Hello!
i don't really know how to start and i hope i can find some help here. This issue is super vague and i don't know where to start looking...
Since yesterday, out of the blue, my system started to become sluggish and slow. Kinda. I did not install anything new, no system upgrade, no new game or anything.
When i wanted to open my console, it took longer than usual. But once i openend the console and closed it, it would open as quick as usual when i tried again. Until i opened a different app. That app would take longer than usual. To conclude this. When i open e.g. Dolphin and no other dolphin session is running right now, it's slow. Like 2-3 seconds. Once i opened it and have not opened another new app in the meantime. It will open instantly. Same goes for every other app on my system right now.
But the much bigger issue, is that i observed that all my games are hicky and sluggish aswell. Regular framedrops, the sound is really stuttering.
Since then i have updated my system, rebooted multiple times, turned the PC off and pulled the powerchord for an hour or so to maybe reset some chipsets...To no avail.
I then started to go through all the apps i autostart at boot and disabled them so i start with nothing from my personal list but only system tools. No avail. I reinstalled wireplumber and pipewire because i thought those are maybe the culprit for atleast the game issues. Also no avail.
I don't really know what to do anymore. My system is kinda bloated and i use a lot of stuff...But it worked perfectly fine all the time, and all of a sudden it didn't ... so i don't think that the number of apps i use are the real issue here, but rather some new incompatibility or something.
Can someone help me troubleshoot this a bit better?
Kernel: 5.19.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c3ef0d61-a4ef-469b-96b1-b7a7583d021e rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 info: latte-dock, polybar
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 4801
date: 03/02/2022
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
level: v3 built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8
stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3987 high: 4003 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3992 2: 3992
3: 3992 4: 3971 5: 4000 6: 3989 7: 4003 8: 3992 9: 3977 10: 3983 11: 3983
12: 3973 bogomips: 86234
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 09:00.0 chip-ID: 10de:2484
compositors: 1: kwin_x11 2: Picom v: git-f70d0 driver: X: loaded: nvidia
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4520x1920 s-dpi: 51 s-size: 2251x301mm (88.62x11.85")
s-diag: 2271mm (89.41")
Monitor-1: DP-2 pos: primary,top-left res: 1080x1920 hz: 60 dpi: 92
size: 299x531mm (11.77x20.91") diag: 609mm (23.99") modes: N/A
Monitor-2: DP-4 pos: primary,bottom-r res: 3440x1440 dpi: 109
size: 800x330mm (31.5x12.99") diag: 865mm (34.07") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Sound Server-1: ALSA v: k5.19.9-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 3-2.1.1:4 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
address: <filter>
Local Storage: total: 2.39 TiB used: 991.42 GiB (40.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDHTNG-8310A size: 238.47 GiB block-size: physical: 512 B
rev: 80070C00 temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO
250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B2QEXE7
temp: 58.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 033 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDP128G
size: 117.38 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD103SI
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1118 scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 129.65 GiB
(55.7%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 129.65
GiB (55.7%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 129.65
ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 129.65
ID-1: swap-1 type: zram size: 15.54 GiB used: 4.54 GiB (29.2%)
System Temperatures: cpu: 57.0 C mobo: 48.0 C gpu: nvidia temp: 47 C
Fan Speeds (RPM): cpu: 1496 case-1: 1049 case-2: 0 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 9.92 5v: N/A 3.3v: N/A vbat: 3.21
Processes: 427 Uptime: 24m wakeups: 0 Memory: 15.54 GiB used: 6.55 GiB
(42.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 2163 pm: pacman
pkgs: 2151 libs: 553 tools: pamac,paru pm: flatpak pkgs: 12 Shell: fish
v: 3.5.1 running-in: alacritty inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-16
Last full system update: 2022-09-17 ↻
Oh also i booted into memtest86+ and let it check my system. Everything seems to be in top condition there
