I tried many fixes from the community forums but I was not able to resolve the sound issue with my machine on which I installed Garuda Linux, I searched alot and many other users are also finding difficulty to resolve the audio issue with Garuda linux.
I tried using garuda assistance for audio related problems and I followed whatever is required but I need to manually increase/ decrease/mute/unmute change the output of port of audio whenever I restart my System.
can anyone help to resolve this permanently?
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=71e780c4-f7a1-4858-904f-bdb4677ecd5c rw rootflags=subvol=@
resume=UUID=70fae1f4-4c84-497f-99e3-eb4223ba0592 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724 WIN
serial: <superuser required> UEFI: LENOVO v: EUCN37WW date: 04/14/2022
ID-1: BAT0 charge: 38.6 Wh (75.0%) condition: 51.5/60.0 Wh (85.8%)
power: 13.3 W volts: 16.1 min: 15.4 model: SMP L19M4PC0 type: Li-poly
serial: <filter> status: discharging cycles: 267
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 high: 1424 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1424 2: 1405
3: 1400 4: 1396 5: 1396 6: 1397 7: 1395 8: 1397 9: 1400 10: 1400 11: 1397
12: 1397 bogomips: 71865
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 535.54.03
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xd1ed built: 2019
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.4.3-zen1-1-zen) direct-render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.73 status: active with:
1: pipewire-media-session status: active 2: pw-jack type: plugin
tools: pw-cat,pw-cli
Server-2: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:5 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 5 state: down
address: <filter>
Local Storage: total: 1.14 TiB used: 42.23 GiB (3.6%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 3L1QEXH7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-08Z10
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A05 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 42.23 GiB (18.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.13 GiB used: 17.1 MiB (0.2%) priority: 100
System Temperatures: cpu: 41.2 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 307 Uptime: 1h 0m wakeups: 4 Memory: total: 8 GiB note: est.
available: 7.14 GiB used: 3.12 GiB (43.7%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: apk
pkgs: 0 pm: dpkg pkgs: 0 pm: pacman pkgs: 1335 libs: 362
tools: octopi,paru,yay Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.28
System install date:     2023-05-04
Last full system update: 2023-07-12
