This is my device conf:-
Kernel: 5.16.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=63bfe055-cc5e-4764-83c0-9d4d25d798e0 rw rootflags=subvol=@
loglevel=3 pci=noaer pcie_aspm=off ipv6.disable=1
Type: Laptop System: HP product: HP Laptop 15g-dr0xxx
Mobo: HP model: 84A7 v: 80.31 serial: <superuser required> UEFI: Insyde
v: F.07 date: 11/21/2018
ID-1: BAT1 charge: 6.9 Wh (30.1%) condition: 22.9/38.8 Wh (59.1%)
volts: 10.6 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3223 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3401 2: 3400 3: 3400
4: 3400 5: 3362 6: 2020 7: 3400 8: 3401 bogomips: 28800
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:174e class-ID: 0302
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0408:5362 class-ID: 0e02
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: BOE Display built: 2015 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168
vendor: Hewlett-Packard driver: rtw_8821ce v: kernel
modules: rtw88_8821ce,8821ce pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
address: <filter>
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.14 TiB used: 307.22 GiB (26.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z44106
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1A03
ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
used: 21.85 GiB (44.7%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 28.5 MiB (29.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-4: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 59.0 C pch: 51.5 C mobo: 27.8 C
Processes: 252 Uptime: 8m wakeups: 1 Memory: 7.68 GiB
used: 3.18 GiB (41.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1381 lib: 353 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-22
Last full system update: 2022-03-25
Snapshots: Timeshift (maybe)
After keeping my pc idle(offline work such as seeing documents etc) for more than 10min, my internet drops and doesn't work(while showing connected to wifi) till I manually reconnect it to the wifi.Also it sometimes reconnects to my wifi inbetween my online sessions.
I have dual-booted with windows 11 and experiencing this issue in all distros,but i do want to stick with garuda and later switch to it
Till now I have switched 5 different kernel linux mainline, linux,linux next-git, linux zen,linux-lts and linux zen
Switched off powersaving mode,ipv6 and mac address randomization
I have tried changing driver but I dont know if it worked(i.e. garuda is using the new drivers I have tried to install or it is using the original drivers).
I also saw some post about my card in garuda as well as arch linux forum, but it did not work.
So pls assist me and thank you in advance ![]()
