
System constantly crashing
None of my desktop effects are working
Steam driver issue
Hey guys do someone knwo how to isntall libreoffice?
Which version should I choose
Ssd Linux drauf HDD programme
Audio not working for about 4 months now
Dragonized post installation error
Mic on a 3.5mm combo headset not working
Stuck at load
Accessibility - screen zooming
CS:GO doesn't open
Garuda linux kde is freezing after boot
Boot USB fail?
Network problem....showing limited connectivity
Installer stuck on logo
Wired Headphone not detecting
Selinux/apparmor
Can't Install Garuda KDE Dragonized Gaming Edition on Ryzen 3800X
Garuda linux got stuck while upgrading garuda-dr490nized
Error to Loading Latte (theme problem)
Usb webcam not working
Nvidia drivers not working at all
Booting Issues v2
Disable power saving mode
Screen tear/flickering and random temporary stutter
Grub Item Not Showing Up
Please tell screen is fluctuating
Hardware error while trying to boot Garuda from USB
Garuda Boot options stuck (Dr460nised KDE)
2 issues after fresh install , please help
Each update is a new configuration
Clementine / Icecast help
No application can access the microphone
No Audio/Sound after Garuda Install
Touch Screen
Timeshift-autosnap E: JSON data must be UTF-8 encoded
Error creating partitions on install
Cannot boot into system
Pen access for the Surface Pro
QTile Edition Fails to Load Config
Unable to play video on any browser
My second screen is "disconnected"
Degraded system font quality
Signature from root@pedrohlc.com is unknown trust
Need help with .jar files
KDE Dragonized gaming won't boot from iso to install
Settings often vanishing upon reboot
Can't load a custom edid.bin
New to i3: How do I change the mouse sensitivity?
Bluetooth connection failed: Protocol not available
Sound on LibreWolf (french name) browser disappears
25min plus boot times
Garuda logo keeps loading
Low framerate desktop experience
Fixing latte top panel
Garuda linux on startup is too buggy
Effects crashing
Kernel Missing due to power fail can only boot using timeshift snapshots now
Gpu drivers problem
Konsole Error with fish
Keyboard crashes in Garuda Installer
Fan Noise and heating
Mounted Partition cant be written
Disk Usage appears too high
Probleme beim Bildschirm teilen
How to install software in Garuda kde multimedia
Unable to boot after installing nvidia proprietary drivers
Pinch to zoom
Apps can move beyond screen resolution
2 monitors full screen mode problem
HDA-NVIDIA-sound-HDMI-laptops-mhwd-nvidia
Add more storage to garuda linux
Errors with pamac update
Weird black bars and buttons while installing kde multimedia
Open java soft
How to set firedragon as default browser
Hdmi for sound not detected
Debtab and Local by flywheel or devkinsta
Whatsapp web keeps on loading in Firedragon
Garuda Settings Manager
Dual Monitor Problem (Beginner)
Multiple monitors' background blurs only on the main screen
Black Screen when Booting from Sleep (KDE Dr4G0nized)
No Booting with Nvidia Drivers
Locale settings defined outside /etc/locale.conf
Garuda uses integrated graphics instead of nvidia graphics
Problem with video driver using the usb live version
Garuda Settings Manager not Opening
Pamac says "No Package Found"
Low memory on Garuda linux along side windows 10
Freeoffice & chrome is lagging
Meta key shortcut not working
Gnome Settings App Removed After Uninstalling Cheese
No sound device
Chaotic-keyring-20210330-1/desc
I am having trouble editing my search engines into brave
Issues with Gnome 40
Displaylink installation fails
Minimal bash-like line editing is supported
Not able to change the color profile
Can't login into Garuda Gnome version
How do i install drivers?
Desktop is empty with no dock or hotbar
[SOLVED] Broadcom BCM57788 Gigabit capped to 100Mb?
Unable to boot into Garuda linux Dragonized bootable usb in order to install it
Error with installation of vmware
I have an critic error
Video's broken
Unable to Install Garuda Linux
How to hide a har drive from another user
How to make auto-freqcpu run on Garuda
Installing npm modules/packages
My mouse is inverted in Unity
Vertical Screen Aspect Ratio
Double close/maximize/minimize buttons in Brave
Nvidia-driver-question
Linux update error
Garuda Network Assistant won't open
Multiple Monitor on garuda dragonized
Nvidia-resolution-problem-
Grey menubars corrupted
Nvidia Optimus laptop with bbswitch: backlight issues
Broke up timeshift somehow and now `garuda-chroot -a` does not detect nvme drives also
Help solving these two issues
Missing menu bar on desktop after boot
Starship::configs::starship_root warnings KDE Dra460ized
Problem with fish konsole
Launching terminal shows starship warnings
No Audio after installing
Kernel Panic - Not Syncing: Fatal Exception In Interrupt when trying to install/boot from USB?
Kernel modules warning
Compositor question
Gradua Linux stuck on booting logo?
Error while booting in Garuda Linux?
Question about shell fish
Unable to connect 5Ghz Wifi
Fish auto-complete is having trouble
Garuda-welcome-git 404
Stuck on "Loading initial ramdisk..."
When i boot, the screen goes all RGB. only red, green, blue
Discord Notification
Second monitor doesn't show buttons
The taskbar is black and console too
Issue with slight sound stutter when hovering icons in the bottom toolbar
Garuda freezing and stuttering all the time
Facing issue while installing Garuda Linux
KDE Multimedia edition is laggy #2
Copy / Paste Issue
Every Package fails
My Apperence theme and login screen themes changes whenever I login Back (after shutting down)
Modify greeting message in fish
Gnome File Manager Hangs when trying to Copy Items
Difficulty in copying into the system files
Audio balance issue
Installing Kernels, Missing Modules, Problems Booting
Optimus Laptop, another GPU thread
Unable to find hdd
Bildschirmsperre in Garuda Linux Ausschalten?!
Need help with program that shows cores in taskbar
Updating Firefox
Unable to update the system
New Install Failed
Stuck on splash screen
Add/Remove Software app not working
Virtualbox Kernel Error
FAILED Faied to start Wait for Netowrk to be Configured
Nvidia stuff is installed, but I have a Radeon card
Add Nvida graphics card to system issue
How to update garuda
BLack Plasma Desktop after update
Missing package and invalid and corrupted file
Everything freezes!
Cant get audio
Screen Sharing Issues
Want to switch, had some issues in USB boot
Waiting for 1 module(s). (xxx second(s))
Loing failed default credential in qtile
Coudn't install Garuda
Can not update Garuda
Avviatore di applicazione
Error : load kernal first
Hybernation setup Garuda 5.12.10-zen1-1-zen (64-bit)
Odd Network Manager Issue
Incomplete system shutdown
New installation issues
Help with clearing the search history in the system
When Minimized, The windows remains in the desktop until the System is restarted
Display Brightness on main monitor always resetting to 0 after hibernation
USB not being detected
How do I get custom resolution in garuda gnome?
Help please master
Wickrme is installed but it can´t start
Unable go into desktop
Persistence usb
Virtual machine is not working
Can't install any thing
Could not update the system
I got maybe 2 issues, 1 isnt an issue maybe
ADB Fastboot and Qualcomm Android USB Drivers Installation Help
Unable to write mp4 video file to Flash drive
The Ultimate guide to install 'Epic Games GTA 5' using Heroic Launcher in any Linux Distro
Terminal and network assistant do not run
Downloading Garuda linux without pen drive
Problem during "Audacity" installation
Codeblocks won't work
Im new to linux in genral. how should i start?
Second monitor messy display
Bluetooth adapter shows missing
System stuttering, heavy lag. Freezes upon restart on load
Update fails: invalid or damaged package
Window borders not showing in "Maximised" mode
Unable to run files under /profile.d
Stop at ramdisc
Network Problem
Bspwm edition long booting time
Bluetooth wireless not connecting
Mirror laptop screen
KDE Desktop Configuration Question
Hello, i am recieving the following error : Maximum file size exceeded
Features & Stability Questions
2 monitors not working
Speed issues with only from my wifi network
Stuck on loading initial ramdisk
Proton doesnt work
Tengo instalado Garuda LXQT
Droidcam USB connections not working for both android and ios
Adding a new keyboard layout
Modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.13.6-zen1-1-zen
Problem on wayfire
Audio issues teclast f7 plus 3
Unable to restore from grub timeshift
Update Failing via Pacman Syu (failed retrieving)
Timeshift crash during setup after snapshot restore
Keyboard shortcut to maximize/minimize current window
[solved] I get black screen after using my GPU
Installation Error (KDE Dr460nized)
Failed to prepare transaction
GTK app UI completely transparent
How do I make data directory to read and write so i can write on it
KDE - random screen capture to wallpaper quirk
Pacman PGP key error
Garuda LXQT Kwin doesn't startup in usb stick
How to add a boot entry to garuda boot menu
Sweet Home 3D - program doesn't start anymore
Wifi networks don't show up
Bluetooth cutting out and reconnecting
Mouse Battery missing in garuda-inxi
Could not install Garuda succesfully with my new RTX 4080
Garbled text from keyboard
Grub-Customizer | GrubCFG error line 218
Latte dock glitch
Grub boot menu gone
Error starting. | Please be more specific
Using Garuda Kwin broken, link has most of the inormation given, the YouTube video has more information
Grub boot menu gone
Multi GPU/APU attempted multi-monitor displays configuration xrandr
Material shell
Material shell
Efistub Not Working
Newly installed software not working
NVIDIA GtX 560ti can't get pass the Dragon loading screen
Pacman & alternatives wants to update to git versions
Error message when opening terminal
Customizing Gnome even with breaking extensions in Gnome4x
Boost.python error in job bootloader
Multiple Monitors Issues
Most of the task switcher animations do not work
USB flash no longer working
Not able to install tar.xz file
Realtek RTL8822BE - wifi unable to connect
Changing resolution to 1080p turns the screen black after update
Can not update due to issue with keyrings
Random restarts
White dotted line when open my laptop after closing its lid in garuda linux
Attempting reloading deprecated 32 bit lib environments in 64 bit OS
Control device does not react
Firewall after restarting PC is turn to off
How Do I Add Bing as Default Search for Firedragon?
GPU Problems Slow motion
Not recognized any android (different phones and tablets)
Problem with installing Garuda
Hdd access denied after coversion from ext4 to btrfs
Second monitor not working via hdmi
Hdd ownwership change
Xen virtualization AUR installation conflicting files
Steam Runtime opening Steam Native
Installation et grub
Help regarding anbox
Nvme not showing in garuda only in ubuntu
Graphic Card and Driver Issues with AMD Radeon R9 200 Series
Unable To Hotplug Game Controller
Automount Drive and Trash conflict
32GB Mem installed showing 16GB
Pipewire breaks after update
Scrolling and speed for 1600 dpi and older with flat curve
Garuda crashing on boot to emergency shell after update
Garuda updater errors out on first update/fresh install
No analog 5.1 sound
Game freezes system in a bad way
GPGME Error no data when attempting to update
VLC volume on tracks & videos resets after repeating erroneously
Garuda dragonized wont update for some reason
I still can't open pamac (pamac-all)
Bluetooth won't enable
RTL8188EU - problem with my USB Wifi adapter
Plasma widgets freeze when desktop is inactive
System unable to boot
Second Monitor Screen Wobbling with nVidia Card
Need help with Checksum
[SOLVED] Intel Wi-Fi 6 AX200 Wifi - suddenly stops working
Dual Boot Problem Garuda & Linux Mint
Low fps on first workspace and when i move to 2nd workspace it becomes normal
Cinnamon installer issues, "GUI dim and flickering"
Installation Problem on Dell Inspiron15 7000
Performance-tweaks and auto-cpufreq-git are in conflict
3d graphics card help
Cannot change the konsole color theme
System update error show ho raha hai
Updating issue
I can't access garuda lxqt
Performance & Updating Issue VMware Workstation
Usb boot with nvidia: error after 'automatic driver instalation via MHWD'
Newbie has issue with dependencies updating
Night color not automatically loading
CMD line upgrade via "sudo update"/"sudo garuda-update" no longer works
Nvidia driver not working after recent update
How can i uninstall Garuda...?
Nvidia drivers dont work
Issue with Ferdi and Vivaldi
Error garuda.db not found while trying to update system
Installer Fails to launch after successful boot of live USB iso
Garuda os installation issue
Annoying sound when start a video in arch based distros
KDE online accounts availability
Youtube isn't responding
Problem with run CS:GO
Problem with the Canon MF3010
Garuda Xfce freezes frequently because my PC has too little memory, cannot be updated
Driver installation NVIDIA GeForce GTS 250, for Dota 2
Latte Dock Issue - RESOLVED
RTL8812BU WLAN NIC Adapter Driver
Garuda Talon doesn't see useless Windows Partition
Update problem. poppler-git and poppler are in conflict
Realtek RTL8821CE - How to improve speed?
Spinning icon around dragon at boot
IQOption not running well
Installing Pacman or Octopi after installing of Garuda
RTL8821CE WiFi - How to fix very slow connection
Intel AX210 - WiFi Not working after installation
No sound from bluetooth speakers but sound from headphones
Screen flickering un LXQT-KWIN live USB | DualCore from 2011
Last update of sddm caused black screen after plymouth
Intel AX210 Wifi - stopped working after update
How do I create code blocks in my posts?
Cannot update (invalid or corrupted package)
Radeon 6800XT Driver Issues Maybe?
RTL8821AU Wifi adapter not showing 5GHz access points
Strange fonts when installing packages (Octopi)
Customise window blur and wriggly animation settings? Restore original fish CLI? More questions
Flatpak steam dont open
League of Legends screen freeze
Update troubleshooting
New-ish Linux User Having Some Issues After new Install
Error mouse and keyboard
Error on installing garuda linux
Cant get right monitor resolution
Change the lock screen layout
