Hello everyone!
Kernel: 6.1.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=dc00aad2-54ef-4d2f-b8a9-6a805cea5f3c rw [email protected]
loglevel=3 ibt=off
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: ASRock model: B550 Phantom Gaming 4/ac serial: <filter>
UEFI: American Megatrends LLC. v: P2.20 date: 02/24/2022
Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP arch: Zen 2
gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3800 min/max: 2200/4672 boost: enabled
base/boost: 3800/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800 20: 3800
21: 3800 22: 3800 23: 3800 24: 3800 bogomips: 182052
Device-1: NVIDIA TU106 [GeForce RTX 2070] vendor: Micro-Star MSI
driver: nvidia v: 525.78.01 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 09:00.0 chip-ID: 10de:1f02 class-ID: 0300
Device-2: AVerMedia USB Device type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 6-2:3 chip-ID: 07ca:0570 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: N/A display-ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: DP-2 pos: primary,left res: 1920x1080 hz: 144 dpi: 93
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.78.01 renderer: NVIDIA GeForce RTX
2070/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1-3:4 chip-ID: 046d:0a66 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech [G533 Wireless Headset Dongle] type: USB
Device-4: AVerMedia USB Device type: USB driver: snd-usb-audio,uvcvideo
Device-5: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 9-4:3 chip-ID: 0d8c:0008
Sound API: ALSA v: k6.1.6-zen1-2-zen running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-9:5 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 2.77 TiB used: 377.06 GiB (13.3%)
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: PCIe SSD size: 1.86 TiB
type: SSD serial: <filter> rev: EDFM00.5 temp: 26.9 C scheme: GPT
used: 206.35 GiB (22.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 768 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.6 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 32%
Processes: 463 Uptime: 3h 47m wakeups: 0 Memory: 31.26 GiB
used: 12.29 GiB (39.3%) Init: systemd v: 252 default: graphical
pkgs: 1512 libs: 493 tools: gnome-software,pamac,paru,yay
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2022-10-07
Last full system update: 2023-01-19 ↻
I'm a new Linux user and everything has been working very well for me except one small issue. I am getting random stutters infrequently that I cannot diagnose.
The stutters last only 1 second, and if I am playing a game the framerate drops and also the audio stutters. This also happens when I am not playing games, just browsing the web or listening to a podcast. 99.9% of the time the system is very responsive and runs better than windows ever did. The stutter happens maybe once every 2-3 hours it seems, they are rather infrequent.
I have tried watching the system monitor to see if memory or CPU usage is spiking but I haven't noticed anything strange so far. I thought maybe it could be an issue with one of the disks but I don't know how to determine that.
Since I am new to Linux I am not sure where to start to even begin to figure out what the cause is. So any advice or even basic tips would be very much appreciated. Thanks for the great OS!
