I've been using Garuda for a few months. Its amazing in every way. The only issue I've had with anything out of the box is a mysterious and infrequent bug where my pc reboots or crashes(ie no post or wakeup possible) when I'm away from the computer. I've never actively caught it rebooting so I theorize that the issue is with the sleep settings? I'm mostly reaching here though. I've been saving the journalctl logs each time it happens to find trends/patterns but have had no luck.
I have not tried much at all to resolve the issue, as I feel silly trying to fix a problem I can't wholly identify. But have tried
1.) Installing xscreensaver and adjusting a few settings to prove if it was a sleep issue. No luck.
2.) Posting on reddit how to ask for help with such limited knowledge. It was removed immediately due to help flair I suppose.
3.) Daily garuda-update with prayers each time.
4.) I have done fresh reinstalls a few times already because the first few times I encountered the issue, I assumed I had tampered with config files too much. My current install I have been very careful to not alter much of anything so I feel less guilty for the situation.
I am primarily looking for advice on how to structure a path toward diagnosing the issue. It blows my mind at how far I've pushed this machine on garuda (lots of gaming) with no crashes, but somehow idling just breaks the whole thing and forces a reboot. My motherboard being 5 years old shouldn't raise suspicions, right? I really prefer fixing ish myself, but have been stuck here with no ideas going forward for a few days now...
I am willing to investigate any and all ideas with great appreciation!
╰─λ garuda-inxi
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=3cd49b86-109a-414c-83ab-7284e660632f rw rootflags=subvol=@
resume=UUID=aed0cb22-d9f7-4fe6-82c6-fbbe92d2b4f6 loglevel=3
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASRock model: AB350M-HDV serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P1.30 date: 03/20/2017
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x800110E
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3002 high: 3559 min/max: 1550/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3005 2: 2935
3: 2806 4: 2731 5: 2726 6: 2891 7: 3027 8: 2956 9: 3316 10: 3230 11: 2848
12: 3559 bogomips: 76657
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: PNY driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:1b81 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 1-7:3 pcie: chip-ID: 1532:0510
gen: 3 class-ID: 0300 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 0a:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 12:00.3
Device-3: Razer USA Kraken 7.1 V2 type: USB
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 08:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wls1 state: dormant mac: <filter>
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 698.65 GiB used: 114.74 GiB (16.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 448.62 GiB size: 448.62 GiB (100.00%)
used: 114.74 GiB (25.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 448.62 GiB size: 448.62 GiB (100.00%)
ID-3: /var/log raw-size: 448.62 GiB size: 448.62 GiB (100.00%)
ID-4: /var/tmp raw-size: 448.62 GiB size: 448.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 1.8 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 57 C
Processes: 324 Uptime: 7h 32m wakeups: 0 Memory: 15.58 GiB
used: 4.12 GiB (26.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1897
lib: 544 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-23
Last full system update: 2022-06-30 ↻
