wirr
13 April 2023 16:56
1
hey guys,
thanks to the help in the other thread, i could proceed with the installation to now, where i'm not getting any sound from displayport-speakers, but the headset is fine... i didnt install the nvidia-propriarity drivers yet as i found too many hints they were causing problems atm ...
i already checked audio settings and tried restarting pipewire-demon, installed/deinstalled both pipewire and pulseaudio forth and back and tried to uninstall wireplumber to install pipewire-media where it crashed and i had to reboot a snapshot beacause of some weired login screen ...
should i next try installing nvidia drivers anyways?
thanks
Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c6a3540d-e2c2-4849-9261-d82666c5d617 rw rootflags=subvol=@
loglevel=3 ibt=off
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0421
date: 08/19/2022
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
model-id: 0x61 (97) stepping: 2 microcode: 0xA601201
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4655 high: 4700 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4700 2: 4700
3: 3640 4: 4700 5: 4700 6: 4700 7: 4700 8: 4700 9: 4700 10: 4700 11: 4700
12: 4700 13: 4700 14: 4700 15: 4700 16: 4700 17: 4700 18: 4700 19: 4700
20: 4700 21: 4700 22: 4700 23: 4700 24: 4700 bogomips: 225163
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-03)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DP-3,
HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
s-diag: 777mm (30.58")
Monitor-1: DP-2 model: LG (GoldStar) 32GK850G serial: <filter> built: 2017
res: 2560x1440 hz: 60 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
API: OpenGL v: 4.3 Mesa 23.0.2 renderer: NV172 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel bus-ID: 2-6:4 v: kernel pcie: chip-ID: 0b05:1a52
class-ID: 0300 gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aef class-ID: 0403
Device-2: ASUSTek USB Audio type: USB
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1.4:5 chip-ID: 046d:0a66
API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
Device-2: Microsoft Xbox Wireless Adapter for Windows type: USB
driver: N/A bus-ID: 3-1.2:4 chip-ID: 045e:02fe class-ID: 0000
Local Storage: total: 8.84 TiB used: 822.34 GiB (9.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung
rev: 2B2QEXM7 temp: 66.8 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
size: 1.75 TiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM15.1 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
type: SSD serial: <filter> rev: 020 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD8SBBU240G1122
type: SSD serial: <filter> rev: 6000 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD40EMRX-82UZ0N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1021 scheme: GPT
ID-8: /dev/sdf maj-min: 8:80 type: USB vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.01 scheme: MBR
used: 12.71 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-1: swap-1 type: zram size: 31.08 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 62.4 C mobo: N/A
Processes: 428 Uptime: 46m wakeups: 9 Memory: 31.08 GiB
used: 3.04 GiB (9.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1835
libs: 549 tools: octopi,pamac,paru Shell: fish v: 3.6.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-04-13
Last full system update: 2023-04-13 ↻
wirr
14 April 2023 13:49
2
ok, i now additionally tried to use different kernels(lts+amd) without a difference.. and then i found this thread but
the /etc/udev/rules.d/90-mhwd-prime-powermanagement.rules is empty and
the /lib/udev/rule.d there is no mhwd-prime-powermanager (but there are some pipewire or upower rules though)
[PS: i also found this post with this advice but i actually don't understand how i should do that ,as if i use journalctl --user -u pipewire --user -u pipewire-media-session --user -u pipewire-pulse -f it just showes
[🧱] × journalctl --user -u pipewire --user -u pipewire-media-session --user -u pipewire-pulse -f
Apr 14 16:06:25 wirr-sys systemd[2447]: Started PipeWire Multimedia Service.
Apr 14 16:06:26 wirr-sys systemd[2447]: Started PipeWire PulseAudio.
^C⏎
╭─wirr@wirr in ~ took 26s
[🧱] × $ aplay -1
fish: Expected a variable name after this $.
wirr
15 April 2023 12:00
3
ok, after some problems with crashes , i'm back to this problem with no sound on display-port (headphones work still fine) , but the nvidia-prop-drivers are installed now
here is my updated garuda-inxi
╭─wirr@wirr in ~
╰─λ garuda-inxi
Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b3328148-480b-42c9-9425-ff822289ea26 rw rootflags=subvol=@
serial: <superuser required> UEFI: American Megatrends v: 1410
date: 03/17/2023
Speed (MHz): avg: 5172 high: 5187 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 5161 2: 5160
3: 5161 4: 5161 5: 5162 6: 5161 7: 5180 8: 5182 9: 5180 10: 5180 11: 5182
12: 5182 13: 5160 14: 5161 15: 5161 16: 5187 17: 5162 18: 5160 19: 5180
20: 5183 21: 5182 22: 5180 23: 5180 24: 5180 bogomips: 225169
driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1, HDMI-A-2
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4,HDMI-A-3
bus-ID: 0d:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 60.0 C
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi gpu: nouveau display-ID: :0
API: OpenGL v: 4.5 Mesa 23.0.2 renderer: llvmpipe (LLVM 15.0.7 256 bits)
direct-render: Yes
driver: snd_hda_intel v: kernel bus-ID: 1-1.4:6 pcie: chip-ID: 046d:0a66
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-4: ASUSTek USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-6:4 chip-ID: 0b05:1a52
API: ALSA v: k6.2.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows type: USB
driver: N/A bus-ID: 1-1.2:4 chip-ID: 045e:02fe class-ID: 0000
Device-1: Foxconn / Hon Hai Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 5-11:7 chip-ID: 0489:e0e2 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 8.9 TiB used: 463.9 GiB (5.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
lanes: 4 type: SSD serial: <filter> rev: ECFM15.1 temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
rev: 2B2QEXM7 temp: 67.8 C scheme: GPT
ID-8: /dev/sdf maj-min: 8:80 type: USB vendor: Intenso model: Basic Line
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.05 scheme: MBR
ID-9: /dev/sdg maj-min: 8:96 type: USB vendor: Generic model: Flash Disk
used: 16.53 GiB (3.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 78.9 C mobo: N/A gpu: amdgpu temp: 60.0 C
Processes: 467 Uptime: 33m wakeups: 16 Memory: 30.5 GiB
used: 4.09 GiB (13.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1850
libs: 552 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date: 2023-04-15
Last full system update: 2023-04-15 ↻
wirr
15 April 2023 12:25
4
nevermind me strange...
after rebooting it did work to "channel al device to this port" and now it seems everything is working as intended .... sorry for my overshoot
system
Closed
17 April 2023 12:26
5
