Hello again,
here is the other problem, i've got, sometimes i experience strange input lags from my wireless keyboard one the logitec unifiing receiver, either it ignores the entries or it stuck on one letter for a second or something ... and it changes from okay to worse and back... idk why , it was a bit better after some bios update but only for 2-3 weeks or so.... i already tried the same stuff, like different kernels, regular update, reinstalling everything, those bios updates and rearranging the usb devices ....
─[email protected] in ~
╰─λ garuda-inxi
Kernel: 6.3.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b3328148-480b-42c9-9425-ff822289ea26 rw [email protected]
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm:
1: GDM v: 44.1 note: stopped 2: SDDM Distro: Garuda Linux base: Arch Linux
Mobo: ASUSTeK model: ROG STRIX B650E-E GAMING WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1410
date: 03/17/2023
Device-1: hidpp_battery_0 model: Logitech G604 Wireless GaG604 Wirel
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Device-2: hidpp_battery_1 model: Logitech Wireless KeyboarWirele
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4565 high: 5490 min/max: 3000/5733 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4700 2: 4700
3: 4700 4: 4700 5: 3802 6: 4700 7: 3593 8: 4700 9: 4700 10: 4700 11: 4700
12: 4700 13: 4700 14: 4700 15: 4700 16: 3802 17: 4700 18: 4700 19: 4700
20: 4700 21: 4700 22: 3593 23: 4700 24: 5490 bogomips: 225172
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: ASUSTeK
status: current (as of 2023-05) arch: Ampere code: GAxxx
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-2: AMD Raphael vendor: ASUSTeK driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 0d:00.0 chip-ID: 1002:164e class-ID: 0300 temp: 60.0 C
gpu: nvidia,amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x393mm (27.83x15.47")
s-diag: 809mm (31.85")
Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 93
size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
Device-4: Logitech [G533 Wireless Headset Dongle]
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 046d:0a66 class-ID: 0300
API: ALSA v: k6.3.2-zen1-1-zen status: kernel-api with: aoss
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0616 class-ID: 0280
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: N/A
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:10
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Local Storage: total: 8.79 TiB used: 1.69 TiB (19.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: OWC model: Aura P12 Pro 2.0TB
size: 1.75 TiB block-size: physical: 4096 B logical: 4096 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM15.1 temp: 30.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 66.8 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SD8SBBU240G1122
tech: SSD serial: <filter> fw-rev: 6000 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD40EMRX-82UZ0N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1021 scheme: GPT
used: 69.27 GiB (14.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 30.5 GiB used: 130 MiB (0.4%) priority: 100
System Temperatures: cpu: 72.8 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 55 C fan: 53% device: amdgpu
temp: 60.0 C
Processes: 519 Uptime: 2h 1m wakeups: 307 Memory: available: 30.5 GiB
used: 5.72 GiB (18.8%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1875
libs: 557 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-04-15
Last full system update: 2023-05-16
╭─[email protected] in ~ took 1s
