So many times we talked about this… Garuda tried add nvidia-tkg into the chaotic-aur, but results was terrible, me too faced issues, BUT if you install nvidia-all manually it’s much better!
nvidia-all can bring significantly more performance!
There is a guide how to install nvidia-all
git clone https://github.com/Frogging-Family/nvidia-all.gitcd nvidia-allmakepkg -si
Installer will run, you will see this:
.---.` `.---. `/syhhhyso- -osyhhhys/` .syNMdhNNhss/``.---.``/sshNNhdMNys. +sdMh.`+MNsssssssssssssssNM+`.hMds+ :syNNdhNNhssssssssssssssshNNhdNNys: /ssyhhhysssssssssssssssssyhhhyss/ .ossssssssssssssssssssssssssssso. :sssssssssssssssssssssssssssssssss: /sssssssssssssssssssssssssssssssssss/ :sssssssssssssoosssssssoosssssssssssss: osssssssssssssoosssssssoossssssssssssso osssssssssssyyyyhhhhhhhyyyyssssssssssso /yyyyyyhhdmmmmNNNNNNNNNNNmmmmdhhyyyyyy/ smmmNNNNNNNNNNNNNNNNNNNNNNNNNNNNNmmms /dNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNd/ `:sdNNNNNNNNNNNNNNNNNNNNNNNNNds:` `-+shdNNNNNNNNNNNNNNNdhs+-` `.-:///////:-.` What driver version do you want? 1.Vulkan dev: 455.50.14 2.465 series: 465.27 3.460 series: 460.73.01 4.455 series: 455.45.01 5.450 series: 450.119.03 6.440 series: 440.100 (kernel 5.8 or lower) 7.435 series: 435.21 (kernel 5.6 or lower) 8.430 series: 430.64 (kernel 5.5 or lower) 9.418 series: 418.113 (kernel 5.5 or lower) 10.415 series: 415.27 (kernel 5.4 or lower) 11.410 series: 410.104 (kernel 5.5 or lower) 12.396 series: 396.54 (kernel 5.3 or lower, 5.1 or lower recommended) 13.Custom version (396.xx series or higher) choice[1-13?]: 2Build the dkms package or the regular one?
1.dkms (recommended)
2.regular
choice[1-2?]: 1
- I used latest drivers.
- I used dkms (Why? If you have dkms, you can switch kernels).
Hit enter, just install everything what’s installer want it.
When installation is completed, use following commands.
sudo mkinitcpio -P
sudo grub-mkconfig -o /boot/grub/grub.cfg
How to update nvidia-all? Just repeat process again. (Yes, it mean delete nvidia-all folder, use git clone command and everything again)
