Hello,
I have been running Garuda for a few months. I’m facing the issue that there is periodic freezing on my system. When I boot up the system, there is no problem, but after running the system for about 5 to 8 hours I can see this problem. Every 5 seconds or so, the system freezes for about half a second. I think the freeze gets longer and longer as the system stays on until it gets to like half a second, but shorter pauses can be seen earlier. This can be observed when I am watching a video on any browser, or even watching the system monitor app, the graph freezes at the same regular interval. But sound faces no freezes.
The output of garuda-inxi is as follows -
Kernel: 6.4.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d68ddd16-da61-4ae2-b6a9-96ddbf2b51c3 rw rootflags=subvol=@
nvidia_drm.modeset=1 ibt=off
Desktop: GNOME v: 44.4 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: Dell product: G5 5500 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 0DV11C v: A02 serial: <filter> UEFI: Dell v: 1.24.0
date: 03/14/2023
ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/68.0 Wh (69.6%)
volts: 15.8 min: 15.2 model: LGC-LGC4.474 DELL JJRRD0C type: Li-poly
serial: <filter> status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1250 high: 2600 min/max: 800/5000 base/boost: 2673/2600
ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
7: 2600 8: 800 9: 800 10: 800 11: 2600 12: 2600 bogomips: 62431
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
active: DP-1 empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell
driver: nvidia v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: DP-3,HDMI-A-3 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Generalplus WEB CAM driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.2:6
chip-ID: 1b3f:1167 class-ID: 0102
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: LG (GoldStar) IPS QHD serial: <filter> built: 2023
res: 2560x1440 dpi: 123 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 2560x1440 min: 640x480
missing.
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_skl,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2.1:4
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: Generalplus WEB CAM driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.4.12-arch1-1 status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.79 status: n/a (root, process) with:
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Dell driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3b:00.0 chip-ID: 10ec:2502
IF: enp59s0 state: down mac: <filter>
Device-3: Lite-On Dell Wireless Device driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:3
chip-ID: 04ca:00bd class-ID: 0301
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
Local Storage: total: 953.87 GiB used: 113.45 GiB (11.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
NVMe WDC 1024GB size: 953.87 GiB block-size: physical: 512 B
fw-rev: 11170012 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 40d 13h cycles: 370
read-units: 49,065,968 [25.1 TB] written-units: 45,870,149 [23.4 TB]
ID-1: / raw-size: 408.79 GiB size: 408.79 GiB (100.00%)
used: 113.45 GiB (27.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p8
maj-min: 259:8
used: 596 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p9
maj-min: 259:9
ID-3: /home raw-size: 408.79 GiB size: 408.79 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 408.79 GiB size: 408.79 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 408.79 GiB size: 408.79 GiB (100.00%)
maj-min: 259:8
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: swap-2 type: zram size: 31.11 GiB used: 9.73 GiB (31.3%)
System Temperatures: cpu: 52.0 C pch: 60.0 C mobo: N/A
Processes: 436 Uptime: 1d 15h 34m wakeups: 89 Memory: total: 32 GiB
available: 31.11 GiB used: 18.96 GiB (60.9%) igpu: 64 MiB Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 11
clang: 16.0.6 Packages: pm: pacman pkgs: 2029 libs: 498
tools: gnome-software,pamac,paru,yay Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.29
System install date: 2023-07-25
Last full system update: 2023-09-10 ↻
Windows dual boot: Yes
