╭─cr0w@cr0w in ~
╰─λ garuda-inxi
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=1a7b1b9c-65b1-4325-a966-5d7c7228631c rw rootflags=subvol=@
resume=UUID=a5a047b9-ca89-413f-b513-57d047847ef0 loglevel=3
Type: Desktop Mobo: ASRock model: A320M Pro4-F serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P2.20 date: 07/27/2020
Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2
L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3743 high: 3884 min/max: 2200/3906 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3762 2: 3746
3: 3590 4: 3731 5: 3884 6: 3724 7: 3678 8: 3831 bogomips: 57490
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
vendor: Tul / PowerColor driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 06:00.0 chip-ID: 1002:67df
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung SMB2330HD built: 2010
res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42")
diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 470 Graphics (polaris10 LLVM 13.0.1 DRM
3.44 5.17.9-zen1-1-zen)
v: 4.6 Mesa 22.1.0 direct render: Yes
vendor: Tul / PowerColor driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.49 TiB used: 191.69 GiB (7.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
type: SSD serial: <filter> rev: 0615 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A750
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000VN004-2E4164
type: HDD rpm: 5900 serial: <filter> rev: SC60 scheme: MBR
ID-1: / raw-size: 206.47 GiB size: 206.47 GiB (100.00%)
used: 100.42 GiB (48.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 206.47 GiB size: 206.47 GiB (100.00%)
ID-3: /var/log raw-size: 206.47 GiB size: 206.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 206.47 GiB size: 206.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 609
Processes: 323 Uptime: 9m wakeups: 0 Memory: 15.55 GiB
used: 2.82 GiB (18.1%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1849 lib: 538 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-05-26
Last full system update: 2022-05-28
Hi! I use the Gaming edition, but my screen feels choppy and laggy. When i record a video, there is no lag on the recorded video. Also when i game it feels laggy and choppy like the kde desktop too, but the fps is stable 60. The gpu is RX 470 4gb. I don't have that problem when I boot live flash drive with Garuda, also it was not like this when it was fresh installed. Maybe it's some config but I don't know where to touch it.
Thanks
