[ 0.328963] microcode: CPU0: patch_level=0x0a601201
[ 0.328963] microcode: CPU1: patch_level=0x0a601201
[ 0.328964] microcode: CPU3: patch_level=0x0a601201
[ 0.328964] microcode: CPU2: patch_level=0x0a601201
[ 0.328964] microcode: CPU6: patch_level=0x0a601201
[ 0.328964] microcode: CPU4: patch_level=0x0a601201
[ 0.328965] microcode: CPU5: patch_level=0x0a601201
[ 0.328965] microcode: CPU9: patch_level=0x0a601201
[ 0.328965] microcode: CPU8: patch_level=0x0a601201
[ 0.328966] microcode: CPU10: patch_level=0x0a601201
[ 0.328966] microcode: CPU11: patch_level=0x0a601201
[ 0.328967] microcode: CPU12: patch_level=0x0a601201
[ 0.328968] microcode: CPU13: patch_level=0x0a601201
[ 0.328969] microcode: CPU15: patch_level=0x0a601201
[ 0.328969] microcode: CPU14: patch_level=0x0a601201
[ 0.328970] microcode: CPU17: patch_level=0x0a601201
[ 0.328970] microcode: CPU16: patch_level=0x0a601201
[ 0.328970] microcode: CPU18: patch_level=0x0a601201
[ 0.328971] microcode: CPU20: patch_level=0x0a601201
[ 0.328971] microcode: CPU19: patch_level=0x0a601201
[ 0.328971] microcode: CPU21: patch_level=0x0a601201
[ 0.328972] microcode: CPU22: patch_level=0x0a601201
[ 0.328972] microcode: CPU23: patch_level=0x0a601201
[ 0.328972] microcode: CPU7: patch_level=0x0a601201
[ 0.328995] microcode: Microcode Update Driver: v2.2.
[ 0.329103] resctrl: L3 allocation detected
[ 0.329104] resctrl: MB allocation detected
[ 0.329104] resctrl: L3 monitoring detected
[ 0.329107] IPI shorthand broadcast: enabled
[ 0.329585] sched_clock: Marking stable (328257987, 1262816)->(381988439, -52467636)
[ 0.329903] registered taskstats version 1
[ 0.330102] Loading compiled-in X.509 certificates
[ 0.331192] Loaded X.509 cert 'Build time autogenerated kernel key: e66b98ade2d068b3ec6fcb2b415d62ccf850ce1a'
[ 0.331528] zswap: loaded using pool lz4/z3fold
[ 0.332066] Key type .fscrypt registered
[ 0.332067] Key type fscrypt-provisioning registered
[ 0.332121] integrity: Loading X.509 certificate: UEFI:db
[ 0.332217] integrity: Loaded X.509 cert 'ASUSTeK MotherBoard SW Key Certificate: da83b990422ebc8c441f8d8b039a65a2'
[ 0.332218] integrity: Loading X.509 certificate: UEFI:db
[ 0.332288] integrity: Loaded X.509 cert 'ASUSTeK Notebook SW Key Certificate: b8e581e4df77a5bb4282d5ccfc00c071'
[ 0.332289] integrity: Loading X.509 certificate: UEFI:db
[ 0.332295] integrity: Loaded X.509 cert 'Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4'
[ 0.332296] integrity: Loading X.509 certificate: UEFI:db
[ 0.332302] integrity: Loaded X.509 cert 'Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53'
[ 0.332303] integrity: Loading X.509 certificate: UEFI:db
[ 0.332374] integrity: Loaded X.509 cert 'Canonical Ltd. Master Certificate Authority: ad91990bc22ab1f517048c23b6655a268e345a63'
[ 0.332782] PM: Magic number: 3:24:218
[ 0.332830] acpi device:69: hash matches
[ 0.332836] acpi PNP0C08:02: hash matches
[ 0.332837] acpi device:3c: hash matches
[ 0.332856] memory memory100: hash matches
[ 0.332901] RAS: Correctable Errors collector initialized.
[ 0.786279] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.786654] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.786974] ata1.00: ATA-9: SanDisk SSD PLUS 1000GB, UH5100RL, max UDMA/133
[ 0.786975] ata1.00: 1953529856 sectors, multi 1: LBA48 NCQ (depth 32)
[ 0.787119] ata3.00: supports DRM functions and may not be fully accessible
[ 0.787120] ata3.00: ATA-10: CT1000MX500SSD1, M3CR020, max UDMA/133
[ 0.787147] ata3.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.787869] ata3.00: Features: Trust Dev-Sleep
[ 0.787977] ata3.00: supports DRM functions and may not be fully accessible
[ 0.788423] ata1.00: Features: Dev-Sleep
[ 0.788714] ata3.00: configured for UDMA/133
[ 0.794290] ata1.00: configured for UDMA/133
[ 0.794335] scsi 0:0:0:0: Direct-Access ATA SanDisk SSD PLUS 00RL PQ: 0 ANSI: 5
[ 0.794422] sd 0:0:0:0: [sda] 1953529856 512-byte logical blocks: (1.00 TB/932 GiB)
[ 0.794427] sd 0:0:0:0: [sda] Write Protect is off
[ 0.794429] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.794435] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.794444] sd 0:0:0:0: [sda] Preferred minimum I/O size 512 bytes
[ 0.803268] sda: sda1
[ 0.803291] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.265965] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.266585] ata2.00: ATA-10: WDC WD10EZEX-08WN4A0, 01.01A01, max UDMA/100
[ 1.267671] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.267674] ata2.00: Features: NCQ-prio
[ 1.269093] ata2.00: configured for UDMA/100
[ 1.269189] scsi 1:0:0:0: Direct-Access ATA WDC WD10EZEX-08W 1A01 PQ: 0 ANSI: 5
[ 1.269361] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.269363] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 1.269372] sd 1:0:0:0: [sdb] Write Protect is off
[ 1.269375] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.269387] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.269387] scsi 2:0:0:0: Direct-Access ATA CT1000MX500SSD1 020 PQ: 0 ANSI: 5
[ 1.269404] sd 1:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
[ 1.269542] sd 2:0:0:0: [sdc] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.269543] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[ 1.269547] sd 2:0:0:0: [sdc] Write Protect is off
[ 1.269548] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 1.269554] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.269567] sd 2:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[ 1.276255] sdc: sdc1
[ 1.276425] sd 2:0:0:0: [sdc] supports TCG Opal
[ 1.276425] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 1.292937] sdb: sdb1
[ 1.293014] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.313776] tsc: Refined TSC clocksource calibration: 4691.184 MHz
[ 1.313784] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x439ee417eeb, max_idle_ns: 440795249536ns
[ 1.313818] clocksource: Switched to clocksource tsc
[ 1.729971] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.734337] ata4.00: ATA-9: SanDisk SD8SBBU240G1122, Z3106000, max UDMA/133
[ 1.737007] ata4.00: 468862128 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.745926] ata4.00: Features: Dev-Sleep
[ 1.765339] ata4.00: configured for UDMA/133
[ 1.765437] scsi 3:0:0:0: Direct-Access ATA SanDisk SD8SBBU2 6000 PQ: 0 ANSI: 5
[ 1.765605] sd 3:0:0:0: [sdd] 468862128 512-byte logical blocks: (240 GB/224 GiB)
[ 1.765616] sd 3:0:0:0: [sdd] Write Protect is off
[ 1.765618] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 1.765631] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.765646] sd 3:0:0:0: [sdd] Preferred minimum I/O size 512 bytes
[ 1.772103] sdd: sdd1
[ 1.772171] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 1.772542] Freeing unused decrypted memory: 2036K
[ 1.772681] Freeing unused kernel image (initmem) memory: 3440K
[ 1.772683] Write protecting the kernel read-only data: 32768k
[ 1.772840] Freeing unused kernel image (rodata/data gap) memory: 1920K
[ 1.789892] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.789894] rodata_test: all tests were successful
[ 1.789897] Run /init as init process
[ 1.789898] with arguments:
[ 1.789898] /init
[ 1.789899] with environment:
[ 1.789899] HOME=/
[ 1.789899] TERM=linux
[ 1.789900] BOOT_IMAGE=/boot/vmlinuz-x86_64
[ 1.789900] lang=en_US
[ 1.789900] keytable=us
[ 1.789900] tz=UTC
[ 1.789900] misobasedir=garuda
[ 1.789901] driver=free
[ 1.817985] raid6: skipped pq benchmark and selected avx512x4
[ 1.817987] raid6: using avx512x2 recovery algorithm
[ 1.819314] xor: automatically using best checksumming function avx
[ 1.886659] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[ 1.917272] device-mapper: uevent: version 1.0.3
[ 1.917294] device-mapper: ioctl: 4.47.0-ioctl (2022-07-28) initialised: dm-devel@redhat.com
[ 1.926538] fbcon: Taking over console
[ 1.926568] Console: switching to colour frame buffer device 128x48
[ 1.962114] acpi PNP0C14:03: duplicate WMI GUID 97845ED0-4E6D-11DE-8A39-0800200C9A66 (first instance was onPNP0C14:00)
[ 1.963859] ACPI: video: Video Device [VGA] (multi-head: yes rom: no post: no)
[ 1.963894] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/LNXVIDEO:00/input/input2
[ 2.074506] Console: switching to colour dummy device 80x25
[ 2.074517] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 2.074534] nouveau 0000:01:00.0: NVIDIA GA102 (b72000a1)
[ 2.188749] nouveau 0000:01:00.0: bios: version 94.02.71.40.9b
[ 2.195990] nouveau 0000:01:00.0: bios: M0203E type 0a
[ 2.195992] nouveau 0000:01:00.0: fb: 10240 MiB of unknown memory type
[ 2.230796] nouveau 0000:01:00.0: DRM: VRAM: 10240 MiB
[ 2.230797] nouveau 0000:01:00.0: DRM: GART: 536870912 MiB
[ 2.230798] nouveau 0000:01:00.0: DRM: BIT table 'A' not found
[ 2.230798] nouveau 0000:01:00.0: DRM: BIT table 'L' not found
[ 2.230798] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 2.230799] nouveau 0000:01:00.0: DRM: DCB version 4.1
[ 2.230799] nouveau 0000:01:00.0: DRM: DCB outp 00: 04800f86 04600020
[ 2.230800] nouveau 0000:01:00.0: DRM: DCB outp 01: 04000f82 00020020
[ 2.230800] nouveau 0000:01:00.0: DRM: DCB outp 02: 04011f72 00020010
[ 2.230801] nouveau 0000:01:00.0: DRM: DCB outp 04: 02822f66 04600020
[ 2.230801] nouveau 0000:01:00.0: DRM: DCB outp 05: 02022f62 00020020
[ 2.230802] nouveau 0000:01:00.0: DRM: DCB outp 07: 02033f52 00020010
[ 2.230802] nouveau 0000:01:00.0: DRM: DCB outp 08: 01844f36 04600010
[ 2.230802] nouveau 0000:01:00.0: DRM: DCB outp 09: 01044f32 00020010
[ 2.230803] nouveau 0000:01:00.0: DRM: DCB conn 00: 02000046
[ 2.230803] nouveau 0000:01:00.0: DRM: DCB conn 01: 01000161
[ 2.230803] nouveau 0000:01:00.0: DRM: DCB conn 02: 00020246
[ 2.230804] nouveau 0000:01:00.0: DRM: DCB conn 03: 00010361
[ 2.230804] nouveau 0000:01:00.0: DRM: DCB conn 04: 00001446
[ 2.231263] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 2.238246] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 2.314795] fbcon: nouveaudrmfb (fb0) is primary device
[ 2.421110] Console: switching to colour frame buffer device 160x45
[ 2.498348] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 2.509353] dracut: Starting plymouth daemon
[ 2.589808] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 2.589890] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[ 2.589952] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 2.591309] xhci_hcd 0000:0b:00.4: xHCI Host Controller
[ 2.591315] xhci_hcd 0000:0b:00.4: new USB bus registered, assigned bus number 1
[ 2.591329] xhci_hcd 0000:0b:00.3: xHCI Host Controller
[ 2.591333] xhci_hcd 0000:0b:00.3: new USB bus registered, assigned bus number 2
[ 2.591674] xhci_hcd 0000:0b:00.4: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000410
[ 2.591706] xhci_hcd 0000:0b:00.3: hcc params 0x0120ffc5 hci version 0x120 quirks 0x0000000200000410
[ 2.591760] xhci_hcd 0000:0c:00.0: xHCI Host Controller
[ 2.591780] xhci_hcd 0000:09:00.0: xHCI Host Controller
[ 2.591805] xhci_hcd 0000:0c:00.0: new USB bus registered, assigned bus number 3
[ 2.591813] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 4
[ 2.592075] Intel(R) 2.5G Ethernet Linux Driver
[ 2.592076] Copyright(c) 2018 Intel Corporation.
[ 2.592155] igc 0000:05:00.0: PCIe PTM not supported by PCIe bus/controller
[ 2.592257] ccp 0000:0b:00.2: enabling device (0000 -> 0002)
[ 2.592347] ccp 0000:0b:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[ 2.592349] ccp 0000:0b:00.2: psp: unable to access the device: you might be running a broken BIOS.
[ 2.592380] xhci_hcd 0000:0b:00.4: xHCI Host Controller
[ 2.592383] xhci_hcd 0000:0b:00.4: new USB bus registered, assigned bus number 5
[ 2.592386] xhci_hcd 0000:0b:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.592420] xhci_hcd 0000:0b:00.3: xHCI Host Controller
[ 2.592424] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[ 2.592426] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.592427] usb usb1: Product: xHCI Host Controller
[ 2.592428] usb usb1: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.592428] usb usb1: SerialNumber: 0000:0b:00.4
[ 2.592572] hub 1-0:1.0: USB hub found
[ 2.592578] hub 1-0:1.0: 2 ports detected
[ 2.592894] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.592907] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[ 2.592909] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.592909] usb usb5: Product: xHCI Host Controller
[ 2.592910] usb usb5: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.592910] usb usb5: SerialNumber: 0000:0b:00.4
[ 2.592975] hub 5-0:1.0: USB hub found
[ 2.592980] hub 5-0:1.0: 2 ports detected
[ 2.593087] xhci_hcd 0000:0c:00.0: USB3 root hub has no ports
[ 2.593091] xhci_hcd 0000:0c:00.0: hcc params 0x0110ffc5 hci version 0x120 quirks 0x0000000200000410
[ 2.593305] xhci_hcd 0000:0c:00.0: xHCI Host Controller
[ 2.593335] xhci_hcd 0000:0b:00.3: new USB bus registered, assigned bus number 6
[ 2.593338] xhci_hcd 0000:0c:00.0: new USB bus registered, assigned bus number 7
[ 2.593339] xhci_hcd 0000:0b:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.593341] xhci_hcd 0000:0c:00.0: Host supports USB 3.0 SuperSpeed
[ 2.593363] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[ 2.593365] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.593366] usb usb2: Product: xHCI Host Controller
[ 2.593367] usb usb2: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.593368] usb usb2: SerialNumber: 0000:0b:00.3
[ 2.593412] hub 2-0:1.0: USB hub found
[ 2.593415] hub 2-0:1.0: 2 ports detected
[ 2.593711] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.593722] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[ 2.593723] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.593724] usb usb6: Product: xHCI Host Controller
[ 2.593724] usb usb6: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.593725] usb usb6: SerialNumber: 0000:0b:00.3
[ 2.593760] hub 6-0:1.0: USB hub found
[ 2.593763] hub 6-0:1.0: 2 ports detected
[ 2.594073] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[ 2.594074] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.594075] usb usb3: Product: xHCI Host Controller
[ 2.594075] usb usb3: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.594076] usb usb3: SerialNumber: 0000:0c:00.0
[ 2.594109] hub 3-0:1.0: USB hub found
[ 2.594113] hub 3-0:1.0: 1 port detected
[ 2.594266] usb usb7: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.594279] usb usb7: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[ 2.594279] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.594280] usb usb7: Product: xHCI Host Controller
[ 2.594281] usb usb7: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.594281] usb usb7: SerialNumber: 0000:0c:00.0
[ 2.594350] hub 7-0:1.0: USB hub found
[ 2.594353] hub 7-0:1.0: config failed, hub doesn't have any ports! (err -19)
[ 2.594741] cryptd: max_cpu_qlen set to 1000
[ 2.603371] BTRFS: device label Terraplatt-zwo devid 1 transid 7352 /dev/sdc1 scanned by (udev-worker) (451)
[ 2.611349] BTRFS: device label Zeugs devid 1 transid 538 /dev/sdd1 scanned by (udev-worker) (438)
[ 2.613108] BTRFS: device label Vol V devid 1 transid 586 /dev/sda1 scanned by (udev-worker) (540)
[ 2.616015] nvme nvme0: pci function 0000:04:00.0
[ 2.616028] nvme nvme1: pci function 0000:0a:00.0
[ 2.617890] AVX2 version of gcm_enc/dec engaged.
[ 2.617924] AES CTR mode by8 optimization enabled
[ 2.620857] nvme nvme0: missing or invalid SUBNQN field.
[ 2.620868] nvme nvme0: Shutdown timeout set to 10 seconds
[ 2.622194] nvme nvme0: 8/0/0 default/read/poll queues
[ 2.622786] nvme nvme0: Ignoring bogus Namespace Identifiers
[ 2.623126] nvme nvme1: missing or invalid SUBNQN field.
[ 2.623135] nvme nvme1: Shutdown timeout set to 8 seconds
[ 2.623911] nvme0n1: p1 p2
[ 2.641011] pps pps0: new PPS source ptp0
[ 2.641029] igc 0000:05:00.0 (unnamed net_device) (uninitialized): PHC added
[ 2.644051] nvme nvme1: 24/0/0 default/read/poll queues
[ 2.647307] nvme1n1: p1 p2
[ 2.647771] xhci_hcd 0000:09:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[ 2.648012] xhci_hcd 0000:09:00.0: xHCI Host Controller
[ 2.648014] xhci_hcd 0000:09:00.0: new USB bus registered, assigned bus number 8
[ 2.648016] xhci_hcd 0000:09:00.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 2.648051] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.02
[ 2.648052] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.648053] usb usb4: Product: xHCI Host Controller
[ 2.648053] usb usb4: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.648053] usb usb4: SerialNumber: 0000:09:00.0
[ 2.648107] hub 4-0:1.0: USB hub found
[ 2.648118] hub 4-0:1.0: 12 ports detected
[ 2.649155] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.649161] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.02
[ 2.649162] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.649163] usb usb8: Product: xHCI Host Controller
[ 2.649163] usb usb8: Manufacturer: Linux 6.2.7-zen1-1-zen xhci-hcd
[ 2.649163] usb usb8: SerialNumber: 0000:09:00.0
[ 2.649192] hub 8-0:1.0: USB hub found
[ 2.649202] hub 8-0:1.0: 5 ports detected
[ 2.656482] BTRFS: device fsid 3b163b28-2f10-48a9-b25b-f322ae04d722 devid 1 transid 253 /dev/nvme0n1p2 scanned by (udev-worker) (451)
[ 2.659807] BTRFS: device fsid c39768c7-800a-4b84-9b35-05593086327b devid 1 transid 28 /dev/nvme1n1p2 scanned by (udev-worker) (441)
[ 2.667878] igc 0000:05:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[ 2.667880] igc 0000:05:00.0 eth0: MAC: a0:36:bc:0c:13:3c
[ 2.835764] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.835787] usb 2-2: new full-speed USB device number 2 using xhci_hcd
[ 2.862692] BTRFS: device label Terraplatt devid 1 transid 2683 /dev/sdb1 scanned by (udev-worker) (432)
[ 2.953766] usb 4-2: new full-speed USB device number 2 using xhci_hcd
[ 2.982531] usb 1-1: New USB device found, idVendor=0bda, idProduct=5411, bcdDevice= 1.15
[ 2.982535] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.982535] usb 1-1: Product: 4-Port USB 2.0 Hub
[ 2.982536] usb 1-1: Manufacturer: Generic
[ 2.985331] usb 2-2: New USB device found, idVendor=1038, idProduct=1852, bcdDevice= 1.32
[ 2.985334] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.985335] usb 2-2: Product: SteelSeries Aerox 5 Wireless
[ 2.985336] usb 2-2: Manufacturer: SteelSeries
[ 3.007385] input: SteelSeries SteelSeries Aerox 5 Wireless as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb2/2-2/2-2:1.0/0003:1038:1852.0001/input/input3
[ 3.007431] hid-generic 0003:1038:1852.0001: input,hidraw0: USB HID v1.11 Mouse [SteelSeries SteelSeries Aerox 5 Wireless] on usb-0000:0b:00.3-2/input0
[ 3.012358] input: SteelSeries SteelSeries Aerox 5 Wireless as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb2/2-2/2-2:1.1/0003:1038:1852.0002/input/input4
[ 3.041446] hub 1-1:1.0: USB hub found
[ 3.042666] hub 1-1:1.0: 4 ports detected
[ 3.064157] hid-generic 0003:1038:1852.0002: input,hidraw1: USB HID v1.11 Keyboard [SteelSeries SteelSeriesAerox 5 Wireless] on usb-0000:0b:00.3-2/input1
[ 3.067507] input: SteelSeries SteelSeries Aerox 5 Wireless as /devices/pci0000:00/0000:00:08.1/0000:0b:00.3/usb2/2-2/2-2:1.2/0003:1038:1852.0003/input/input5
[ 3.104907] usb 5-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 3.118829] hid-generic 0003:1038:1852.0003: input,hidraw2: USB HID v1.11 Device [SteelSeries SteelSeries Aerox 5 Wireless] on usb-0000:0b:00.3-2/input2
[ 3.122471] hid-generic 0003:1038:1852.0004: hiddev96,hidraw3: USB HID v1.11 Device [SteelSeries SteelSeries Aerox 5 Wireless] on usb-0000:0b:00.3-2/input3
[ 3.127414] hid-generic 0003:1038:1852.0005: hiddev97,hidraw4: USB HID v1.11 Device [SteelSeries SteelSeries Aerox 5 Wireless] on usb-0000:0b:00.3-2/input4
[ 3.127433] usbcore: registered new interface driver usbhid
[ 3.127434] usbhid: USB HID core driver
[ 3.131142] usb 5-1: New USB device found, idVendor=0bda, idProduct=0411, bcdDevice= 1.15
[ 3.131144] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.131145] usb 5-1: Product: 4-Port USB 3.0 Hub
[ 3.131146] usb 5-1: Manufacturer: Generic
[ 3.155810] hub 5-1:1.0: USB hub found
[ 3.156993] hub 5-1:1.0: 4 ports detected
[ 3.238004] usb 1-2: new high-speed USB device number 3 using xhci_hcd
[ 3.342363] usb 4-2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.08
[ 3.342368] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.342369] usb 4-2: Product: USB Receiver
[ 3.342370] usb 4-2: Manufacturer: Logitech
[ 3.370015] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=70.32
[ 3.370019] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.370020] usb 1-2: Product: USB2.1 Hub
[ 3.370020] usb 1-2: Manufacturer: GenesysLogic
[ 3.374156] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.0/0003:046D:C52B.0006/input/input6
[ 3.425571] hub 1-2:1.0: USB hub found
[ 3.425883] hid-generic 0003:046D:C52B.0006: input,hidraw5: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:09:00.0-2/input0
[ 3.426164] hub 1-2:1.0: 4 ports detected
[ 3.448487] input: Logitech USB Receiver Mouse as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.1/0003:046D:C52B.0007/input/input7
[ 3.448567] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.1/0003:046D:C52B.0007/input/input8
[ 3.488686] usb 5-2: new SuperSpeed Plus Gen 2x1 USB device number 3 using xhci_hcd
[ 3.499856] input: Logitech USB Receiver System Control as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.1/0003:046D:C52B.0007/input/input9
[ 3.499912] hid-generic 0003:046D:C52B.0007: input,hiddev98,hidraw6: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:09:00.0-2/input1
[ 3.502834] usb 5-2: New USB device found, idVendor=05e3, idProduct=0625, bcdDevice=70.32
[ 3.502835] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.502835] usb 5-2: Product: USB3.2 Hub
[ 3.502836] usb 5-2: Manufacturer: GenesysLogic
[ 3.515139] hid-generic 0003:046D:C52B.0008: hiddev99,hidraw7: USB HID v1.11 Device [Logitech USB Receiver]on usb-0000:09:00.0-2/input2
[ 3.520624] hub 5-2:1.0: USB hub found
[ 3.520914] hub 5-2:1.0: 4 ports detected
[ 3.576738] usb 1-1.2: new high-speed USB device number 4 using xhci_hcd
[ 3.614851] logitech-djreceiver 0003:046D:C52B.0008: hiddev98,hidraw5: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:09:00.0-2/input2
[ 3.668501] usb 1-1.2: New USB device found, idVendor=045e, idProduct=02fe, bcdDevice= 1.00
[ 3.668505] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.668506] usb 1-1.2: Product: XBOX ACC
[ 3.668507] usb 1-1.2: Manufacturer: Microsoft Inc.
[ 3.668507] usb 1-1.2: SerialNumber: 452648
[ 3.690746] usb 4-3: new full-speed USB device number 3 using xhci_hcd
[ 3.726165] input: Logitech Wireless Device PID:4004 Keyboard as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.2/0003:046D:C52B.0008/0003:046D:4004.0009/input/input11
[ 3.726221] hid-generic 0003:046D:4004.0009: input,hidraw6: USB HID v1.11 Keyboard [Logitech Wireless Device PID:4004] on usb-0000:09:00.0-2/input2:1
[ 3.779596] usb 5-1.1: new SuperSpeed USB device number 4 using xhci_hcd
[ 3.798064] input: Logitech K360 as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-2/4-2:1.2/0003:046D:C52B.0008/0003:046D:4004.0009/input/input15
[ 3.798123] logitech-hidpp-device 0003:046D:4004.0009: input,hidraw6: USB HID v1.11 Keyboard [Logitech K360] on usb-0000:09:00.0-2/input2:1
[ 3.801154] usb 5-1.1: New USB device found, idVendor=058f, idProduct=6387, bcdDevice= 0.02
[ 3.801156] usb 5-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.801157] usb 5-1.1: Product: Mass Storage
[ 3.801158] usb 5-1.1: Manufacturer: Generic
[ 3.801158] usb 5-1.1: SerialNumber: AEC2D60E
[ 3.803894] usb-storage 5-1.1:1.0: USB Mass Storage device detected
[ 3.803973] scsi host4: usb-storage 5-1.1:1.0
[ 3.803998] usbcore: registered new interface driver usb-storage
[ 3.805378] usbcore: registered new interface driver uas
[ 3.870995] usb 1-1.4: new full-speed USB device number 5 using xhci_hcd
[ 4.065061] usb 4-3: New USB device found, idVendor=046d, idProduct=c539, bcdDevice=39.06
[ 4.065066] usb 4-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.065067] usb 4-3: Product: USB Receiver
[ 4.065068] usb 4-3: Manufacturer: Logitech
[ 4.089500] logitech-djreceiver 0003:046D:C539.000A: hidraw7: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:09:00.0-3/input0
[ 4.149529] logitech-djreceiver 0003:046D:C539.000B: hiddev99,hidraw8: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:09:00.0-3/input1
[ 4.208236] logitech-djreceiver 0003:046D:C539.000C: hiddev100,hidraw9: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:09:00.0-3/input2
[ 4.265307] logitech-djreceiver 0003:046D:C539.000C: device of type eQUAD Lightspeed 1 (0x0c) connected on slot 1
[ 4.274103] input: Logitech G604 as /devices/pci0000:00/0000:00:02.1/0000:02:00.0/0000:03:0c.0/0000:09:00.0/usb4/4-3/4-3:1.2/0003:046D:C539.000C/0003:046D:4085.000D/input/input16
[ 4.274179] logitech-hidpp-device 0003:046D:4085.000D: input,hidraw10: USB HID v1.11 Keyboard [Logitech G604 ] on usb-0000:09:00.0-3/input2:1
[ 4.430453] usb 1-1.4: New USB device found, idVendor=046d, idProduct=0a66, bcdDevice= 1.00
[ 4.430457] usb 1-1.4: New USB device strings: Mfr=3, Product=4, SerialNumber=0
[ 4.430458] usb 1-1.4: Product: G533 Gaming Headset
[ 4.430459] usb 1-1.4: Manufacturer: Logitech
[ 4.440745] usb 4-6: new high-speed USB device number 4 using xhci_hcd
[ 4.480688] usb 5-2.2: new SuperSpeed USB device number 5 using xhci_hcd
[ 4.492654] usb 5-2.2: New USB device found, idVendor=1058, idProduct=25a3, bcdDevice=10.21
[ 4.492658] usb 5-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.492660] usb 5-2.2: Product: Elements 25A3
[ 4.492661] usb 5-2.2: Manufacturer: Western Digital
[ 4.492661] usb 5-2.2: SerialNumber: 574343374B37534B4E394458
[ 4.493040] usb-storage 5-2.2:1.0: USB Mass Storage device detected
[ 4.493158] scsi host5: usb-storage 5-2.2:1.0
[ 4.499615] input: Logitech G533 Gaming Headset Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/usb1/1-1/1-1.4/1-1.4:1.3/0003:046D:0A66.000E/input/input17
[ 4.551127] input: Logitech G533 Gaming Headset as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/usb1/1-1/1-1.4/1-1.4:1.3/0003:046D:0A66.000E/input/input18
[ 4.551160] input: Logitech G533 Gaming Headset as /devices/pci0000:00/0000:00:08.1/0000:0b:00.4/usb1/1-1/1-1.4/1-1.4:1.3/0003:046D:0A66.000E/input/input20
[ 4.551211] hid-generic 0003:046D:0A66.000E: input,hiddev101,hidraw11: USB HID v1.11 Device [Logitech G533 Gaming Headset] on usb-0000:0b:00.4-1.4/input3
[ 5.538753] scsi 5:0:0:0: Direct-Access WD Elements 25A3 1021 PQ: 0 ANSI: 6
[ 6.351497] usb 4-6: New USB device found, idVendor=0b05, idProduct=1a52, bcdDevice= 0.02
[ 6.351501] usb 4-6: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 6.351502] usb 4-6: Product: USB Audio
[ 6.351503] usb 4-6: Manufacturer: Generic
[ 6.397826] scsi 4:0:0:0: Direct-Access Generic Flash Disk 8.01 PQ: 0 ANSI: 6
[ 6.398331] sd 5:0:0:0: [sdf] Very big device. Trying to use READ CAPACITY(16).
[ 6.398441] sd 5:0:0:0: [sdf] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 6.398443] sd 5:0:0:0: [sdf] 4096-byte physical blocks
[ 6.398716] sd 5:0:0:0: [sdf] Write Protect is off
[ 6.398718] sd 5:0:0:0: [sdf] Mode Sense: 47 00 10 08
[ 6.398851] sd 4:0:0:0: [sde] 122880000 512-byte logical blocks: (62.9 GB/58.6 GiB)
[ 6.399004] sd 4:0:0:0: [sde] Write Protect is off
[ 6.399005] sd 4:0:0:0: [sde] Mode Sense: 23 00 00 00
[ 6.399008] sd 5:0:0:0: [sdf] No Caching mode page found
[ 6.399010] sd 5:0:0:0: [sdf] Assuming drive cache: write through
[ 6.399148] sd 4:0:0:0: [sde] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6.401033] sde: sde1 sde2
[ 6.401070] sd 4:0:0:0: [sde] Attached SCSI removable disk
[ 6.402011] sdf: sdf1
[ 6.402042] sd 5:0:0:0: [sdf] Attached SCSI disk
[ 6.416578] hid-generic 0003:0B05:1A52.000F: hiddev102,hidraw12: USB HID v1.11 Device [Generic USB Audio] on usb-0000:09:00.0-6/input7
[ 6.592742] usb 4-7: new full-speed USB device number 5 using xhci_hcd
[ 6.881581] ISO 9660 Extensions: Microsoft Joliet Level 3
[ 6.882324] ISO 9660 Extensions: RRIP_1991A
[ 6.886518] loop: module loaded
[ 6.886795] loop0: detected capacity change from 0 to 29944
[ 6.906417] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 6.908815] loop1: detected capacity change from 0 to 858760
[ 6.942892] loop2: detected capacity change from 0 to 5836800
[ 6.954247] usb 4-7: config 1 has an invalid interface number: 2 but max is 1
[ 6.954249] usb 4-7: config 1 has no interface number 1
[ 6.966301] usb 4-7: New USB device found, idVendor=0b05, idProduct=19af, bcdDevice= 1.00
[ 6.966303] usb 4-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.966304] usb 4-7: Product: AURA LED Controller
[ 6.966305] usb 4-7: Manufacturer: AsusTek Computer Inc.
[ 6.966306] usb 4-7: SerialNumber: 9876543210
[ 6.976540] loop3: detected capacity change from 0 to 1419168
[ 6.982046] hid-generic 0003:0B05:19AF.0010: hiddev103,hidraw13: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:09:00.0-7/input2
[ 7.017567] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[ 7.057397] dracut: Mounted root filesystem overlay
[ 7.101729] dracut: Switching root
[ 7.157740] usb 4-8: new high-speed USB device number 6 using xhci_hcd
[ 7.369488] usb 4-8: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
[ 7.369491] usb 4-8: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 7.369493] usb 4-8: Product: USB2.0 Hub
[ 7.379549] hub 4-8:1.0: USB hub found
[ 7.383475] hub 4-8:1.0: 4 ports detected
[ 7.813540] systemd[1]: systemd 253.1-3-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 7.813543] systemd[1]: Detected architecture x86-64.
[ 7.836649] systemd[1]: Hostname set to <garuda-dr460nized-gaming>.
[ 8.149801] systemd[1]: bpf-lsm: LSM BPF program attached
[ 8.279621] zram: Added device: zram0
[ 8.392826] systemd[1]: /usr/lib/systemd/system/grub-btrfs-snapper.service:11: Ignoring unknown escape sequences: "if [[ -z $(/usr/bin/findmnt -n / | /usr/bin/grep "\.snapshots") ]]; then if [ -s "${GRUB_BTRFS_GRUB_DIRNAME:-/boot/grub}/grub-btrfs.cfg" ]; then /etc/grub.d/41_snapshots-btrfs; else ${GRUB_BTRFS_MKCONFIG:-grub-mkconfig} -o ${GRUB_BTRFS_GRUB_DIRNAME:-/boot/grub}/grub.cfg; fi; fi"
[ 8.393904] systemd[1]: Queued start job for default target Graphical Interface.
[ 8.402012] systemd[1]: Created slice Virtual Machine and Container Slice.
[ 8.402231] systemd[1]: Created slice Slice /system/getty.
[ 8.402374] systemd[1]: Created slice Slice /system/modprobe.
[ 8.402476] systemd[1]: Created slice Slice /system/systemd-zram-setup.
[ 8.402547] systemd[1]: Created slice User and Session Slice.
[ 8.402572] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.402643] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.402660] systemd[1]: Reached target Login Prompts.
[ 8.402674] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 8.402687] systemd[1]: Reached target Remote File Systems.
[ 8.402702] systemd[1]: Reached target Slice Units.
[ 8.402724] systemd[1]: Reached target Local Verity Protected Volumes.
[ 8.402757] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 8.403888] systemd[1]: Listening on LVM2 poll daemon socket.
[ 8.404799] systemd[1]: Listening on Process Core Dump Socket.
[ 8.404844] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.404882] systemd[1]: Listening on Journal Socket.
[ 8.404918] systemd[1]: Listening on Userspace Out-Of-Memory (OOM) Killer Socket.
[ 8.406059] systemd[1]: Listening on udev Control Socket.
[ 8.406093] systemd[1]: Listening on udev Kernel Socket.
[ 8.406437] systemd[1]: Mounting Huge Pages File System...
[ 8.406713] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.406995] systemd[1]: Mounting Kernel Debug File System...
[ 8.407295] systemd[1]: Mounting Kernel Trace File System...
[ 8.423446] systemd[1]: Starting Create List of Static Device Nodes...
[ 8.423745] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.424057] systemd[1]: Starting Load Kernel Module configfs...
[ 8.424405] systemd[1]: Starting Load Kernel Module dm_mod...
[ 8.424787] systemd[1]: Starting Load Kernel Module drm...
[ 8.425125] systemd[1]: Starting Load Kernel Module fuse...
[ 8.425472] systemd[1]: Starting Load Kernel Module loop...
[ 8.426399] systemd[1]: Starting Journal Service...
[ 8.468446] systemd-journald[776]: Collecting audit messages is disabled.
[ 8.487002] fuse: init (API version 7.38)
[ 8.508787] systemd[1]: Starting Load Kernel Modules...
[ 8.508821] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 8.509285] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.509657] systemd[1]: Starting Coldplug All udev Devices...
[ 8.510323] systemd[1]: Started Journal Service.
[ 8.648977] i2c_dev: i2c /dev entries driver
[ 8.680456] systemd-journald[776]: Received client request to flush runtime journal.
[ 8.993487] zram0: detected capacity change from 0 to 65181696
[ 9.114518] igc 0000:05:00.0 enp5s0: renamed from eth0
[ 9.129422] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[ 9.129425] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 9.131161] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 9.131163] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[ 9.131260] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 9.248122] i8042: PNP: No PS/2 controller found.
[ 9.268318] asus_wmi: ASUS WMI generic driver loaded
[ 9.286047] SVM: TSC scaling supported
[ 9.286049] kvm: Nested Virtualization enabled
[ 9.286049] SVM: kvm: Nested Paging enabled
[ 9.286052] SVM: Virtual VMLOAD VMSAVE supported
[ 9.286052] SVM: Virtual GIF supported
[ 9.286052] SVM: LBR virtualization supported
[ 9.305301] MCE: In-kernel MCE decoding enabled.
[ 9.306014] asus_wmi: SFUN value: 0x1
[ 9.306016] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 9.306017] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 9.306019] asus_wmi: Failed to get WMI notify code: AE_NOT_FOUND
[ 9.306019] asus_wmi: Failed to get event during flush: -5
[ 9.306347] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input21
[ 9.308746] asus_wmi: SFUN value: 0x1
[ 9.308747] eeepc-wmi eeepc-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 9.309119] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input22
[ 9.332870] intel_rapl_common: Found RAPL domain package
[ 9.332871] intel_rapl_common: Found RAPL domain core
[ 9.387755] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 9.387820] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 9.387823] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 9.419280] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 9.422905] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input23
[ 9.422942] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input24
[ 9.422962] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input25
[ 9.422977] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.1/0000:01:00.1/sound/card0/input26
[ 9.424098] mousedev: PS/2 mouse device common for all mice
[ 9.468208] Adding 32590844k swap on /dev/zram0. Priority:100 extents:1 across:32590844k SSDscFS
[ 9.479660] mc: Linux media interface: v0.10
[ 9.552603] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.552697] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 9.771844] usb 1-1.2: reset high-speed USB device number 4 using xhci_hcd
[ 9.862255] mt76x2u 1-1.2:1.0: ASIC revision: 76320044
[ 10.897233] NET: Registered PF_QIPCRTR protocol family
[ 11.047261] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 11.074482] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 11.074498] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 11.074513] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 11.074526] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 11.074544] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 11.074558] sd 5:0:0:0: Attached scsi generic sg5 type 0
[ 11.151022] mt76x2u 1-1.2:1.0: could not get hardware semaphore for ROM PATCH
[ 11.705793] mt76x2u: probe of 1-1.2:1.0 failed with error -110
[ 11.705816] usbcore: registered new interface driver mt76x2u
[ 15.837703] usbcore: registered new interface driver snd-usb-audio
[ 17.174185] igc 0000:05:00.0 enp5s0: NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX
[ 17.174281] IPv6: ADDRCONF(NETDEV_CHANGE): enp5s0: link becomes ready
[ 56.578485] logitech-hidpp-device 0003:046D:4085.000D: HID++ 4.2 device connected.
[ 129.522975] logitech-hidpp-device 0003:046D:4004.0009: HID++ 2.0 device connected.
