Freezing often
I consistently get a freeze just under a second when switching focus from one application to another or when moving my mouse after not moving it for a while. It doesn’t seem like video stuttering because the whole system freezes.
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1e0ad18c-0993-40e1-b5e4-31a3b75f8dad rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 2.C0
date: 08/05/2022
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3724 high: 4297 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 4230
3: 3600 4: 3788 5: 3589 6: 4297 7: 3600 8: 3600 9: 3600 10: 4216 11: 3600
12: 3468 13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115203
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 2d:00.0 chip-ID: 1002:73df class-ID: 0300
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Gigabyte M27Q
serial: <filter> built: 2020 res: 2560x1440 dpi: 109 gamma: 1.2
size: 596x335mm (23.46x13.19") diag: 801mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.6-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-2:4 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0aa7
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.96 TiB used: 15.36 GiB (0.5%)
fw-rev: 2B2QEXM7 temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: USB 3.2Gen1
size: 232.97 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 15.36 GiB (0.8%)
used: 15.36 GiB (0.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 51.4 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 48.0 C
Processes: 408 Uptime: 23m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.74 GiB (15.1%) Init: systemd v: 254
pm: pacman pkgs: 1700 libs: 472 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-10
Last full system update: 2023-10-10
With reports I have seen floating around other forums, I would try changing to LTS kernel first to see if that helps.
(also mentioned as one of the possible fixes in the FAQ that filo linked).
Quick solve to this (at least for me) was to disable blur effects .
try maybe it helps .
or just do what our fellow @filo shared .
I have the same exact problem as described here: Hiccups / Freezing on Latest Update? - #5 by v0idMrK
Also as you can see from my post there is some people in the Manjaro community also experiencing this.
Tried to revert to LTS as suggested but am unable to boot after doing so (had to restore snapshot).
For now I am using Wayland instead of Xorg and it doesnt happen with that.
Maybe I will try to disable blur effects as suggested above with Xorg to see if it helps.
So it runs with no issue in Wayland session ?
So use it , it is better ! there is no need to use Xorg .
After updating my BIOS i have noticed the issue less. could have just been the reboot that fixed it. I’ll update later if i keep noticing it.
Reboots solve half of our problems :wink:
Remember to reboot after kernel, KDE, and systemd updates.
Rolling systems just like updates and reboots.
I want to try to switch to wayland to resolve my freezing issues with the latest zen kernel + X11. I can’t switch to wayland from login so i’m guessing i have to add the option somewhere?
pacman -Q | grep wayland
kwayland-integration 5.27.8-2
kwayland5 5.110.0-1
lib32-wayland 1.22.0-1
qt5-wayland 5.15.11+kde+r59-1
qt6-wayland 6.5.3-1
wayland 1.22.0-1
wayland-protocols 1.32-1
wayland-utils 1.2.0-1
xorg-xwayland 23.2.1-1
i figured out how to switch to wayland. it fixes all my issues. I guess the latest zen kernel doesn’t like X11. This topic can be closed now.
Please post the way for all the ignorant, it is a help forum here after all. :slight_smile:
The answer we can mark than as solution.
The solution was to run:
sudo pacman -S plasma-wayland-session
for some reason garuda doesn’t include this package by default with the kde/plasma version
