garuda-inxi OS: Garuda Linux
.8Xxd 8X:. Host: ASUSTeK COMPUTER INC. ROG STRIX B550-F GAMING
.8Xx; 8x:. Kernel: 5.17.5-zen1-1-zen
.tt8x .d x88; Uptime: 20 mins
.@8x8; .db: xx@; Packages: 1476 (pacman)
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Shell: bash
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; DE: Plasma 5.24.4
,888S pd! WM: KWin
8X88/ q Terminal: konsole
GBB. CPU: AMD Ryzen 7 5700G with Radeon Graphics (16) @ 3.8GHz
x%88 d888@8@X@X@X88X@@XX@@X@8@X. GPU: AMD ATI Cezanne
dxXd dB8b8b8B8B08bB88b998888b88x. GPU: NVIDIA GeForce GTX 960
dxx8o .@@;. Memory: 3.84GiB / 30.71GiB
sudo paru xrandr
43 aur/gnome-randr-rust 0.1.1.44.g688e0c2-1 [+0 ~0.00]
xrandr for Gnome/wayland, on distros that don't support wlr-randr
42 aur/grobi-rotate-git r137.0619061-1 [+0 ~0.00]
grobi automates applying xrandr profiles when outputs change. This version supports rotation specifiers
41 aur/nxrandrd-git 0.99-1 [+0 ~0.00]
Randr daemon for NX
40 aur/spinnrd-git 1.1.0.r43.b2a48cc-1 [+0 ~0.00]
A daemon to turn accelerometer data into xrandr orientations for auto-screen rotation
39 aur/automirror-git 50_20170328.3b88aff-1 [+0 ~0.00]
An xrandr-wrapper that automatically configures the attached monitors in a mirror configuration that is
optimized for the primary display and makes all other outputs scale to that.
38 aur/xrandr-notify 0.2.0-1 [+0 ~0.00]
subscribe to randr xevents
37 aur/displayset-doc 0.2-1 [+0 ~0.00]
A simple display auto-setup script tool using xrandr - doc and sample config
36 aur/displayset-udev-rules 0.2-1 [+0 ~0.00]
A simple display auto-setup script tool using xrandr - udev rules
35 aur/displayset 0.2-1 [+0 ~0.00]
34 aur/libinput-xrandr-autorotate 0.1.1-1 [+0 ~0.00]
Allows to rotate screen and touch input for 2-in-1 laptops
33 aur/xrandr-multihead-bottom-git r2.ee61e56-1 [+0 ~0.00]
Align a bunch of screens to the bottom edge left to right via a xrandr call.
32 aur/xsane-xrandr 1.0-0 [+0 ~0.00]
Utility script to create and manage user defined monitors
31 aur/mplugd-git 0.1-1 [+0 ~0.00] [Orphaned]
Daemon that listens on events (e.g. xrandr or pulseaudio) and executes user-defined actions on certain
events
30 aur/brandr 0.2-2 [+0 ~0.00] [Out-of-date: 2018-12-26]
An interactive xrandr interface using bash
29 aur/gnome-randr 0.0.1-3 [+1 ~0.55]
This tries to reimplement the some of the functionality of 'xrandr' for the gnome desktop using mutter's
dbus-api. It currently has not been tested with fractional scaling support.
28 aur/xrandr-mgr 2013.7-2 [+1 ~0.00]
Save and restore named xrandr states.
27 aur/auto-display-manager-cr-git v.0.1.3.cr.r0.c1685b4-1 [+1 ~0.00]
A Crystal program for managing multiple screens (displays) via XRandR.
26 aur/auto-xrandr 1.0-1 [+1 ~0.00]
Automatically configure xrandr when a display is connected or disconnected
25 aur/grobi-git r123.fd80d7f-1 [+1 ~0.00]
24 aur/xrandr-watch-git r23.56fc8c7-3 [+2 ~0.00]
xrandr event watcher
23 aur/mmutils-git 1.1.1.r4.g4beedf9-1 [+2 ~0.00]
A set of utilities for querying xrandr monitor information
22 aur/xrasengan 1.0.0-5 [+2 ~0.05]
An xrandr wrapper to make your multi-monitor setup easier
21 aur/libxrandr-git 1.5.0-1 [+2 ~0.00] [Out-of-date: 2021-08-29]
X11 RandR extension library. Git version.
20 aur/screenchange-git v8-1 [+2 ~0.00]
simplify access to xrandr and be able to quickly expand your desktop
19 aur/xlayoutdisplay 1.3.0-1 [+3 ~0.03]
Detects and arranges linux display outputs, using XRandR for detection and xrandr for arrangement.
18 aur/xpointerbarrier-git r19.f4b2be1-1 [+3 ~0.00]
This program creates four pointer barriers around each XRandR screen, thus effectively jailing your mouse
pointer to one physical screen.
17 aur/display-visor 0.4-1 [+3 ~0.06]
An xrandr wrapper daemon for automatically configuring displays upon system events.
16 aur/xprofile 1.2.0-3 [+4 ~0.00] [Orphaned]
A tool to manage and automatically apply xrandr configurations.
15 aur/mpv-plugin-xrandr r21.af6c335-1 [+5 ~0.00]
Makes mpv automatically invoke the xrandr tool to set the best suitable parameters for the display output
14 aur/fakexrandr-git r68.bb5ee75-2 [+5 ~0.00]
Fake XRandR configurations for multi-head setups with crappy video drivers, like fakexinerama but with
xrandr
13 aur/xorg-xrandr-git 1.5.0-1 [+6 ~0.00]
Primitive command line interface to RandR extension. Git version.
12 aur/zrandr 0.3.2-1 [+7 ~0.00]
A simple Qt5 front end for xrandr
11 aur/drandr 1-3 [+7 ~0.00]
a dmenu based XRandR frontend
10 aur/xrandr-invert-colors 0.02-1 [+11 ~0.33]
Simple utility that inverts colors on all screens, using XrandR
9 aur/arandr-git 20130304-3 [+25 ~0.00] [Out-of-date: 2022-02-14] [Orphaned]
Provide a simple visual front end for XRandR 1.2.
8 aur/autorandr-git 1.3.r0.gcbb5662-1 [+67 ~0.00]
Auto-detect the connect display hardware and load the appropiate X11 setup using xrandr. Formerly
autodisper. No disper support.
7 multilib/lib32-libxrandr 1.5.2-1 [17.65KiB 54.00KiB] [Installed]
X11 RandR extension library (32-bit)
6 community/lxrandr-gtk3 0.3.2-2 [57.91KiB 231.85KiB] (lxde-gtk3)
Monitor configuration tool (part of LXDE) (GTK+ 3 version)
5 community/lxrandr 0.3.2-2 [57.87KiB 231.82KiB] (lxde)
4 community/autorandr 1.12.1-2 [0B 86.44KiB] [Installed]
Auto-detect connected display hardware and load appropiate X11 setup using xrandr
3 community/arandr 0.1.10-7 [83.85KiB 284.94KiB]
2 extra/xorg-xrandr 1.5.1-2 [36.76KiB 69.44KiB] [Installed] (xorg-apps xorg)
1 extra/libxrandr 1.5.2-3 [27.18KiB 71.13KiB] [Installed]
:: Packages to install (eg: 1 2 3, 1-3): ~~~
~~~ lightsight in ~
λ sudo paru aur/auto-display-manager-cr-git
[sudo] password for lightsight:
no packages match search
lightsight@lightsight in ~ as 🧙 took 6s
[🔴] × garuda-update
core 156.0 KiB 31.1 KiB/s 00:05 [------------------------------------] 100%
extra 1700.2 KiB 337 KiB/s 00:05 [------------------------------------] 100%
community 6.6 MiB 1161 KiB/s 00:06 [------------------------------------] 100%
multilib is up to date
chaotic-aur 1745.8 KiB 222 KiB/s 00:08 [------------------------------------] 100%
--> Refreshing mirrorlists using rate-mirrors, please be patient..
core 156.0 KiB 1279 KiB/s 00:00 [------------------------------------] 100%
extra 1700.2 KiB 4.43 MiB/s 00:00 [------------------------------------] 100%
community 6.6 MiB 3.56 MiB/s 00:02 [------------------------------------] 100%
multilib 175.9 KiB 11.6 KiB/s 00:15 [------------------------------------] 100%
chaotic-aur 1745.8 KiB 1781 KiB/s 00:01 [------------------------------------] 100%
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'core.db' from arch.lucassymons.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
error: failed retrieving file 'extra.db' from arch.lucassymons.net : Operation too slow. Less than 1 bytes/sectransferred the last 10 seconds
error: failed retrieving file 'community.db' from arch.lucassymons.net : Operation too slow. Less than 1 bytes/sec transferred the last 10 seconds
warning: too many errors from arch.lucassymons.net, skipping for the remainder of this transaction
spawn pacman -Su
resolving dependencies...
Packages (2) cifs-utils-6.15-1 snapper-0.10.1-1
Total Download Size: 0.79 MiB
Total Installed Size: 2.89 MiB
Net Upgrade Size: 0.03 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
cifs-utils-6.15-1-x86_64 89.0 KiB 640 KiB/s 00:00 [------------------------------------] 100%
snapper-0.10.1-1-x86_64 715.4 KiB 3.76 MiB/s 00:00 [------------------------------------] 100%
Total (2/2) 804.4 KiB 491 KiB/s 00:02 [------------------------------------] 100%
error: failed retrieving file 'snapper-0.10.1-1-x86_64.pkg.tar.zst' from arch.lucassymons.net : The requested URL returned error: 404
error: failed retrieving file 'cifs-utils-6.15-1-x86_64.pkg.tar.zst' from arch.lucassymons.net : The requestedURL returned error: 404
(2/2) checking keys in keyring [------------------------------------] 100%
(2/2) checking package integrity [------------------------------------] 100%
(2/2) loading package files [------------------------------------] 100%
(2/2) checking for file conflicts [------------------------------------] 100%
(2/2) checking available disk space [------------------------------------] 100%
==> root: 89
(1/2) upgrading cifs-utils [------------------------------------] 100%
(2/2) upgrading snapper [------------------------------------] 100%
(1/8) Reloading system manager configuration...
(2/8) Arming ConditionNeedsUpdate...
(3/8) Reloading system bus configuration...
(4/8) Foreign/AUR package notification
firestorm-bin 6.5.3.65658-1
kipi-plugins 21.12.3-1
libkipi 21.12.3-1
(5/8) Orphaned package notification...
containerd 1.6.3-1
elfutils 0.186-5
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
neard 0.18-1
nm-connection-editor 1.26.0-1
xf86-video-intel 1:2.99.917+916+g31486f40-2
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/pamac.conf.pacnew
/etc/paru.conf.pacnew
Please check and merge
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 90
(8/8) Syncing all file systems...
Checking for plugin updates
Nothing to install / update
System updated! 🐧
SO... despite multiple reboots, i am still not getting all my monitors on at the same time and somehow related yet unrelated to title of post i have also lost all my audio output from anything system-wide "youtube, chat services, audio-interface... i am not finding a system restore point @TNE
Please read the guide
greetings SGS
