So I have installed garuda yesterday and it appearance that I don’t have audio, I have tried to switch things and nothing happen. I have did a little research about this problem and found this and appearance that it works for him, but not for me. Right now I have installed : ALSA support, JACK support and User in real time group.
Also the mic of the headset works or that is what discord says. I have tried using other headset to check the audio, and one with bluetooth and it works.
Kernel: 6.10.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=0a5e2cc5-ab1c-41e7-93be-8a982c17d085 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop System: HP product: OMEN 25L Desktop GT11-0xxx v: N/A
Mobo: HP model: 8704 v: 00 serial: <superuser required>
part-nu: 1E0D2EA#ABE uuid: <superuser required> UEFI: AMI v: F.23
date: 10/13/2022
Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 840 high: 900 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 845 3: 898 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 900 11: 900 12: 800 13: 900 14: 800
15: 900 16: 900 bogomips: 92796
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Hewlett-Packard
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1
bus-ID: 01:00.0 chip-ID: 10de:21c4 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2 memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 SUPER driver: nvidia v: 560.35.03 device-ID: 10de:21c4
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
API: ALSA v: k6.10.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5020
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 15.11 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1006 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20120006 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8L0 scheme: GPT
used: 15.11 GiB (3.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.0 C pch: 46.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 16 GiB available: 15.48 GiB used: 2.73 GiB (17.7%)
Processes: 369 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1375 libs: 401 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.35
System install date: 2024-08-29
Last full system update: 2024-08-30
