LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_US.UTF-8",
LC_NAME = "en_US.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_PAPER = "en_US.UTF-8",
LC_IDENTIFICATION = "en_US.UTF-8",
LC_TELEPHONE = "en_US.UTF-8",
LC_MEASUREMENT = "en_US.UTF-8",
LC_TIME = "en_150.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4fccdecf-75e6-4e0c-aaef-6a7f77d45a4d rw [email protected]
resume=UUID=2d9fc423-d580-4293-96fb-a4f6d0dc5c43 loglevel=3
nvidia-drm.modeset=1 ibt=off
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII FORMULA v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4201
date: 04/26/2022
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3772 high: 3950 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3675 9: 3599 10: 3800 11: 3762
12: 3600 13: 3800 14: 3538 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800
20: 3800 21: 3800 22: 3950 23: 3812 24: 3800 bogomips: 182408
protection
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Gigabyte
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-2,DP-3 empty: DP-1,HDMI-A-1,Unknown-1
bus-ID: 0c:00.0 chip-ID: 10de:1e07 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5
compositor: kwin_wayland driver: N/A d-rect: 7280x2160 display-ID: 0
Monitor-1: DP-2 pos: right res: 3440x1440 size: N/A modes: N/A
Monitor-2: DP-3 pos: primary,left res: 3840x2160 size: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce RTX 2080
Ti/PCIe/SSE2 direct render: Yes
Device-1: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso bus-ID: 3-2.3:5 v: kernel bus-ID: 05:04.0
chip-ID: 1532:0528 class-ID: 0300 chip-ID: 13f6:8788 class-ID: 0401
Device-2: NVIDIA TU102 High Definition Audio vendor: Gigabyte
bus-ID: 0c:00.1 chip-ID: 10de:10f7 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Razer USA BlackShark V2 Pro type: USB
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Aquantia AQC111 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 1 link-max: lanes: 4 port: N/A bus-ID: 06:00.0 chip-ID: 1d6a:11b1
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-6:3
chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 7.27 TiB used: 763.73 GiB (10.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Patriot model: Burst size: 894.25 GiB
serial: <filter> rev: J1.3 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWE160 size: 5.46 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: FS2A scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB model: General USB Flash Disk
size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
used: 646.98 GiB (72.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-4: /var/log raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.84 GiB size: 896.84 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 1.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 34.5 C mobo: 29.0 C
Fan Speeds (RPM): cpu: 0 fan-1: 0 fan-2: 1555 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 0 fan-7: 1465
Processes: 470 Uptime: 20m wakeups: 1 Memory: 31.25 GiB
used: 8.04 GiB (25.7%) Init: systemd v: 252 default: graphical
pkgs: 1639 libs: 480 tools: gnome-software,octopi,paru pm: flatpak pkgs: 0
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-11-05
Last full system update: 2022-12-12 ↻
Failed units: fancontrol.service systemd-networkd-wait-online.service
sudo dmesg | grep -i bluetooth
[sudo] password for mark:
[ 6.165564] Bluetooth: Core ver 2.22
[ 6.165591] NET: Registered PF_BLUETOOTH protocol family
[ 6.165592] Bluetooth: HCI device and connection manager initialized
[ 6.165597] Bluetooth: HCI socket layer initialized
[ 6.165599] Bluetooth: L2CAP socket layer initialized
[ 6.165601] Bluetooth: SCO socket layer initialized
[ 8.036036] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.036039] Bluetooth: BNEP filters: protocol multicast
[ 8.036041] Bluetooth: BNEP socket layer initialized
[ 8.339850] Bluetooth: hci0: command 0xfc05 tx timeout
[ 8.339853] Bluetooth: hci0: Reading Intel version command failed (-110)
journalctl -b -1 | grep -i bluetooth
Dec 12 12:51:03 mark-systemproductname bluetoothd[998]: Terminating
Dec 12 12:51:03 mark-systemproductname systemd[1]: Stopping Bluetooth service...
Dec 12 12:51:03 mark-systemproductname dbus-daemon[1005]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.66" (uid=1000 pid=412790 comm="/usr/b
in/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=998 comm="/u
sr/lib/bluetooth/bluetoothd")
Dec 12 12:51:03 mark-systemproductname bluetoothd[998]: Stopping SDP server
Dec 12 12:51:03 mark-systemproductname bluetoothd[998]: Exit
Dec 12 12:51:03 mark-systemproductname systemd[1]: bluetooth.service: Deactivated successfully.
Dec 12 12:51:03 mark-systemproductname systemd[1]: Stopped Bluetooth service.
Dec 12 12:51:03 mark-systemproductname audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd
" hostname=? addr=? terminal=? res=success'
Dec 12 12:51:59 mark-systemproductname systemd[1112876]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDire
ctoryMode: 555)
Dec 12 12:51:59 mark-systemproductname systemd[1]: Starting Bluetooth service...
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: Bluetooth daemon 5.66
Dec 12 12:51:59 mark-systemproductname systemd[1]: Started Bluetooth service.
Dec 12 12:51:59 mark-systemproductname audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/system
d" hostname=? addr=? terminal=? res=success'
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: Starting SDP server
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 12 12:51:59 mark-systemproductname dbus-daemon[1005]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.
service' requested by ':1.524' (uid=0 pid=1112876 comm="/usr/lib/bluetooth/bluetoothd")
Dec 12 12:51:59 mark-systemproductname bluetoothd[1112876]: Bluetooth management interface 1.22 initialized
Dec 12 15:09:14 mark-systemproductname systemd[412196]: Started Add Bluetooth Device - Add Bluetooth Device.
Dec 12 15:09:26 mark-systemproductname systemsettings[1732333]: file:///usr/share/kpackage/kcms/kcm_bluetooth/contents/ui/main.qml:97:13: QML InlineMessage: Cannot ancho
r to an item that isn't a parent or sibling.
Dec 12 15:14:25 mark-systemproductname systemd[412196]: Started Add Bluetooth Device - Add Bluetooth Device.
Dec 12 15:15:09 mark-systemproductname systemsettings[1758496]: file:///usr/share/kpackage/kcms/kcm_bluetooth/contents/ui/main.qml:97:13: QML InlineMessage: Cannot ancho
Dec 12 15:16:43 mark-systemproductname dbus-daemon[1005]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service'
requested by ':1.760' (uid=0 pid=1766028 comm="sudo bluetoothhctl")
Dec 12 15:17:06 mark-systemproductname dbus-daemon[1005]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service'
requested by ':1.763' (uid=0 pid=1767589 comm="sudo bluetoothctl")
Dec 12 15:17:06 mark-systemproductname sudo[1767589]: mark : TTY=pts/1 ; PWD=/home/mark ; USER=root ; COMMAND=/usr/bin/bluetoothctl
Dec 12 15:23:06 mark-systemproductname dbus-daemon[1005]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service'
requested by ':1.775' (uid=0 pid=1794520 comm="sudo systemctl start bluetooth")
Dec 12 15:23:16 mark-systemproductname sudo[1794520]: mark : TTY=pts/1 ; PWD=/home/mark ; USER=root ; COMMAND=/usr/bin/systemctl start bluetooth
Dec 12 15:23:30 mark-systemproductname systemd[412196]: Started Add Bluetooth Device - Add Bluetooth Device.
Dec 12 15:23:46 mark-systemproductname systemsettings[1797536]: file:///usr/share/kpackage/kcms/kcm_bluetooth/contents/ui/main.qml:97:13: QML InlineMessage: Cannot ancho
Dec 12 17:59:00 mark-systemproductname systemd[1]: Stopped target Bluetooth Support.
Dec 12 17:59:00 mark-systemproductname bluetoothd[1112876]: Terminating
Dec 12 17:59:00 mark-systemproductname systemd[1]: Stopping Bluetooth service...
Dec 12 17:59:00 mark-systemproductname dbus-daemon[1005]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.66" (uid=1000 pid=412790 comm="/usr/b
in/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.524" (uid=0 pid=1112876 co
Dec 12 17:59:00 mark-systemproductname bluetoothd[1112876]: Stopping SDP server
Dec 12 17:59:00 mark-systemproductname bluetoothd[1112876]: Exit
Dec 12 17:59:00 mark-systemproductname systemd[1]: bluetooth.service: Deactivated successfully.
Dec 12 17:59:00 mark-systemproductname systemd[1]: Stopped Bluetooth service.
Dec 12 17:59:00 mark-systemproductname audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd
rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
sudo lsmod | grep bluetooth
bluetooth 991232 15 btrtl,btmtk,btintel,btbcm,bnep,btusb
ecdh_generic 16384 1 bluetooth
crc16 16384 2 bluetooth,ext4
rfkill 36864 11 iwlmvm,asus_wmi,bluetooth,cfg80211
Please read
greetings SGS
