Kernel: 6.4.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=788ff74a-74a7-4a79-9567-bb9553eed02d rw rootflags=subvol=@
resume=UUID=505adbf2-7006-49ac-a083-612a1d4a9254 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GT_X571GT
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X571GT v: 1.0 serial: <filter>
UEFI: American Megatrends v: X571GT.308 date: 12/17/2020
ID-1: BAT1 charge: 15.3 Wh (94.4%) condition: 16.2/41.9 Wh (38.7%)
volts: 12.3 min: 11.8 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF2
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1183 high: 2600 min/max: 800/4500 base/boost: 1980/8300
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 900 2: 900 3: 2600 4: 900 5: 900 6: 900
7: 2600 8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:56a8
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
Monitor-1: eDP-1 model: LG Display 0x0563 built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
API: ALSA v: k6.4.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.72 status: n/a (root, process) with:
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: kernel modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 13d3:3529
Local Storage: total: 476.94 GiB used: 25.67 GiB (5.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 29.9 C scheme: GPT
SMART: yes health: PASSED on: 112d 11h cycles: 2,000
read-units: 31,121,923 [15.9 TB] written-units: 22,654,526 [11.5 TB]
ID-1: / raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
used: 25.66 GiB (5.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
maj-min: 259:2
ID-4: /var/log raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 459.62 GiB size: 459.62 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.02 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.0 C pch: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 303 Uptime: 5m wakeups: 1 Memory: available: 15.47 GiB
used: 3.29 GiB (21.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1341
libs: 346 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2023-06-15
Last full system update: 2023-07-04
Hello, thanks in advance for help. I recently switched to Garuda Linux from Windows and I really like it so far. However, there are a couple of small issues Windows didnt have, the most severe of which is that the wifi signal strength is significantly weaker overall and as a result wifi no longer reaches my room, even though the signal was completely fine on windows. So far I have installed the rtw88-dkms-git driver and changed my /etc/modprobe.d/rtl8821ce.conf to this:
[connection]
wifi.powersave = 0
options rtw_pci disable_aspm=1
blacklist rtw88_8822ce
I used to have issues with the powersave turning my wifi off, hence the powersave line. It seemed to help.
Once again, thanks for your time and efforts.
