I used to not have this problem, but my system now crashes about 5x a day. It even crashed in the middle of an update which completely changed the overall layout of my terminal. My terminal is now completely plain, just like after a vanilla arch install. If I run neofetch, I get the G in colors that resemble the Indian flag. Orange, white, and green.
Secondary issue that might be related, after input of sudo pacman -Syu, I get this
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Failed to connect to mirror.theash.xyz port 443 after 47 ms: Connection refused
THIRD ISSUE, after my system crashes and restarts, my laptop stops charging. I have to shut the computer down, unplug the cable, and plug it back in when my computer is off, THEN turn it back on. Otherwise it will not charge. My computer is a Dell XPS 15 9500.
λ sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 1706.3 KiB 2.52 MiB/s 00:01 [------------------------------------] 100%
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Failed to connect to mirror.theash.xyz port 443 after 35 ms: Connection refused
there is nothing to do
EDIT: here's the textual output
λ garuda-inxi
root=UUID=5d0daf37-2fd1-4f15-983f-f88071f25b91 rw [email protected]
Type: Laptop System: Dell product: XPS 15 9500 v: N/A
Mobo: Dell model: 05XYW7 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.0 date: 11/12/2021
ID-1: BAT0 charge: 75.7 Wh (96.3%) condition: 78.6/84.3 Wh (93.2%)
volts: 12.9 min: 11.4 model: SMP DELL 70N2F95 type: Li-poly
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
v: kernel ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Dell
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-11:5 chip-ID: 0c45:6d14 class-ID: 0e02
Device-4: USB C Video Adaptor type: USB driver: N/A bus-ID: 1-4.3:6
chip-ID: 25a4:9311 class-ID: 1100 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x14d1 built: 2020 res: 1920x1200 hz: 60
dpi: 145 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
ratio: 16:10 modes: 1920x1200
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.0.1
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 27.46 GiB (5.8%)
model: PC SN730 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 11170012 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 211.83 GiB size: 211.83 GiB (100.00%)
used: 27.36 GiB (12.9%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 650 MiB size: 646 MiB (99.38%)
used: 103.9 MiB (16.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 211.83 GiB size: 211.83 GiB (100.00%)
ID-4: /var/log raw-size: 211.83 GiB size: 211.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 211.83 GiB size: 211.83 GiB (100.00%)
ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-2: swap-2 type: zram size: 15.37 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C pch: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 299 Uptime: 17m wakeups: 4245 Memory: 15.38 GiB
used: 3.21 GiB (20.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1274 lib: 339 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-02-22
Last full system update: 2022-04-13 ↻
Snapshots: Snapper (maybe)
