Hey
I have big problems with sound on garuda since I installed it.
The sound sometimes almost randomly doesnt work, firedragon also doesnt work correctly when that happens, when playing a video on youtube it loads for some time and then the whole browser freezes. Sound tests work but everything else doesnt. I tried stuff from the arch wiki and also stuff from forums but I couldnt resolve it. Would be nice if someone could help me on here ![]()
garuda-inxi:
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7b132aa0-c8bb-43f6-bf92-5df4993fce8a rw rootflags=subvol=@
resume=UUID=fa8276ff-217f-44da-98a2-4c66bad9a1e4 loglevel=3
Type: Desktop System: HP product: HP Pavilion Gaming Desktop 790-08xx
v: N/A serial: <superuser required> Chassis: type: 3
Mobo: HP model: 844C v: 00 serial: <superuser required> UEFI: AMI v: F.43
date: 11/25/2020
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2018 process: Intel 14nm family: 6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2006 high: 3200 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1800 2: 1800 3: 2100
4: 1801 5: 1861 6: 1800 7: 2269 8: 3200 9: 1799 10: 2050 11: 1800
12: 1800 bogomips: 76799
vulnerable
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Hewlett-Packard
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 90 s-size: 542x301mm (21.34x11.85")
s-diag: 620mm (24.41")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 90
size: 543x302mm (21.38x11.89") diag: 621mm (24.46") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-2: NVIDIA GP106 High Definition Audio vendor: Hewlett-Packard
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.19.13-zen1-1-zen running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-14:5 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Local Storage: total: 1.14 TiB used: 577.73 GiB (49.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: ADHA0101
temp: 56.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: HPH4
ID-1: / raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 61.69 GiB
(27.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 61.69
GiB (27.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 61.69
ID-5: /var/tmp raw-size: 221.27 GiB size: 221.27 GiB (100.00%) used: 61.69
ID-1: swap-1 type: zram size: 15.37 GiB used: 142 MiB (0.9%)
ID-2: swap-2 type: partition size: 16.9 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.0 C pch: 54.0 C mobo: N/A gpu: nvidia
temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Processes: 315 Uptime: 31m wakeups: 0 Memory: 15.37 GiB used: 7.21 GiB
(46.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1499 libs: 444
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-18
Last full system update: 2022-10-05 ↻
Please, use this
Text from terminal
to make it more readable in the forum.
