WiFi difficulties
Hi
When I tried to install Garuda KDE Dr460nized off-line manual installation, the installation didn’t recognize local wifi networks. In order to be able to use the wifi, it is needed to connect first to it in a live session, so then there is no issue.
just tried one time
Operating System: Garuda Linux KDE Plasma Version: 6.2.3 KDE Frameworks Version: 6.7.0 Qt Version: 6.8.0 Kernel Version: 6.11.6-zen1-1-zen (64-bit) Graphics Platform: Wayland Processors: 12 × AMD Ryzen 5 5500U with Radeon Graphics 01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Also, the Garuda KDE Dr460nized doesn’t allow adding panels, while the Garuda KDE Dr460nized Gaming Edition allows it.
Thank you very much for the distro.
No shortage of problems with your adapter:
Welcome to the Garuda forum @ksso . :wave:
Hi
I tried again in other laptop and happen the same thing (off-line installation doesn’t allow wifi, but live connected session prior installation allows wifi), this time using iso image writer, first time with ventoy, same results
thank you
02:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
03:00.0 Ethernet controller: Qualcomm Atheros AR8162 Fast Ethernet (rev 10)
KDE Plasma Version: 6.0.4
KDE Frameworks Version: 6.1.0
Qt Version: 6.7.0
Kernel Version: 6.8.7-zen1-2-zen (64-bit)
Processors: 4 × Intel® Core™ i5-3230M CPU @ 2.60GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 4000
The fact that you are having the same problem on two different computers with different WiFi adapters would seem to indicate that this problem is not originating from the specific WiFi chips in use.
We really need you to post proper log outputs from both devices and a full garuda-inxi output from both devices to have any clue of what is happening here.
You should check both computer logs for errors relating to your realtek and atheros adapters, (your WiFi chip manufacturers).
Your descriptions of both issues are so vague that it’s next to impossible to diagnose what your problem is remotely without far more info.
If after installation you must connect to your network in a live session and then your WiFi works normally afterwards, this is not unheard of. I don’t know why this occurs, but I suggest connecting in a live session for this exact reason as sometimes this fixes WiFi connectivity.
Are you dual booting with with Windows?
Have you rebooted your router?
As you have not provided any logs or garuda-inxi information, I can only make general recommendations for you.
Test at least 3 different kernels. Make sure you try at least the linux-lts and linux-mainline kernels. Also be sure to install the headers package for any kernel you install.
Try disabling MAC address randomization in Network Manager. Be sure to reboot both of your computers and your router after disabling MAC address randomization.
Try whitelisting both computers in your router’s configuration utility. This is often referred to as “MAC address association” in most router configuration utilities.
Try disabling IPv6 in your routers configuration utility.
Be sure to reboot both of your computers and your router after making any of these types of configuration changes.
Without you posting at the minimum your full garuda-inxi outputs from both computers I likely won’t be able to provide any further assistance. Fair warning… your thread may be closed if you do not post the required information in a timely manner. Without proper logs and inxi outputs we will simply be spinning our wheels attempting to help you.
Please post the requested information on your next response @ksso. If you are unfamiliar with any of the terms in my requests, please perform an internet search for clarification.
this is from the hp, only garuda installed, the other is dual boot
─λ garuda-inxi
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f83c7c5a-1e63-42f2-a616-1d35dfeba26d rw rootflags=subvol=@
quiet rd.luks.uuid=d41c618f-f321-41b9-baaa-b47e0281472e
resume=/dev/mapper/luks-d41c618f-f321-41b9-baaa-b47e0281472e loglevel=3
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: HP product: HP Laptop 15-ef2xxx v: N/A
Mobo: HP model: 887A v: 59.25 serial: <superuser required>
part-nu: 612B7LA#ABM uuid: <superuser required> UEFI: AMI v: F.34
date: 07/29/2024
ID-1: BAT0 charge: 41.5 Wh (100.0%) condition: 41.5/41.5 Wh (100.0%)
volts: 12.8 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608107
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1368 min/max: 400/4056 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1368 2: 1368 3: 1368
4: 1368 5: 1368 6: 1368 7: 1368 8: 1368 9: 1368 10: 1368 11: 1368 12: 1368
bogomips: 50305
Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Hewlett-Packard
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:164c class-ID: 0300 temp: 51.0 C
Device-2: Luxvisions Innotech HP TrueVision HD Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 30c9:0013 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.11.6-zen1-1-zen) device-ID: 1002:164c
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 0bda:b00e
Local Storage: total: 476.94 GiB used: 401.95 GiB (84.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OSC model: PCIe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: T1103K0L temp: 44.9 C
ID-1: / raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
used: 23.97 GiB (39.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 1.35 GiB size: 1.35 GiB (99.80%)
used: 584 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 390.62 GiB size: 390.62 GiB (100.00%)
used: 377.98 GiB (96.8%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-967d7b8f-0173-4118-b0f2-193bcd518956
ID-4: /var/log raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-5: /var/tmp raw-size: 60.55 GiB size: 60.55 GiB (100.00%)
ID-1: swap-1 type: partition size: 24.41 GiB used: 0 KiB (0.0%)
mapped: luks-d41c618f-f321-41b9-baaa-b47e0281472e
ID-2: swap-2 type: zram size: 11.01 GiB used: 7.69 GiB (69.8%)
System Temperatures: cpu: 71.4 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 12 GiB note: est. available: 11.01 GiB used: 8.42 GiB (76.5%)
Processes: 428 Power: uptime: 5h 57m states: freeze,mem,disk
suspend, test_resume image: 4.39 GiB services: org_kde_powerdevil,
Packages: 2205 pm: pacman pkgs: 2195 libs: 593 tools: octopi,paru
pm: flatpak pkgs: 10 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date:     2024-11-08
Last full system update: 2024-11-08
this is for the toshiba dual
λ garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=81078805-1872-4d7a-bddb-8e6522d273dd rw rootflags=subvol=@
Type: Laptop System: TOSHIBA product: Satellite C45-A v: PSCD2P-014LM2
Mobo: Type2 - Board Vendor Name1 model: Type2 - Board Product Name1
v: Type2 - Board Version serial: <superuser required> part-nu: PSCD2P
uuid: <superuser required> UEFI-[Legacy]: Insyde v: 1.20 date: 09/18/2013
ID-1: BAT1 charge: 248.8 Wh (100.0%) condition: 248.8/48.6 Wh (512.0%)
volts: 23.0 min: 10.8 model: Panasonic PA5109U-1BRS type: Li-ion serial: N/A
status: charging cycles: 39
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2994 high: 2995 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2995 2: 2994 3: 2994
4: 2993 bogomips: 20753
Device-1: Intel 3rd Gen Core processor Graphics vendor: Toshiba driver: i915
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony TOSHIBA Web Camera - HD driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.4:4
chip-ID: 04f2:b3b1 class-ID: 0e02 serial: <filter>
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: LVDS-1 res: 1366x768 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: crocus wayland: drv: crocus x11:
drv: crocus inactive: gbm
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: integrated-gpu name: Intel
HD Graphics 4000 (IVB GT2) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:0166 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Toshiba
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-2: Qualcomm Atheros AR8162 Fast Ethernet vendor: Toshiba
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 03:00.0 chip-ID: 1969:1090 class-ID: 0200
Device-1: Toshiba driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-1.3:5 chip-ID: 0930:0220 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.1
lmp-v: 7 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 727.61 GiB used: 8.28 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD075
size: 698.64 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4M scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: DataTraveler 2.0
size: 28.98 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 48.88 GiB size: 48.88 GiB (100.00%) used: 8.22 GiB (16.8%)
ID-2: /home raw-size: 48.88 GiB size: 48.88 GiB (100.00%)
used: 8.22 GiB (16.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /var/log raw-size: 48.88 GiB size: 48.88 GiB (100.00%)
ID-4: /var/tmp raw-size: 48.88 GiB size: 48.88 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 91.0 C mobo: N/A
Memory: total: 8 GiB available: 7.65 GiB used: 3.2 GiB (41.8%)
Processes: 216 Power: uptime: 4h 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1804 libs: 537 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
advertencia: database file for 'chaotic-aur' does not exist (use '-Sy' to download)
System install date:     2024-11-09
Last full system update: 2024-11-09
for logs is ok, just sent me the commands
changing kernels, configuration routers, disabling things, is difficult for now, sorry
For now, I may use very little the dual for now, because wine still does not recognize some exe programs, thanks.
Thank you for your attention
Both WiFi and BT adapters on both computers are reported as up and working. This would tend to make me suspect a configuration issue with your router may be complicating connecting properly.
The first thing you should do is to try disabling MAC address randomization in Network Manager. Be sure to reboot your computer and your router after disabling MAC address randomization. Start by making changes on only your Toshiba laptop. The Toshiba laptop has the far more reliable Atheros WiFi chip, so it the better choice to begin working on.
Have you rebooted your router yet?
If not, be sure to do that after you “disable MAC address randomization” in Network Manager. A quick search should give you the information on how to do this.
If you have a spare router it might be worth swapping out the one you are currently using as a troubleshooting step.
Hi, is before the installation that is needed to connect the live session to wifi (live session recognizes wifi networks) in order to have a wifi operating after installation
At this time, both have internet.
I think the tests you want to do would have to be done with off-line installation for the problem of wifi networks not being recognized to appear.
Maybe I’ll study a bit how to do it before reinstalling the laptop, I don’t know how to do the randomization and stuff, so maybe I’ll be late, or something like that.
thank you
Well if both the Wifi’s are now working normally, then there’s really no point in further troubleshooting. Hopefully they will continue working for the foreseeable future. Although, it is not uncommon for Realtek WiFi to break fairly regularly on kernel updates. If this happens, then switching to the LTS kernel is usually enough to get things working again.
Best of luck to you, and I hope you enjoy using Garuda for some time to come.
Thank you!
