ok so my internet is good for windows but in linux isbad as hell what can i do
First follow the template and post your garuda-inxi output as text.
Can you please describe it briefly and post garuda-inxi
what is garuda inxi
Type in your terminal this
And post its output
You must start reading and not just delete it.
i cant copy paste trough diferent platforms
my linux internet is so bad i cant even do anything so ic ant paste it ;-;
So how are you doing conversation with us ?
If you don't feel any necessacity of giving garuda-inxi but still it's important for us to know many things
And one more question
You have written in your profile 'other OS' so do you really use garuda?
I have never noticed any difference in terms of speed (win/garuda).
Without your data from the garuda-inxi, no one here can help you.
ok let me use garuda and try signing in to here
ello its me
Kernel: 5.16.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=e63ed1c6-c492-4e65-8080-2535bd6dfc59 rw [email protected]
resume=UUID=a08e6a87-2d0e-4791-9c4a-bf1d99641ed3 loglevel=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.3 info: latte-dock wm: kwin_x11
Type: Desktop System: LENOVO product: F0EB00DFID v: ideacentre A340-22IWL
serial: <superuser required> Chassis: type: 13 serial: <superuser required>
Mobo: LENOVO model: 370B v: SDK0Q55754 WIN 3273516960883
serial: <superuser required> UEFI: LENOVO v: O4JKT20A date: 11/24/2020
Info: model: Intel Core i3-10110U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3535 high: 3718 min/max: 400/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3552 2: 3283 3: 3718
4: 3590 bogomips: 20799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 174f:2425 class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
s-diag: 582mm (22.9")
Monitor-1: eDP1 mapped: eDP-1 model: Lenovo LEN-A340W-C-A
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 480x260mm (18.9x10.2") diag: 546mm (21.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.12-zen1-1-zen running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:c821
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-10:5 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Local Storage: total: 1.16 TiB used: 13.03 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 32B3T8EA
temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0E scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 51.23 GiB size: 51.23 GiB (100.00%)
used: 13.03 GiB (25.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 350 MiB size: 349.3 MiB (99.80%)
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 51.23 GiB size: 51.23 GiB (100.00%)
ID-4: /var/log raw-size: 51.23 GiB size: 51.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 51.23 GiB size: 51.23 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 7.57 GiB used: 1.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 96.0 C pch: 67.0 C mobo: N/A
Processes: 221 Uptime: 0m wakeups: 0 Memory: 7.57 GiB
used: 1.98 GiB (26.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1682 lib: 508 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-29
Last full system update: 2022-03-29
there its my --garuda-inxi--
Try checking your speed at speedtest.net and if it's what it should be then you may need to change your repository mirrors. If not, then it's probably your equipment or an ISP issue.
another solution?
with teminal?
Please don't post here like in chat, this is a forum.
This is a web address and must be executed in the browser, regardless of whether it is in Windows or Linux.
ok ima do it
Here's the full meal deal on how to correct issues with the RTL8821CE WiFi adapter.
Disable Wifi power saving:
You can disable Network Manager's power saving features by creating /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
with the following command::
sudo touch /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Add the following contents to the newly created conf file with your preferred text editor:
[connection]
wifi.powersave = 0
Alternately, you can run the following command to generate the required conf file automatically:
echo -e "[connection]\nwifi.powersave = 0" | sudo tee /etc/modprobe.d/rtl8821ce.conf
Then restart Network Manager, or reboot.
Install the rtw88-dkms-git
driver from the Chaotic AUR.
If you have already installed any other driver version, then uninstall that driver before proceeding. Once the driver has been uninstalled, then install the rtw88-dkms-git
Chaotic AUR driver with the following command:
sudo pacman -Syu rtw88-dkms-git
Then reboot.
Create /etc/modprobe.d/rtl8821ce.conf
sudo touch /etc/modprobe.d/rtl8821ce.conf
options rtw_pci disable_aspm=1
blacklist rtw88_8821ce
echo -e "options rtw_pci disable_aspm=1\nblacklist rtw88_8821ce" | sudo tee /etc/modprobe.d/rtl8821ce.conf
Then reboot.
Add the pci=noaer
kernel parameter to grub.
First, backup your grub config file:
sudo cp /etc/default/grub /etc/default/grub.bak
Then edit /etc/default/grub
and add pci=noaer
to the end of the following line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 pci=noaer"
After adding the boot parameter and saving your changes, run:
sudo update-grub
Reboot
Alternately, run the following command to automatically add the pci=noaer
boot parameter to /etc/default/grub
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ pci=noaer"/g' -i /etc/default/grub
After adding the boot parameter(s), run:
sudo update-grub
Reboot.
If the change does not improve your issue you can restore the grub file to its original state with:
sudo cp /etc/default/grub.bak /etc/default/grub
After restoring the file, again run:
sudo update-grub
Then reboot again.
It has been over 2 weeks since the OP responded. This thread is deemed abandoned.
Please do not leave threads dangling in the future.
Thread closed.
