Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It’s especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your …
please
and post terminal in- and output from
inxi -Fza
as text!
If you include terminal outputs in your post, please use the proper output format in your post.
Using “~” 3 times above and “~” 3 times below the text block will provide a readable, raw look.
**Even if you personally think it is unnecessary.
Can anyone plz tell me why my garuda linux is not recognizing my phone when i am connecting it via usb cable while the last night it was working perfectly
What else should i provide plz tell me cuz i am still learning but it is strangely not connecting to the phone what else i can do ..
Bro
7 August 2021 12:56
5
Read the statement ABOVE WHAT YOU POSTED. That is what.
SGS
7 August 2021 13:00
6
I am so happy that there are members here who can sum it up perfectly in English.
My answer would probably have been considered rude
because of the translation software I use.
tbg
7 August 2021 14:00
8
Have you rebooted both the phone and computer?
Try a different/shorter USB cable.
have you tried reverting to a previous snapshot? maybe the cable broke? or the usb port isnt working?
