Hi,
i reinstalled garuda linux (Dual boot with windows 10) last month (26 of June) with the iso garuda-dr460nized-linux-zen-210225 (i have reinstalled the entire OS because i wanted to increase the space's partition of garuda 50GB -> 90GB).
Connected to wired connection (tethering) i have installed rtl8821ce-dkms-git, the wifi's driver for my wifi card, and I connected to my wifi after system reboot.
Then i tried to upgrade the system with no success. The problem were the outdated keys, so after sudo pacman-key --refresh-keysand cp /etc/skel/.config/starship.toml ~/.config/starship.tomlall works fine.
After a while (i was still connected to wifi) the screen froze, so i shutdown the laptop with the power button and boot into garuda again. As soon as i connect to wifi the screen froze.
This does not happen with wired connection.
I tought the problem was in the wifi driver, so i reinstalled it 3/4 times with the same package.
I hadn't removed it before install it again: I just went into the folder and typed makepkg -Si every time after reboot when i saw that the problem was still there.
So after those 3/4 times i decided to sudo pacman -R rtl8821ce-dkms-git and reinstalled the package again. Same problem.
Then i figured out that wifi was working even without this driver, but connection was very slow. With this driver speed was about 80-100 Mb/s, without it 5-10 Mb/s.
But the screen continue to freeze even with different wifi.
inxi -Fxxxa output:
System: Host: dadezana-garuda Kernel: 5.13.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=02abdc43-e389-464b-81db-821055a40507
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Laptop 15-dw0xxx v: Type1ProductConfigId
Mobo: HP model: 85F0 v: 36.35 serial: <superuser required> UEFI: Insyde v: F.20
date: 11/25/2019
Battery: ID-1: BAT1 charge: 22.2 Wh (80.4%) condition: 27.6/41.9 Wh (65.8%) volts: 13.1 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: 41167 status: Charging
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: C (12) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 800 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 799
6: 800 7: 800 8: 903
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:174e class-ID: 0302
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: modesetting
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno1 state: down mac: 04:0e:3c:57:bb:da
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:c821
IF: wlo1 state: down mac: c0:e4:34:1e:3a:e7
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: b2:f2:cc:26:75:32
Bluetooth: Device-1: Huawei FIG-LX1 type: USB driver: rndis_host v: kernel bus-ID: 1-2:6
chip-ID: 12d1:108a class-ID: 0a00 serial: HBEDU18202008286
Report: bt-service: enabled,stopped note: tool can't run
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 6060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Drives: Local Storage: total: 476.94 GiB used: 19.53 GiB (4.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: PHNH938201YC512A rev: HPS0 temp: 39.9 C scheme: GPT
Partition: ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 19.45 GiB (21.6%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 78.2 MiB (30.6%) fs: vfat
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%) used: 19.45 GiB (21.6%) fs: btrfs
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%) used: 19.45 GiB (21.6%) fs: btrfs
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%) used: 19.45 GiB (21.6%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C mobo: 29.8 C
Info: Processes: 263 Uptime: 46m wakeups: 7 Memory: 7.65 GiB used: 3.74 GiB (48.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1276 lib: 312
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.06
lsmod | grep rtw88 output:
rtw88_8821ce 16384 0
rtw88_8821c 94208 1 rtw88_8821ce
rtw88_pci 28672 1 rtw88_8821ce
rtw88_core 237568 2 rtw88_pci,rtw88_8821c
mac80211 1241088 2 rtw88_pci,rtw88_core
cfg80211 1069056 2 rtw88_core,mac80211
