Hello Garuda users.
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d7992808-1cb8-4e4b-bf2f-42362922780e rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM note: stopped
Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <filter>
UEFI: American Megatrends v: X556UQK.317 date: 04/16/2019
ID-1: BAT0 charge: 23.5 Wh (100.0%) condition: 23.5/38.0 Wh (61.8%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 258
Info: model: Intel Core i7-7500U socket: U3E1 bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 level: v3 note: check
built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3500 min/max: 400/3500 base/boost: 2600/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 3500 2: 3500 3: 3500 4: 3500 bogomips: 23199
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-1,eDP-1
empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:6 chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau,vesa alternate: fbdev,nv dri: iris gpu: i915
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DP1 pos: left model: KONKA serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 530x290mm (20.87x11.42") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-2: eDP-1 mapped: eDP1 pos: primary,right
model: AU Optronics 0x38ed built: 2014 res: 1920x1080 dpi: 143 gamma: 1.2
size: 340x190mm (13.39x7.48") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.60 running: yes
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
IF-ID-1: br-5adfbd167649 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: br-7fbba6935cb9 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: veth0014a22 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth2fb470d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth6cdd161 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:12
chip-ID: 04ca:3018 class-ID: e001
Local Storage: total: 2.05 TiB used: 122.61 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 033 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 19d 9h cycles: 176
written: 8.76 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: MZ7PD256HCGM-000H7
size: 238.47 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 6H6Q temp: 31 C
SMART: yes state: enabled health: PASSED on: 2y 307d 7h cycles: 4642
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: MQ01ABD100
family: 2.5" HDD MQ01ABD... size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: AX0R2J temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 61d 23h cycles: 3208
Old-Age: g-sense error rate: 10682
used: 122.61 GiB (13.2%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 11.57 GiB used: 7.57 GiB (65.4%)
System Temperatures: cpu: 77.0 C pch: 63.5 C mobo: N/A
Fan Speeds (RPM): cpu: 4500
Processes: 424 Uptime: 4h 20m wakeups: 1 Memory: 11.57 GiB
used: 9.11 GiB (78.7%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: 1928 pm: pacman pkgs: 1892
libs: 380 tools: octopi,paru pm: flatpak pkgs: 28 pm: snap pkgs: 8
inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-22
Last full system update: 2022-11-23
Failed units: httpd.service
After many time of using garuda , it have an inconvenient on getting a slow performance . It freezes sometimes . All Gui are stucked.
Can you have a suggestion for me ?
