Hello.
Need help. Kinda new to Arch Linux (Garuda). My computer freezes randomly but I did notice that it happens most often when I video conference. Any help would be appreciated.
root=UUID=d411223b-2659-4b4b-b58c-0e4c71ff2df1 rw [email protected]
Type: Desktop Mobo: ASUSTeK model: P8B75-M LE v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 1402
date: 12/09/2013
Info: model: Intel Core i5-3570K bits: 64 type: MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 2311 high: 3795 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1656 2: 1818 3: 3795
4: 1978 bogomips: 27137
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
STIBP: disabled, RSB filling
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.78x10.55") diag: 547mm (21.54") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
vendor: ASUSTeK P8H77-I driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP108 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Realtek 802.11ac NIC type: USB driver: N/A bus-ID: 2-1.6:4
chip-ID: 0bda:c811 class-ID: 0000 serial: <filter>
bus-ID: 1-1.1:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 37.01 GiB (2.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: SSD serial: <filter> rev: 043 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: JMicron Tech
model: Generic DISK00 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 0103 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: JMicron Tech
model: Generic DISK01 size: 465.76 GiB block-size: physical: 512 B
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 37.01 GiB (7.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 48 C
Processes: 246 Uptime: 2h 11m wakeups: 0 Memory: 15.56 GiB
used: 3.78 GiB (24.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1927 lib: 547 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-30
Last full system update: 2022-03-30 ↻
