I tried all USB ports but the USB camera connection in droidcam does not work.
In android, error: No devices detected, reconnect device and try running ‘ADB devices’ in terminal.
In iOS, error: Error loading devices, Make sure usbmuxd service is installed and running.
This issue is very important for me, please help.
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It’s especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your …
please
and post
inxi -Fza
as text!
Even if you personally think it is unnecessary.
filo
31 July 2021 15:58
2
Hi there, welcome!
I think you should provide more info on what you have in Garuda.
Is droidcam correctly installed?
Error messages shown?
Please
ask there.
Did you try?
We can’t fix or support your Hardware or third party software.
Naman
31 July 2021 20:57
4
You can try manually installing and enabling it.
Are sure you followed correct documentation / guide
system
Closed
14 August 2021 20:58
5
