Hi,
So I have 16GB of RAM on my system running AMD 3 2200G with in built graphics and allocated vRAM at 500mb.
The issue is.. when I reach around 10gigs of RAM usage, my system slows down to a crawl..
I couldn't understand this at first.. I was checking the RAM usage using the system monitor GUI apps.
Then I read some online content and found I should be using "free -h" command.
Here's the result I got:
And Free -h
╭─dibakarg@linuxpc in ~ took 3s
╰─λ free -h
total used free shared buff/cache available
Mem: 15Gi 7.1Gi 1.4Gi 389Mi 6.7Gi 7.2Gi
Swap: 30Gi 277Mi 29Gi
As you can see.. even though it shows the total is 15GB and I have used 7.1GB.. I only have 1.4G left..
Now, this makes perfect sense why the system starts to lag when I reach 10GB of RAM usage.
But why can I just use 10GB of RAM?
Where is the rest 5GB or so??
Other info you might be interested in:
inxi -Fxxxza
╰─λ inxi -Fxxxza
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ffa2da0a-139d-47f4-9350-125eeef36842
systemd.unified_cgroup_hierarchy=1 resume=UUID=d3f1d17d-ce5e-4b8c-a9d8-3eef38cddc13 loglevel=3
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0 Distro: Garuda Linux
Machine: Type: Desktop System: Gigabyte product: A320M-S2H v: N/A serial: <filter>
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <filter> UEFI-[Legacy]: American Megatrends
v: F22 date: 03/15/2018
CPU: Info: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP arch: Zen
family: 17 (23) model-id: 11 (17) stepping: 0 microcode: 8101007 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 27947
Speed: 2440 MHz min/max: 1600/3500 MHz boost: enabled Core speeds (MHz): 1: 2440 2: 2196
3: 2736 4: 1871
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Gigabyte
driver: amdgpu v: kernel bus-ID: 07:00.0 chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: gnome-shell driver: loaded: amdgpu,ati
unloaded: modesetting alternate: fbdev,vesa display-ID: :1 screens: 1
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.12.15-zen1-1-zen LLVM 12.0.0)
v: 4.6 Mesa 21.1.4 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media Blue Snowball type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-3:3 chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 698.65 GiB used: 179.23 GiB (25.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: KC48 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 3B6Q scheme: GPT
Partition: ID-1: / raw-size: 450.72 GiB size: 450.72 GiB (100.00%) used: 179.23 GiB (39.8%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 450.72 GiB size: 450.72 GiB (100.00%) used: 179.23 GiB (39.8%) fs: btrfs
ID-3: /var/log raw-size: 450.72 GiB size: 450.72 GiB (100.00%) used: 179.23 GiB (39.8%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 450.72 GiB size: 450.72 GiB (100.00%) used: 179.23 GiB (39.8%)
ID-1: swap-1 type: zram size: 15.14 GiB used: 277.5 MiB (1.8%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 15.03 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
Sensors: System Temperatures: cpu: 49.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
Info: Processes: 369 Uptime: 7h 56m wakeups: 0 Memory: 15.14 GiB used: 7.92 GiB (52.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1338 pacman: 1330
lib: 354 flatpak: 8 Shell: fish v: 3.3.1 running-in: gnome-terminal inxi: 3.3.05
