Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=2077d7dd-92d7-452a-abff-0496557f2c1c rw [email protected]
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Laptop System: HP product: HP 255 G7 Notebook PC
Mobo: HP model: 87CE v: 51.25 serial: <superuser required> UEFI: Insyde
v: F.34 date: 12/14/2020
ID-1: BAT1 charge: 28.7 Wh (75.1%) condition: 38.2/40.9 Wh (93.3%)
volts: 11.8 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: AMD Athlon Silver 3050U with Radeon Graphics bits: 64
type: MCP arch: Zen/Zen+ note: check family: 0x17 (23) model-id: 0x18 (24)
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2145 high: 2324 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2324 2: 1967
bogomips: 9182
vendor: Hewlett-Packard driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6.1:3 chip-ID: 04f2:b67f class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0687 built: 2015
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RAVEN2 (LLVM 13.0.1 DRM 3.44 5.17.5-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6.3:4 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 238.47 GiB used: 133.74 GiB (56.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNLH256HAJD-000H1
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 2H0Q scheme: GPT
used: 133.74 GiB (56.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 5.8 GiB used: 838.3 MiB (14.1%)
System Temperatures: cpu: 20.0 C mobo: 10.0 C gpu: amdgpu temp: 53.0 C
Processes: 216 Uptime: 9h 39m wakeups: 1 Memory: 5.8 GiB
used: 2.52 GiB (43.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1645 lib: 401 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-01-20
Last full system update: 2022-05-15
Relevant software: tlp NetworkManager
So i have had Garuda for a couple months now and since the start my laptops wifi keeps disconnecting despite me being right next to the router, i usually fix it by turning wifi off and then on again but like it's starting to be a bit annoying at this point. So is there some fix i can do other than changing the power settings which i've already done and by that i mean making a config file for Network Manager and then writing this wifi.powersave = 2
