output of garuda-inxi:
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=308b5626-2597-4f46-9f16-a4d882bf2bf0 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401QM_GA401QM
Mobo: ASUSTeK model: GA401QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA401QM.410 date: 12/13/2021
ID-1: BAT0 charge: 37.0 Wh (53.9%) condition: 68.7/76.0 Wh (90.4%)
status: charging
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 398 high: 399 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 399 2: 399
3: 399 4: 399 5: 399 6: 399 7: 399 8: 399 9: 399 10: 397 11: 399 12: 399
13: 399 14: 399 15: 399 16: 399 bogomips: 105395
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: amdgpu
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: TL140BDXP01-0 built: 2020 res: 2560x1440 hz: 120
dpi: 210 gamma: 1.2 size: 310x174mm (12.2x6.85") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.1-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
IF-ID-1: br-80eb1c4c8213 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: veth351d7b5 state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 3-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 484.3 GiB (50.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20
temp: 40.9 C scheme: GPT
ID-1: / raw-size: 250 GiB size: 250 GiB (100.00%) used: 200.24 GiB (80.1%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
used: 41.8 MiB (8.2%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 436.52 GiB size: 436.52 GiB (100.00%)
used: 284.02 GiB (65.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 250 GiB size: 250 GiB (100.00%)
used: 200.24 GiB (80.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-5: /var/tmp raw-size: 250 GiB size: 250 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.1 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 2600
Processes: 446 Uptime: 16m wakeups: 2 Memory: 15.1 GiB
used: 5.29 GiB (35.0%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 2255 pacman: 2233 lib: 527 flatpak: 9
snap: 13 Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.16
e[1;34mGaruda (2.6.3-2):e[0m
e[1;34m System install date:e[0m 2022-01-06
e[1;34m Last full system update:e[0m 2022-06-07
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m plymouth-deactivate.service plymouth-quit.service snapper-cleanup.service
My laptop stopped running smoothly this after noon while in the morning I had good performance as usual. As you can probably tell from my specs I should have no problem to run Garuda. What could be a problem is that my laptops battery went out while in sleep mode.
But still when logging in it takes about a minute for kde to load and for ssdm the same thing.
I've tried to update my system and it took to 15min and it was not nearly done yet so I force restarted during the update and used a timeshift snapshot from this morning when every thing was running smoothly.
During the update I noticed that linux thought my CPU usage was 100% but the temperature was staying at 40- 50 c° which can't be because usualy under that kind of loads the temperature is 80-95 C°.
I've disabled all the performance and power tweak settings with a power profile of performance but still no improvements.
I'm currently trying to reinstall linux-zen but its taking ages (I'll let you know when its finished)
And what is also weird is that even grub is not as responsive as usual which makes me belive that its a hardware problem.
Do you have any suggestions what I could try?
UPDATE:
Linux-zen finally finished updating but it didn‘t fix the problem.
UPDATE 2:
I‘ve just booted into windows and there the performance seems to be as usual. Which means it can’t be a hardware issue.
