System hard freezes in some games
Hello Garuda Team, Im currently having a problem I cant fix, searched the web but cannot find a solution. The system in hard freezing in some specific games, the game opens, and works great for a few minutes, but randomly freezes the machine and I cant do a thing, alt-tab, kill the window, being the only solution to hard reset in the power key. I had this problem in Deep Rock Galactic, Warhammer, and League of Legends, but not in Remnant 2, so its very weird. Thanks in advance !
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=39a4b1a1-c8fa-484c-96bc-1a07ebc23212 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: Dell product: Dell G15 5530 v: N/A
Mobo: Dell model: 0X7FHX v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 05/04/2023
ID-1: BAT0 charge: 83.4 Wh (100.0%) condition: 83.4/84.3 Wh (98.9%)
volts: 13.1 min: 11.4 model: SMP DELL 70N2F35 type: Li-poly serial: <filter>
status: not charging cycles: 3
Info: model: 13th Gen Intel Core i5-13450HX bits: 64 type: MST AMCP
microcode: 0x119
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1039 high: 1825 min/max: 800/4600:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 833 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 801 9: 910 10: 1414 11: 1825 12: 800 13: 1558
14: 1432 15: 1465 16: 800 bogomips: 83558
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Dell driver: i915
v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1 bus-ID: 0000:00:02.0 chip-ID: 8086:a78b
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ bus-ID: 0000:01:00.0
chip-ID: 10de:28e1 class-ID: 0300
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 0c45:6730
class-ID: 0e02
Monitor-1: eDP-1 model: Najing CEC Panda 0x005f built: 2021 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a78b memory: 14.95 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:a78b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4050 Laptop GPU driver: nvidia v: 535.113.01
device-ID: 10de:28e1 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel vendor: Dell driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 0000:00:14.3
chip-ID: 8086:7a70 class-ID: 0280
vendor: Dell driver: r8169 v: kernel port: 3000 bus-ID: 0000:02:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 476.94 GiB used: 437.97 GiB (91.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: SM2P41C3 NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 92212301 temp: 60.9 C scheme: GPT
used: 437.97 GiB (91.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 600 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.31 GiB used: 1.22 GiB (7.9%)
System Temperatures: cpu: 67.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (rpm): cpu: 1784
Processes: 376 Uptime: 5h 31m wakeups: 16 Memory: total: 16 GiB note: est.
available: 15.31 GiB used: 6.63 GiB (43.3%) Init: systemd v: 254
pm: pacman pkgs: 1496 libs: 483 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-08-31
Last full system update: 2023-10-19
Try collecting some logs at the exact time the system hangs.
I see you have a lot of disk usage. Make sure you perform a full btrfs balance.
In general, try to give a look at this tutorial.
Maybe this can help ? I believe this is a log from when the game(deep rock) freezed everythig, sorry for my lack of experience. Thank u again for your time.
journalctl --since="2023-10-20 19:07:00"
out 20 19:28:11 skadi kernel: microcode: updated early: 0x112 -> 0x119, date = 2023-06-06
out 20 19:28:11 skadi kernel: Linux version 6.5.7-zen2-1-zen (linux-zen@archlinux) (gcc (GCC) 13.2.1 20230801, GNU ld (GNU Binutils) 2.41.0) #1 ZEN SMP PREEMPT_DYNAMIC Sun, 15 Oct 2023 >
out 20 19:28:11 skadi kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=39a4b1a1-c8fa-484c-96bc-1a07ebc23212 rw rootflags=subvol=@ quiet quiet rd.udev.log_priority=3 >
out 20 19:28:11 skadi kernel: x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
out 20 19:28:11 skadi kernel: BIOS-provided physical RAM map:
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000000100000-0x000000005cd14fff] usable
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x000000005cd15000-0x0000000060d10fff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000060d11000-0x0000000061571fff] ACPI NVS
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000061572000-0x00000000617fefff] ACPI data
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x00000000617ff000-0x00000000617fffff] usable
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000061800000-0x00000000663fffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000066e00000-0x00000000707fffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x00000000f9800000-0x00000000f9ffffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
out 20 19:28:11 skadi kernel: BIOS-e820: [mem 0x0000000100000000-0x000000048f7fffff] usable
out 20 19:28:11 skadi kernel: NX (Execute Disable) protection: active
out 20 19:28:11 skadi kernel: e820: update [mem 0x56c26018-0x56c4aa57] usable ==> usable
out 20 19:28:11 skadi kernel: extended physical RAM map:
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000000000000-0x000000000009efff] usable
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x000000000009f000-0x00000000000fffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000000100000-0x0000000056c26017] usable
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000056c26018-0x0000000056c4aa57] usable
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000056c4aa58-0x000000005cd14fff] usable
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x000000005cd15000-0x0000000060d10fff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000060d11000-0x0000000061571fff] ACPI NVS
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000061572000-0x00000000617fefff] ACPI data
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x00000000617ff000-0x00000000617fffff] usable
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000061800000-0x00000000663fffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000066e00000-0x00000000707fffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x00000000f9800000-0x00000000f9ffffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
out 20 19:28:11 skadi kernel: reserve setup_data: [mem 0x0000000100000000-0x000000048f7fffff] usable
out 20 19:28:11 skadi kernel: efi: EFI v2.7 by Dell
out 20 19:28:11 skadi kernel: efi: ACPI=0x617fe000 ACPI 2.0=0x617fe014 SMBIOS=0x5d5ae000 TPMFinalLog=0x614ac000 ESRT=0x5d546718 MEMATTR=0x57b0a018 INITRD=0x57aeb818 RNG=0x61727018 TPMEv>
out 20 19:28:11 skadi kernel: random: crng init done
out 20 19:28:11 skadi kernel: efi: Remove mem97: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
out 20 19:28:11 skadi kernel: e820: remove [mem 0xc0000000-0xcfffffff] reserved
out 20 19:28:11 skadi kernel: efi: Remove mem98: MMIO range=[0xf9800000-0xf9ffffff] (8MB) from e820 map
out 20 19:28:11 skadi kernel: e820: remove [mem 0xf9800000-0xf9ffffff] reserved
out 20 19:28:11 skadi kernel: efi: Remove mem100: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
out 20 19:28:11 skadi kernel: e820: remove [mem 0xff000000-0xffffffff] reserved
out 20 19:28:11 skadi kernel: SMBIOS 3.6 present.
out 20 19:28:11 skadi kernel: DMI: Dell Inc. Dell G15 5530/0X7FHX, BIOS 1.4.0 05/04/2023
out 20 19:28:11 skadi kernel: tsc: Detected 2600.000 MHz processor
out 20 19:28:11 skadi kernel: tsc: Detected 2611.200 MHz TSC
out 20 19:28:11 skadi kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
out 20 19:28:11 skadi kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
out 20 19:28:11 skadi kernel: last_pfn = 0x48f800 max_arch_pfn = 0x400000000
out 20 19:28:11 skadi kernel: MTRR map: 5 entries (3 fixed + 2 variable; max 23), built from 10 variable MTRRs
out 20 19:28:11 skadi kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
out 20 19:28:11 skadi kernel: last_pfn = 0x61800 max_arch_pfn = 0x400000000
out 20 19:28:11 skadi kernel: esrt: Reserving ESRT space from 0x000000005d546718 to 0x000000005d5467a0.
out 20 19:28:11 skadi kernel: Using GB pages for direct mapping
out 20 19:28:11 skadi kernel: Incomplete global flushes, disabling PCID
out 20 19:28:11 skadi kernel: Secure boot disabled
out 20 19:28:11 skadi kernel: RAMDISK: [mem 0x4aa06000-0x526c9fff]
out 20 19:28:11 skadi kernel: ACPI: Early table checksum verification disabled
out 20 19:28:11 skadi kernel: ACPI: RSDP 0x00000000617FE014 000024 (v02 DELL  )
out 20 19:28:11 skadi kernel: ACPI: XSDT 0x000000006173D188 000124 (v01 DELL   Dell Inc 00000002      01000013)
out 20 19:28:11 skadi kernel: ACPI: FACP 0x00000000617ED000 000114 (v06 DELL   Dell Inc 00000002      01000013)
out 20 19:28:11 skadi kernel: ACPI: DSDT 0x0000000061753000 096C28 (v02 DELL   Dell Inc 00000002      01000013)
out 20 19:28:11 skadi kernel: ACPI: FACS 0x00000000614DB000 000040
I’m not really sure this is the source of your problem, because at a very quick internet search this appeared to be a non-harming issue (but I see “crashing” here…), anyway I think you could try using the kernel boot parameter:
split_lock_detect=off
sorry, where can I change that ?
To test it once, when you are in the grub in the line that you want to use, press button E instead of Enter, go to the end of the line starting with linux and add that parameter, then CTRL+x
If it works, you can easily set this as permanent with the Garuda Boot Options tool in the Kernel parameters field.
LMGTFY :slight_smile:
arch wiki
GRUB
Press e when the menu shows up and add them on the linux line:
linux /boot/vmlinuz-linux root=UUID=0a3407de-014b-458b-b5c1-848e92a327a3 rw quiet splash
Press Ctrl+x to boot with these parameters.
To make the change persistent after reboot, you could manually edit /boot/grub/grub.cfg with the exact line from above, or if using grub-mkconfig:
Edit /etc/default/grub and append your kernel options between the quotes in the GRUB_CMDLINE_LINUX_DEFAULT line:
    GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
And then automatically re-generate the grub.cfg file with:
    # grub-mkconfig -o /boot/grub/grub.cfg
For more information on configuring GRUB, see the GRUB article.
Did not work, maybe this can help ? Is Steam being run with prime-run from this logs or am I mistaken ?
journalctl --since="2023-10-24 17:45:00"
out 24 17:45:34 skadi kwin_x11[1874]: kwin_core: XCB error: 3 (BadWindow), sequence: 839, resource id: 16795514, major code: 129 (SHAPE), minor code: 6 (Input)
out 24 17:45:37 skadi kwin_x11[1874]: kwin_core: XCB error: 3 (BadWindow), sequence: 4037, resource id: 16795734, major code: 129 (SHAPE), minor code: 6 (Input)
out 24 17:45:44 skadi kwin_x11[1874]: kwin_core: XCB error: 3 (BadWindow), sequence: 7926, resource id: 16795972, major code: 129 (SHAPE), minor code: 6 (Input)
out 24 17:49:38 skadi bluetoothd[759]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
out 24 17:49:38 skadi dbus-daemon[760]: [system] Rejected send message, 0 matched rules; type="method_return", sender=":1.49" (uid=1000 pid=2353 comm="/usr/bin/wireplumber") interface=">
out 24 17:49:38 skadi plasmashell[2071]: org.kde.plasma.pulseaudio: No object for name "bluez_output.20_10_21_35_0C_8F.1"
out 24 17:49:46 skadi systemd[1442]: Reached target Bluetooth.
out 24 17:49:47 skadi kernel: input: T7 (AVRCP) as /devices/virtual/input/input30
out 24 17:49:48 skadi systemd-logind[768]: Watching system buttons on /dev/input/event24 (T7 (AVRCP))
out 24 17:49:56 skadi kwin_x11[1874]: kwin_core: XCB error: 152 (BadDamage), sequence: 8425, resource id: 16811514, major code: 143 (DAMAGE), minor code: 3 (Subtract)
out 24 17:49:56 skadi kglobalaccel5[5138]: fsync: up and running.
out 24 17:49:56 skadi kglobalaccel5[5138]: wine: Using setpriority to control niceness in the [-11,11] range
out 24 17:50:01 skadi kglobalaccel5[3081]: /bin/sh\0-c\0prime-run /home/es/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=548430 -- /home/es/.local/share/Steam/ubuntu12_32/stea>
out 24 17:50:01 skadi kglobalaccel5[5225]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:01 skadi kglobalaccel5[5226]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:01 skadi kglobalaccel5[5227]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5227]: ProtonFixes[5227] INFO: Running protonfixes
out 24 17:50:02 skadi kglobalaccel5[5227]: ProtonFixes[5227] INFO: Running checks
out 24 17:50:02 skadi kglobalaccel5[5227]: ProtonFixes[5227] INFO: All checks successful
out 24 17:50:02 skadi kglobalaccel5[5227]: ProtonFixes[5227] INFO: Using global defaults for "Deep Rock Galactic" (548430)
out 24 17:50:02 skadi kglobalaccel5[5227]: ProtonFixes[5227] INFO: No protonfix found for "Deep Rock Galactic" (548430)
out 24 17:50:02 skadi kglobalaccel5[5228]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5229]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5230]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5232]: fsync: up and running.
out 24 17:50:02 skadi kglobalaccel5[5232]: wine: Using setpriority to control niceness in the [-11,11] range
out 24 17:50:02 skadi kglobalaccel5[5234]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5236]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5239]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5248]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5260]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:02 skadi kglobalaccel5[5266]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:05 skadi kglobalaccel5[5292]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:06 skadi kglobalaccel5[5229]: Setting breakpad minidump AppID = 548430
out 24 17:50:06 skadi kglobalaccel5[5229]: Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 24 17:50:07 skadi kglobalaccel5[5322]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:07 skadi kglobalaccel5[5327]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:08 skadi kglobalaccel5[5328]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:08 skadi kglobalaccel5[5329]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:08 skadi kglobalaccel5[5327]: LogPakFile: Display: Found Pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak attempting to mount.
out 24 17:50:08 skadi kglobalaccel5[5327]: LogPakFile: Display: Mounting pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak.
out 24 17:50:08 skadi kglobalaccel5[5327]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: PakFile '../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak' (chunk index ->
out 24 17:50:08 skadi kglobalaccel5[5327]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: pending pak file info (ChunkID:-1 Root:../../../ File:../../../FSD/Content>
out 24 17:50:09 skadi kglobalaccel5[5327]: LogInit: Display: Loading text-based GConfig....
out 24 17:50:09 skadi kglobalaccel5[5327]: Setting breakpad minidump AppID = 548430
out 24 17:50:09 skadi kglobalaccel5[5327]: SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 24 17:50:11 skadi kglobalaccel5[5327]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:50:12 skadi kglobalaccel5[5327]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:50:12 skadi kglobalaccel5[5455]: 10/24 17:50:12 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20230929173826)/tid(5455)
out 24 17:50:12 skadi kglobalaccel5[5455]: 10/24 17:50:12 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(5455)
out 24 17:50:12 skadi kglobalaccel5[5327]: winegstreamer: failed to create decodebin, are 64-bit GStreamer "base" plugins installed?
out 24 17:50:12 skadi kglobalaccel5[5327]: [1024/175012.954:ERROR:network_change_notifier_win.cc(156)] WSALookupServiceBegin failed with: 8
out 24 17:50:13 skadi kglobalaccel5[5499]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:13 skadi kded5[1873]: Registering ":1.74/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.74" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.75/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.75" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.76/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.76" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.77/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.77" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.78/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.78" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.79/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.79" unregistered
out 24 17:50:13 skadi kded5[1873]: Registering ":1.80/StatusNotifierItem" to system tray
out 24 17:50:13 skadi kded5[1873]: Service  ":1.80" unregistered
out 24 17:50:13 skadi kglobalaccel5[5327]: LogMaterial: Error: Loading a material resource None with an invalid ShaderMap!
out 24 17:50:13 skadi kglobalaccel5[5327]: LogMaterial: Error: Tried to access an uncooked shader map ID in a cooked application
out 24 17:50:14 skadi kglobalaccel5[5555]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:14 skadi kglobalaccel5[5556]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:50:15 skadi kglobalaccel5[5327]: [OVRPlugin][ERROR] ovr_Initialize failed: Unable to load LibOVRRT DLL
out 24 17:50:15 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Kickoff.qml:157:34: QML FullRepresentation (parent or ancestor of QQuickLa>
out 24 17:50:15 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Footer.qml:155:5: QML LeaveButtons: Binding loop detected for property "sh>
out 24 17:50:15 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.virtualdesktopbar/contents/ui/applet/Container.qml:38:5: QML MouseArea: Detected anchors on an>
out 24 17:50:15 skadi bluetoothd[759]: /org/bluez/hci0/dev_20_10_21_35_0C_8F/fd1: fd(43) ready
out 24 17:50:15 skadi kglobalaccel5[5327]:  (software\oculussdk\integrations\ovrplugin\main\src\util\compositorcapi.cpp:78)
out 24 17:50:15 skadi kglobalaccel5[5499]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:50:15 skadi kglobalaccel5[5499]: [1024/175015.445:ERROR:mf_helpers.cc(12)] Error in dxva_video_decode_accelerator_win.cc on line 355
out 24 17:50:16 skadi kglobalaccel5[5327]: LogTemp: Error: Modio: TCs not accepted 11074 (The user has not agreed to the mod.io Terms of Use. Please see terms_agreed parameter descripti>
out 24 17:50:19 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:50:19 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:50:23 skadi kded5[1873]: Registering ":1.81/StatusNotifierItem" to system tray
out 24 17:50:23 skadi plasmashell[2071]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
out 24 17:50:23 skadi kglobalaccel5[5327]: winegstreamer: failed to create decodebin, are 64-bit GStreamer "base" plugins installed?
out 24 17:50:23 skadi kglobalaccel5[5327]: LogWmfMedia: Error: Failed to resolve byte stream file://Z:/home/es/.local/share/Steam/steamapps/common/Deep Rock Galactic/FSD/Content/Movies/>
out 24 17:50:23 skadi kded5[1873]: Service  ":1.81" unregistered
out 24 17:50:23 skadi kded5[1873]: Registering ":1.82/StatusNotifierItem" to system tray
out 24 17:50:33 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:50:33 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:50:35 skadi kwin_x11[1874]: OpenGL vendor string:                   Intel
out 24 17:50:35 skadi kwin_x11[1874]: OpenGL renderer string:                 Mesa Intel(R) Graphics (RPL-S)
out 24 17:50:35 skadi kwin_x11[1874]: OpenGL version string:                  4.6 (Compatibility Profile) Mesa 23.2.1-arch1.2
out 24 17:50:35 skadi kwin_x11[1874]: OpenGL shading language version string: 4.60
out 24 17:50:35 skadi kwin_x11[1874]: Driver:                                 Intel
out 24 17:50:35 skadi kwin_x11[1874]: GPU class:                              Unknown
out 24 17:50:35 skadi kwin_x11[1874]: OpenGL version:                         4.6
out 24 17:50:35 skadi kwin_x11[1874]: GLSL version:                           4.60
out 24 17:50:35 skadi kwin_x11[1874]: Mesa version:                           23.2.1
out 24 17:50:35 skadi kwin_x11[1874]: X server version:                       1.21.1
out 24 17:50:35 skadi kwin_x11[1874]: Linux kernel version:                   6.5.7
out 24 17:50:35 skadi kwin_x11[1874]: Requires strict binding:                yes
out 24 17:50:35 skadi kwin_x11[1874]: GLSL shaders:                           yes
out 24 17:50:35 skadi kwin_x11[1874]: Texture NPOT support:                   yes
out 24 17:50:35 skadi kwin_x11[1874]: Virtual Machine:                        no
out 24 17:50:35 skadi kwin_x11[1874]: WobblyWindowsConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: BlurConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: ZoomConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: WindowViewConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: SlidingPopupsConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: SlideConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: OverviewConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: MagicLampConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: KscreenConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kwin_x11[1874]: DesktopGridConfig::instance called after the first use - ignoring
out 24 17:50:35 skadi kded5[1873]: Service  ":1.82" unregistered
out 24 17:50:35 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Footer.qml:155:5: QML LeaveButtons: Binding loop detected for property "sh>
out 24 17:50:35 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.virtualdesktopbar/contents/ui/applet/Container.qml:38:5: QML MouseArea: Detected anchors on an>
out 24 17:50:37 skadi kglobalaccel5[5232]: pid 5232 != 5230, skipping destruction (fork without exec?)
out 24 17:50:37 skadi kernel: wineserver[5232]: segfault at 0 ip 00007fe9028ad6f4 sp 00007ffe75e33180 error 4 in libnvidia-glvkspirv.so.535.113.01[7fe901800000+2038000] likely on CPU 8 >
out 24 17:50:37 skadi kernel: Code: 00 00 00 00 00 90 53 48 8b 1f 48 89 df e8 74 38 0d ff 48 89 df 5b e9 2b 39 0d ff 66 2e 0f 1f 84 00 00 00 00 00 90 48 83 ec 08 <48> 8b 3f e8 94 3a 0d >
out 24 17:50:37 skadi systemd[1]: Created slice Slice /system/systemd-coredump.
out 24 17:50:37 skadi systemd[1]: Started Process Core Dump (PID 5646/UID 0).
out 24 17:50:37 skadi systemd-coredump[5647]: [🡕] Process 5232 (wineserver) of user 1000 dumped core.
Stack trace of thread 5232:
#0  0x00007fe9028ad6f4 n/a (libnvidia-glvkspirv.so.535.113.01 + 0x10ad6f4)
#1  0x00007fe9028ac7d2 n/a (libnvidia-glvkspirv.so.535.113.01 + 0x10ac7d2)
#2  0x00007fe90284ef66 n/a (libnvidia-glvkspirv.so.535.113.01 + 0x104ef66)
#3  0x00007fe902b649ef n/a (libnvidia-glvkspirv.so.535.113.01 + 0x13649ef)
#4  0x00007fe9057481e2 n/a (libnvidia-glcore.so.535.113.01 + 0x15481e2)
#5  0x00007fe907369ba1 n/a (libGLX_nvidia.so.0 + 0x83ba1)
#6  0x00007fe907369fbd n/a (libGLX_nvidia.so.0 + 0x83fbd)
#7  0x00007fe90736a194 n/a (libGLX_nvidia.so.0 + 0x84194)
#8  0x00007fe90571510e n/a (libnvidia-glcore.so.535.113.01 + 0x151510e)
#9  0x00007fe90733775b n/a (libGLX_nvidia.so.0 + 0x5175b)
#10 0x00007fe907337f3f n/a (libGLX_nvidia.so.0 + 0x51f3f)
#11 0x00007fe9073c6009 n/a (libGLX_nvidia.so.0 + 0xe0009)
ELF object binary architecture: AMD x86-64
continuing with the logs, sorry about dumping so much logs
out 24 17:50:37 skadi systemd[1]: systemd-coredump@0-5646-0.service: Deactivated successfully.
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface STEAMAPPS_INTERFACE_VERSION008 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION014 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface STEAMUSERSTATS_INTERFACE_VERSION012 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamController008 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamFriends017 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamInput002 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamMatchMaking009 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamMatchMakingServers002 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamNetworking006 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamNetworkingSockets009 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamNetworkingUtils003 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamUser021 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamUser021 / User
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 created interface SteamUtils010 /
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientNetworkingUtilsSerialized::GotLocationString : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientNetworkingSocketsSerialized::GetSTUNServer : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientNetworkingSocketsSerialized::GetCachedRelayTicketCount : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientNetworkingSocketsSerialized::GetCertAsync : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientHTTP::ReleaseHTTPRequest : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientHTTP::GetHTTPResponseBodyData : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientHTTP::SendHTTPRequest : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientHTTP::SetHTTPRequestHeaderValue : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientHTTP::CreateHTTPRequest : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::UploadLeaderboardScore : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetDownloadedLeaderboardEntry : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::DownloadLeaderboardEntriesForUsers : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetLeaderboardDisplayType : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetLeaderboardSortMethod : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetLeaderboardEntryCount : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::FindLeaderboard : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetUserStat : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::RequestUserStats : 7
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetAchievementDisplayAttribute : 207
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetAchievement : 69
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::StoreStats : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::SetStat : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::GetStat : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUserStats::RequestCurrentStats : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientAppManager::GetActiveBeta : 65
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientAppManager::IsAppDlcInstalled : 24
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientAppManager::GetAppContentInfo : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::GetLobbyOwner : 4
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::SetLobbyJoinable : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::SetLobbyType : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::GetLobbyMemberLimit : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::SetLobbyMemberLimit : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::SetLobbyData : 84
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::GetNumLobbyMembers : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientMatchmaking::CreateLobby : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::RecordSteamInterfaceCreation : 17
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::GetAPICallResult : 21
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::IsAPICallCompleted : 160
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::GetAppID : 21
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::GetIPCountry : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUtils::GetServerRealTime : 4
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::GetFriendPersonaName_Public : 4
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::SetRichPresence : 6
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::SetInGameVoiceSpeaking : 4
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::IsUserInSource : 5
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::GetFriendCount : 3
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientFriends::GetPersonaName : 5
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::BIsSubscribedApp : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::GetEncryptedAppTicket : 2
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::RequestEncryptedAppTicket : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::GetAuthSessionTicket : 1
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::GetSteamID : 56
out 24 17:50:37 skadi kglobalaccel5[3081]: Game 548430 method call count for IClientUser::BLoggedOn : 12
out 24 17:50:37 skadi kglobalaccel5[3081]: Uploaded AppInterfaceStats to Steam
out 24 17:50:37 skadi krunner[4750]: kf.sonnet.core: No language dictionaries for the language: "en_US"
out 24 17:50:38 skadi gameoverlayui[5455]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
out 24 17:50:38 skadi krunner[4750]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ToolTip.qml:57:9: QML Label: Binding loop detected for property "verticalAlignment"
out 24 17:50:39 skadi systemd[1442]: Started System Settings - System Settings.
out 24 17:50:40 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
out 24 17:50:40 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_AllowKDEAppsToRememberWindowPositions" was found but there is no setting named "AllowKDEAppsToRemember>
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ShadeHover" was found but there is no setting named "ShadeHover"
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ShadeHoverInterval" was found but there is no setting named "ShadeHoverInterval"
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_Placement" was found but there is no setting named "Placement"
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_HideUtilityWindowsForInactive" was found but there is no setting named "HideUtilityWindowsForInactive"
out 24 17:50:43 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ActivationDesktopPolicy" was found but there is no setting named "ActivationDesktopPolicy"
out 24 17:50:44 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:50:46 skadi systemsettings[5663]: kf.coreaddons: "Could not load plugin from kcm_bismuth: The shared library was not found."
out 24 17:50:46 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:50:46 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
out 24 17:50:46 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:50:48 skadi systemsettings[5663]: Invalid window uuid.
out 24 17:50:48 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:50:48 skadi systemsettings[5663]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
out 24 17:50:48 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:50:48 skadi kglobalaccel5[3081]: reaping pid: 5455 -- gameoverlayui
out 24 17:50:59 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:50:59 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:51:02 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implic>
out 24 17:51:02 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Dialog.qml:345: TypeError: Cannot read property 'height' of null
out 24 17:51:02 skadi systemsettings[5663]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
out 24 17:51:02 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "height"
out 24 17:51:17 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:51:17 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:52:16 skadi systemsettings[5663]: QQuickVelocityCalculator: a call to stopMeasuring() must be preceded by a call to startMeasuring()
out 24 17:52:45 skadi kwin_x11[1874]: kwin_core: XCB error: 3 (BadWindow), sequence: 56573, resource id: 16814175, major code: 129 (SHAPE), minor code: 6 (Input)
out 24 17:52:51 skadi systemsettings[5663]: kf.coreaddons: "Could not load plugin from kcm_bismuth: The shared library was not found."
out 24 17:52:51 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:52:51 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
out 24 17:52:51 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:19 skadi systemsettings[5663]: Invalid window uuid.
out 24 17:53:19 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:53:19 skadi systemsettings[5663]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
out 24 17:53:19 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:20 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:53:20 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_AllowKDEAppsToRememberWindowPositions" was found but there is no setting named "AllowKDEAppsToRemember>
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ShadeHover" was found but there is no setting named "ShadeHover"
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ShadeHoverInterval" was found but there is no setting named "ShadeHoverInterval"
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_Placement" was found but there is no setting named "Placement"
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_HideUtilityWindowsForInactive" was found but there is no setting named "HideUtilityWindowsForInactive"
out 24 17:53:21 skadi systemsettings[5663]: kf.configwidgets: A widget named "kcfg_ActivationDesktopPolicy" was found but there is no setting named "ActivationDesktopPolicy"
out 24 17:53:21 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:22 skadi systemsettings[5663]: kf.coreaddons: "Could not load plugin from kcm_bismuth: The shared library was not found."
out 24 17:53:22 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:53:22 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "implicitHeight"
out 24 17:53:22 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:26 skadi systemsettings[5663]: Invalid window uuid.
out 24 17:53:26 skadi systemsettings[5663]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:53:26 skadi systemsettings[5663]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
out 24 17:53:26 skadi systemsettings[5663]: qml: The item SubCategoryPage_QMLTYPE_114(0x563b1e818790) is already in the PageRow
out 24 17:53:29 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implic>
out 24 17:53:29 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/Dialog.qml:345: TypeError: Cannot read property 'height' of null
out 24 17:53:29 skadi systemsettings[5663]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
out 24 17:53:29 skadi systemsettings[5663]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:603:17: QML ColumnLayout: Binding loop detected for property "height"
out 24 17:54:42 skadi krunner[4750]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
out 24 17:54:42 skadi krunner[4750]: kf.sonnet.core: No language dictionaries for the language: "en_US"
out 24 17:54:45 skadi systemsettings[5663]: file:///usr/share/kpackage/kcms/kcm_kwinrules/contents/ui/OptionsComboBox.qml:50: TypeError: Cannot read property 'width' of null
out 24 17:54:57 skadi kwin_x11[1874]: OpenGL vendor string:                   Intel
out 24 17:54:57 skadi kwin_x11[1874]: OpenGL renderer string:                 Mesa Intel(R) Graphics (RPL-S)
out 24 17:54:57 skadi kwin_x11[1874]: OpenGL version string:                  4.6 (Compatibility Profile) Mesa 23.2.1-arch1.2
out 24 17:54:57 skadi kwin_x11[1874]: OpenGL shading language version string: 4.60
out 24 17:54:57 skadi kwin_x11[1874]: Driver:                                 Intel
out 24 17:54:57 skadi kwin_x11[1874]: GPU class:                              Unknown
out 24 17:54:57 skadi kwin_x11[1874]: OpenGL version:                         4.6
out 24 17:54:57 skadi kwin_x11[1874]: GLSL version:                           4.60
out 24 17:54:57 skadi kwin_x11[1874]: Mesa version:                           23.2.1
out 24 17:54:57 skadi kwin_x11[1874]: X server version:                       1.21.1
out 24 17:54:57 skadi kwin_x11[1874]: Linux kernel version:                   6.5.7
out 24 17:54:57 skadi kwin_x11[1874]: Requires strict binding:                yes
out 24 17:54:57 skadi kwin_x11[1874]: GLSL shaders:                           yes
out 24 17:54:57 skadi kwin_x11[1874]: Texture NPOT support:                   yes
out 24 17:54:57 skadi kwin_x11[1874]: Virtual Machine:                        no
out 24 17:54:57 skadi kwin_x11[1874]: WobblyWindowsConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: BlurConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: ZoomConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: WindowViewConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: SlidingPopupsConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: SlideConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: OverviewConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: MagicLampConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: KscreenConfig::instance called after the first use - ignoring
out 24 17:54:57 skadi kwin_x11[1874]: DesktopGridConfig::instance called after the first use - ignoring
out 24 17:54:58 skadi krunner[4750]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
out 24 17:54:58 skadi krunner[4750]: kf.sonnet.core: No language dictionaries for the language: "en_US"
out 24 17:54:58 skadi krunner[4750]: trying to show an empty dialog
out 24 17:54:59 skadi krunner[4750]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
out 24 17:54:59 skadi krunner[4750]: kf.sonnet.core: No language dictionaries for the language: "en_US"
out 24 17:55:00 skadi krunner[4750]: QCommandLineParser: argument list cannot be empty, it should contain at least the executable name
out 24 17:55:02 skadi systemd[1442]: app-systemsettings-79704265c49f4d6eba024f8e77d842d3.scope: Consumed 11.926s CPU time.
out 24 17:55:06 skadi kwin_x11[1874]: kwin_core: XCB error: 3 (BadWindow), sequence: 27673, resource id: 16816166, major code: 129 (SHAPE), minor code: 6 (Input)
out 24 17:55:06 skadi kwin_x11[1874]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
out 24 17:55:06 skadi kwin_x11[1874]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
out 24 17:55:13 skadi kwin_x11[1874]: kwin_core: XCB error: 152 (BadDamage), sequence: 33075, resource id: 16816490, major code: 143 (DAMAGE), minor code: 3 (Subtract)
out 24 17:55:13 skadi kglobalaccel5[5815]: fsync: up and running.
out 24 17:55:13 skadi kglobalaccel5[5815]: wine: Using setpriority to control niceness in the [-11,11] range
out 24 17:55:19 skadi kglobalaccel5[3081]: /bin/sh\0-c\0prime-run /home/es/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=548430 -- /home/es/.local/share/Steam/ubuntu12_32/stea>
out 24 17:55:19 skadi kglobalaccel5[5905]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5906]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5907]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5907]: ProtonFixes[5907] INFO: Running protonfixes
out 24 17:55:19 skadi kglobalaccel5[5907]: ProtonFixes[5907] INFO: Running checks
out 24 17:55:19 skadi kglobalaccel5[5907]: ProtonFixes[5907] INFO: All checks successful
out 24 17:55:19 skadi kglobalaccel5[5907]: ProtonFixes[5907] INFO: Using global defaults for "Deep Rock Galactic" (548430)
out 24 17:55:19 skadi kglobalaccel5[5907]: ProtonFixes[5907] INFO: No protonfix found for "Deep Rock Galactic" (548430)
out 24 17:55:19 skadi kglobalaccel5[5908]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5909]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5910]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5911]: fsync: up and running.
out 24 17:55:19 skadi kglobalaccel5[5911]: wine: Using setpriority to control niceness in the [-11,11] range
out 24 17:55:19 skadi kglobalaccel5[5914]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5916]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5919]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5928]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5940]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:19 skadi kglobalaccel5[5946]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
this is the end, until “power key pressed”, again, sorry about the dump of logs and thank you for your help
out 24 17:55:20 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:55:20 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:55:23 skadi kglobalaccel5[5970]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:24 skadi kglobalaccel5[5909]: Setting breakpad minidump AppID = 548430
out 24 17:55:24 skadi kglobalaccel5[5909]: Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 24 17:55:24 skadi kglobalaccel5[5998]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:25 skadi kglobalaccel5[6004]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:25 skadi kglobalaccel5[6005]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:25 skadi kglobalaccel5[6006]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:25 skadi kglobalaccel5[6004]: LogPakFile: Display: Found Pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak attempting to mount.
out 24 17:55:25 skadi kglobalaccel5[6004]: LogPakFile: Display: Mounting pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak.
out 24 17:55:25 skadi kglobalaccel5[6004]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: PakFile '../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak' (chunk index ->
out 24 17:55:25 skadi kglobalaccel5[6004]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: pending pak file info (ChunkID:-1 Root:../../../ File:../../../FSD/Content>
out 24 17:55:26 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:55:26 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:55:26 skadi kglobalaccel5[6004]: LogInit: Display: Loading text-based GConfig....
out 24 17:55:26 skadi kglobalaccel5[6004]: Setting breakpad minidump AppID = 548430
out 24 17:55:26 skadi kglobalaccel5[6004]: SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 24 17:55:28 skadi kglobalaccel5[6004]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:55:29 skadi kglobalaccel5[6004]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:55:29 skadi kglobalaccel5[6132]: 10/24 17:55:29 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20230929173826)/tid(6132)
out 24 17:55:29 skadi kglobalaccel5[6132]: 10/24 17:55:29 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(6132)
out 24 17:55:29 skadi kglobalaccel5[6004]: winegstreamer: failed to create decodebin, are 64-bit GStreamer "base" plugins installed?
out 24 17:55:29 skadi kglobalaccel5[6004]: [1024/175529.878:ERROR:network_change_notifier_win.cc(156)] WSALookupServiceBegin failed with: 8
out 24 17:55:29 skadi kglobalaccel5[6176]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:29 skadi kded5[1873]: Registering ":1.86/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.86" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.87/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.87" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.88/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.88" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.89/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.89" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.90/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.90" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.91/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.91" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.92/StatusNotifierItem" to system tray
out 24 17:55:29 skadi kded5[1873]: Service  ":1.92" unregistered
out 24 17:55:29 skadi kded5[1873]: Registering ":1.93/StatusNotifierItem" to system tray
out 24 17:55:30 skadi kded5[1873]: Service  ":1.93" unregistered
out 24 17:55:30 skadi kglobalaccel5[6004]: LogStreaming: Error: Couldn't find file for package /Engine/Transient requested by async loading code. NameToLoad: /Engine/Transient
out 24 17:55:30 skadi kglobalaccel5[6004]: LogStreaming: Error: This will hitch streaming because it ends up searching the disk instead of finding the file in the pak file.
out 24 17:55:30 skadi kglobalaccel5[6004]: LogStreaming: Error: Found 0 dependent packages...
out 24 17:55:30 skadi kglobalaccel5[6004]: LogMaterial: Error: Loading a material resource None with an invalid ShaderMap!
out 24 17:55:30 skadi kglobalaccel5[6004]: LogMaterial: Error: Tried to access an uncooked shader map ID in a cooked application
out 24 17:55:30 skadi kglobalaccel5[6227]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:31 skadi kglobalaccel5[6228]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 24 17:55:31 skadi kglobalaccel5[6004]: [OVRPlugin][ERROR] ovr_Initialize failed: Unable to load LibOVRRT DLL
out 24 17:55:31 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Footer.qml:155:5: QML LeaveButtons: Binding loop detected for property "sh>
out 24 17:55:31 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.virtualdesktopbar/contents/ui/applet/Container.qml:38:5: QML MouseArea: Detected anchors on an>
out 24 17:55:32 skadi plasmashell[2071]: file:///usr/share/plasma/plasmoids/org.kde.plasma.virtualdesktopbar/contents/ui/applet/Container.qml:38:5: QML MouseArea: Detected anchors on an>
out 24 17:55:32 skadi kglobalaccel5[6004]:  (software\oculussdk\integrations\ovrplugin\main\src\util\compositorcapi.cpp:78)
out 24 17:55:32 skadi kglobalaccel5[6176]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 24 17:55:32 skadi kglobalaccel5[6176]: [1024/175532.385:ERROR:mf_helpers.cc(12)] Error in dxva_video_decode_accelerator_win.cc on line 355
out 24 17:55:33 skadi kglobalaccel5[6004]: LogTemp: Error: Modio: TCs not accepted 11074 (The user has not agreed to the mod.io Terms of Use. Please see terms_agreed parameter descripti>
out 24 17:55:33 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:55:33 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 17:55:39 skadi kded5[1873]: Registering ":1.94/StatusNotifierItem" to system tray
out 24 17:55:39 skadi plasmashell[2071]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
out 24 17:55:39 skadi kglobalaccel5[6004]: winegstreamer: failed to create decodebin, are 64-bit GStreamer "base" plugins installed?
out 24 17:55:39 skadi kglobalaccel5[6004]: LogWmfMedia: Error: Failed to resolve byte stream file://Z:/home/es/.local/share/Steam/steamapps/common/Deep Rock Galactic/FSD/Content/Movies/>
out 24 17:55:39 skadi kded5[1873]: Service  ":1.94" unregistered
out 24 17:55:39 skadi kded5[1873]: Registering ":1.95/StatusNotifierItem" to system tray
out 24 17:55:59 skadi kernel: IPv4: martian source 192.168.3.255 from 192.168.3.58, on dev wlp0s20f3
out 24 17:55:59 skadi kernel: ll header: 00000000: 68 7a 64 d5 3f 54 04 bf 1b 68 ab d0 08 00
out 24 18:01:32 skadi systemd-logind[768]: Power key pressed short.
For long logs you can use https://bin.garudalinux.org/
I got a shorter and fresh one, if anybody could help I woud greatly appreciate it
out 25 11:43:55 skadi kglobalaccel5[4267]: /bin/sh\0-c\0prime-run /home/es/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=548430 -- /home/es/.local/share/Steam/ubuntu12_32/stea>
out 25 11:43:55 skadi kglobalaccel5[5407]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5408]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5409]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5409]: ProtonFixes[5409] INFO: Running protonfixes
out 25 11:43:55 skadi kglobalaccel5[5409]: ProtonFixes[5409] INFO: Running checks
out 25 11:43:55 skadi kglobalaccel5[5409]: ProtonFixes[5409] INFO: All checks successful
out 25 11:43:55 skadi kglobalaccel5[5409]: ProtonFixes[5409] INFO: Using global defaults for "Deep Rock Galactic" (548430)
out 25 11:43:55 skadi kglobalaccel5[5409]: ProtonFixes[5409] INFO: No protonfix found for "Deep Rock Galactic" (548430)
out 25 11:43:55 skadi kglobalaccel5[5410]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5411]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5413]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5414]: fsync: up and running.
out 25 11:43:55 skadi kglobalaccel5[5414]: wine: Using setpriority to control niceness in the [-11,11] range
out 25 11:43:55 skadi kglobalaccel5[5416]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5418]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5421]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:55 skadi kglobalaccel5[5431]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:56 skadi kglobalaccel5[5443]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:56 skadi kglobalaccel5[5449]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:43:59 skadi kglobalaccel5[5474]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:00 skadi kglobalaccel5[5411]: Setting breakpad minidump AppID = 548430
out 25 11:44:00 skadi kglobalaccel5[5411]: Steam_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 25 11:44:01 skadi kglobalaccel5[5502]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:01 skadi kglobalaccel5[5508]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:01 skadi kglobalaccel5[5509]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:01 skadi kglobalaccel5[5510]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:01 skadi kglobalaccel5[5508]: LogPakFile: Display: Found Pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak attempting to mount.
out 25 11:44:01 skadi kglobalaccel5[5508]: LogPakFile: Display: Mounting pak file ../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak.
out 25 11:44:01 skadi kglobalaccel5[5508]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: PakFile '../../../FSD/Content/Paks/FSD-WindowsNoEditor.pak' (chunk index ->
out 25 11:44:01 skadi kglobalaccel5[5508]: LogShaderLibrary: Display: ShaderCodeLibraryPakFileMountedCallback: pending pak file info (ChunkID:-1 Root:../../../ File:../../../FSD/Content>
out 25 11:44:02 skadi kglobalaccel5[5508]: LogInit: Display: Loading text-based GConfig....
out 25 11:44:02 skadi kglobalaccel5[5508]: Setting breakpad minidump AppID = 548430
out 25 11:44:02 skadi kglobalaccel5[5508]: SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561198092798742 [API loaded no]
out 25 11:44:04 skadi kglobalaccel5[5508]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 25 11:44:04 skadi kwin_x11[1915]: org.kde.bismuth: Client added: KWin::X11Window(0x55e8a1d4ecb0)
out 25 11:44:04 skadi kwin_x11[1915]: org.kde.bismuth: onWindowAdded,[object Object]
out 25 11:44:04 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:44:04 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:44:04 skadi kwin_x11[1915]: org.kde.bismuth: Client is ok, can manage. Bind events now...
out 25 11:44:05 skadi kglobalaccel5[5508]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: Client added: KWin::X11Window(0x55e8a1d9a2a0)
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: onWindowAdded,[object Object]
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: Client is ok, can manage. Bind events now...
out 25 11:44:05 skadi kwin_x11[1915]: org.kde.bismuth: [Controller#onWindowRemoved] Window removed: Window(KWin(7800001.steam_app_548430))
out 25 11:42:00 skadi kglobalaccel5[2621]: [2621:2621:1025/114200.163941:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_xk3Mz9>
out 25 11:42:00 skadi kglobalaccel5[2621]: [2621:2621:1025/114200.169035:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_xk3Mz9>
out 25 11:42:04 skadi kglobalaccel5[2621]: [2621:2621:1025/114204.468527:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_ggJ7gd>
out 25 11:42:04 skadi kglobalaccel5[2621]: [2621:2621:1025/114204.468823:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_ggJ7gd>
out 25 11:42:10 skadi kglobalaccel5[2621]: [2621:2621:1025/114210.291252:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:10 skadi kglobalaccel5[2621]: [2621:2621:1025/114210.307376:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:20 skadi kglobalaccel5[2621]: [2621:2621:1025/114220.401277:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_iFdzDS>
out 25 11:42:20 skadi kglobalaccel5[2621]: [2621:2621:1025/114220.401517:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_iFdzDS>
out 25 11:42:23 skadi kglobalaccel5[2621]: [2621:2621:1025/114223.699075:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:24 skadi kglobalaccel5[2621]: [2621:2621:1025/114224.606460:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:33 skadi kglobalaccel5[2621]: [2621:2621:1025/114233.512144:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:33 skadi kglobalaccel5[2621]: [2621:2621:1025/114233.512391:ERROR:CONSOLE(14)] "Failed to handle media duration metadata: missing publisher key for media key youtube_p-uTdq>
out 25 11:42:37 skadi kwin_x11[1915]: org.kde.bismuth: Client added: KWin::X11Window(0x55e8a1d35620)
out 25 11:42:37 skadi kwin_x11[1915]: org.kde.bismuth: onWindowAdded,[object Object]
out 25 11:42:37 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:42:37 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:42:37 skadi kwin_x11[1915]: org.kde.bismuth: Window becomes unmanaged and gets removed :( The client was KWin::X11Window(0x55e8a1d35620)
out 25 11:43:39 skadi kwin_x11[1915]: org.kde.bismuth: onCurrentSurfaceChanged,[object Object]
out 25 11:43:39 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:43:39 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:43:47 skadi kwin_x11[1915]: org.kde.bismuth: Client added: KWin::X11Window(0x55e8a1e24d70)
out 25 11:43:47 skadi kwin_x11[1915]: org.kde.bismuth: onWindowAdded,[object Object]
out 25 11:43:47 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:43:47 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:43:47 skadi kwin_x11[1915]: org.kde.bismuth: Client is ok, can manage. Bind events now...
out 25 11:43:49 skadi kwin_x11[1915]: org.kde.bismuth: [Controller#onWindowRemoved] Window removed: Window(KWin(520007b.steam))
out 25 11:43:49 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:43:49 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:43:49 skadi kwin_x11[1915]: kwin_core: XCB error: 152 (BadDamage), sequence: 65013, resource id: 16800458, major code: 143 (DAMAGE), minor code: 3 (Subtract)
out 25 11:43:49 skadi kwin_x11[1915]: kwin_core: XCB error: 3 (BadWindow), sequence: 65042, resource id: 77594718, major code: 129 (SHAPE), minor code: 6 (Input)
out 25 11:43:49 skadi kglobalaccel5[5314]: fsync: up and running.
out 25 11:43:49 skadi kglobalaccel5[5314]: wine: Using setpriority to control niceness in the [-11,11] range
out 25 11:43:51 skadi kwin_x11[1915]: org.kde.bismuth: onWindowChanged,[object Object]
out 25 11:43:51 skadi kwin_x11[1915]: org.kde.bismuth: arrange
out 25 11:43:51 skadi kwin_x11[1915]: org.kde.bismuth: arrangeScreen/finished,[object Object]
out 25 11:44:05 skadi kglobalaccel5[5636]: 10/25 11:44:05 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20230929173826)/tid(5636)
out 25 11:44:05 skadi kglobalaccel5[5636]: 10/25 11:44:05 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(5636)
out 25 11:44:06 skadi kglobalaccel5[5508]: winegstreamer: failed to create decodebin, are 64-bit GStreamer "base" plugins installed?
out 25 11:44:06 skadi kglobalaccel5[5508]: [1025/114406.367:ERROR:network_change_notifier_win.cc(156)] WSALookupServiceBegin failed with: 8
out 25 11:44:06 skadi kglobalaccel5[5680]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:06 skadi kded5[1914]: Registering ":1.80/StatusNotifierItem" to system tray
out 25 11:44:06 skadi kded5[1914]: Service  ":1.80" unregistered
out 25 11:44:06 skadi kglobalaccel5[5508]: LogStreaming: Error: Couldn't find file for package /Engine/Transient requested by async loading code. NameToLoad: /Engine/Transient
out 25 11:44:06 skadi kglobalaccel5[5508]: LogStreaming: Error: This will hitch streaming because it ends up searching the disk instead of finding the file in the pak file.
out 25 11:44:06 skadi kglobalaccel5[5508]: LogStreaming: Error: Found 0 dependent packages...
out 25 11:44:07 skadi kglobalaccel5[5508]: LogMaterial: Error: Loading a material resource None with an invalid ShaderMap!
out 25 11:44:07 skadi kglobalaccel5[5508]: LogMaterial: Error: Tried to access an uncooked shader map ID in a cooked application
out 25 11:44:07 skadi kglobalaccel5[5732]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:07 skadi kglobalaccel5[5733]: ERROR: ld.so: object '/home/es/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: EL>
out 25 11:44:08 skadi kglobalaccel5[5508]: [OVRPlugin][ERROR] ovr_Initialize failed: Unable to load LibOVRRT DLL
out 25 11:44:08 skadi plasmashell[2156]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Kickoff.qml:157:34: QML FullRepresentation (parent or ancestor of QQuickLa>
out 25 11:44:08 skadi plasmashell[2156]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/Footer.qml:155:5: QML LeaveButtons: Binding loop detected for property "sh>
out 25 11:44:08 skadi plasmashell[2156]: file:///usr/share/plasma/plasmoids/org.kde.plasma.virtualdesktopbar/contents/ui/applet/Container.qml:38:5: QML MouseArea: Detected anchors on an>
out 25 11:44:08 skadi kglobalaccel5[5508]:  (software\oculussdk\integrations\ovrplugin\main\src\util\compositorcapi.cpp:78)
out 25 11:44:08 skadi kglobalaccel5[5680]: Fossilize INFO: Overriding serialization path: "/home/es/.local/share/Steam/steamapps/shadercache/548430/fozpipelinesv6/steamapprun_pipeline_c>
out 25 11:44:08 skadi kglobalaccel5[5680]: [1025/114408.967:ERROR:mf_helpers.cc(12)] Error in dxva_video_decode_accelerator_win.cc on line 355
out 25 11:44:10 skadi kglobalaccel5[5508]: LogTemp: Error: Modio: TCs not accepted 11074 (The user has not agreed to the mod.io Terms of Use. Please see terms_agreed parameter descripti>
out 25 11:44:50 skadi systemd-logind[772]: Power key pressed short.
