Hello.
I was thinking about giving Material shell a try. Any help on how to install it?
I don’t think for this question you need this info, but I’ll give it any ways.
Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=65a78a57-0cbd-4e1f-bf84-3a292960e2bb rw rootflags=subvol=@
resume=UUID=c4e96593-c611-4b46-8a27-a511b52358fa loglevel=3
Desktop: GNOME 41.2 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: LENOVO product: 20U9005MUS v: ThinkPad X1 Carbon Gen 8
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20U9005MUS v: SDK0J40697 WIN
serial: UEFI: LENOVO v: N2WET27W (1.17 )
date: 03/29/2021
ID-1: BAT0 charge: 50.3 Wh (100.0%) condition: 50.3/51.0 Wh (98.6%)
volts: 17.2 min: 15.4 model: SMP 5B10W13931 type: Li-poly serial:
status: Full cycles: 18
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial:
Use of uninitialized value $val2 in string eq at /usr/bin/inxi line 6943.
Use of uninitialized value $val2 in split at /usr/bin/inxi line 6948.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6950.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6953.
Use of uninitialized value $val2 in concatenation (.) or string at /usr/bin/inxi line 6954.
charge: 55% (should be ignored) rechargeable: yes status:
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K540/K545
serial: charge: 100% (should be ignored) rechargeable: yes status:
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 799 high: 800 min/max: 400/4900 scaling:
5: 797 6: 800 7: 800 8: 800 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 13d3:56bb class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :1
Screen-1: 0 s-res: 3840x1155 s-dpi: 96 s-size: 1016x306mm (40.0x12.0")
s-diag: 1061mm (41.8")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: DP2 res: 1920x1080 dpi: 139 size: 350x190mm (13.8x7.5")
diag: 398mm (15.7")
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.41 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
IF: enp0s31f6 state: down mac:
bus-ID: 1-10:8 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 953.87 GiB used: 82.11 GiB (8.6%)
model: PC SN730 SDBQNTY-1T00-1001 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: rev: 11170101 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
used: 82.11 GiB (8.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-4: /var/log raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 936.75 GiB size: 936.75 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C pch: 51.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3033
Processes: 281 Uptime: 4h 10m wakeups: 39 Memory: 15.29 GiB
used: 3.16 GiB (20.6%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1197 lib: 409 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.10
Your kind answer will be greatly appreciated.
Please, read
