Realtek RTL8821CE - How to improve speed?
  Kernel: 5.17.4-256-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=71ddc465-8706-4c2e-ab7c-e66e5b669061 rw rootflags=subvol=@
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GD_X571GD
  Mobo: ASUSTeK model: X571GD v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X571GD.312 date: 09/15/2021
  ID-1: BAT1 charge: 16.5 Wh (61.3%) condition: 26.9/42.3 Wh (63.6%)
    volts: 10.5 min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A
  Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1082 high: 1242 min/max: 800/4000 scaling:
    driver: intel_cpufreq governor: ondemand cores: 1: 1228 2: 896 3: 1242
    4: 1091 5: 1020 6: 1200 7: 1083 8: 900 bogomips: 36832
  Type: l1tf
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
    driver: N/A alternate: nouveau pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1c92 class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 1-7:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x0563 built: 2018
    res: 1920x1080 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
    v: 4.6 Mesa 22.0.1 direct render: Yes
  Sound Server-1: ALSA v: k5.17.4-256-tkg-bmq running: yes
  Sound Server-3: PipeWire v: 0.3.50 running: yes
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
    vendor: ASUSTeK driver: N/A modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-14:5 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
    address: <filter>
    v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 1.14 TiB used: 11.53 GiB (1.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
    rev: 80001C00 temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
    speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
    used: 11.53 GiB (4.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 7.62 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 46.0 C pch: 49.0 C mobo: 27.8 C
  Fan Speeds (RPM): cpu: 0
  Processes: 287 Uptime: 2m wakeups: 4 Memory: 7.62 GiB
  used: 2.02 GiB (26.5%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 Packages: pacman: 1334 lib: 360 Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.15
Garuda (2.6.1-3):
  System install date:     2022-04-23
  Last full system update: 2022-04-24
  Failed units:            NetworkManager-wait-online.service
Internet is downloading in speed 2,2 MB/s and it should be in speed 3,5 MB/s . Thank you and sorry
Please very match admin, improve my 1st post , thank you .
First post formatted.
Give a look how-to, for the future :wink:. Also read:
Internet speed, rather than on the kernel depends on the network card and the relevant driver.
Considering that the former cannot be easily changed, you could give a try to the driver mentioned below (detailed instructions are included)
I think it would be safer to start with the linux kernel for It. I see also users in the forum using it with linux-zen. I don’t know with your current kernel.
Had the same network driver and same network issue.It is more of the problem of the network driver than the kernel.
Just install
http://aur.archlinux.org/packages/rtl8821ce-dkms-git
from your software installer.
Then reboot
If it is still not working then input this command
echo -e "options rtw_pci disable_aspm=1\nblacklist rtw88_8821ce" | sudo tee /etc/modprobe.d/rtl8821ce.conf
which makes a files in etc/modprobe to blacklist default driver and makes kernel to use rtl8821ce driver
reboot again
Thanks , it works and I choosed kernel 5.16.20 hardened .
