Freezes after a few minutes of starting
I just recently switched to garuda (yesterday) and the problem started from the moment i started to install it every time I boot/start linux it freezes after a few mins (nothing works once it freezes) The only thing i can do is turn off my device and turn it back on using the power button. When i turn it back on the same thing happens and it freezes again (this keeps happening no matter how many times i turn it off and on). Idk any solutions or what i can do (as i am new to linux). pls i need help bcz i need to use my pc. (dragonized KDE version)
root=UUID=c81fb263-a8b0-4659-8dd3-2226421a73a8 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 80C5 v: 97.45 serial: <superuser required> UEFI: Insyde
v: F.1E date: 12/25/2015
ID-1: BAT1 charge: 26.2 Wh (100.0%) condition: 26.2/41.4 Wh (63.2%)
volts: 16.8 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Pentium N3700 bits: 64 type: MCP arch: Airmont level: v2
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76) stepping: 3
microcode: 0x368
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2400 min/max: 480/2400 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2400 2: 2400 3: 2400 4: 2400 bogomips: 12800
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
Device-2: Cheng Uei Precision Industry (Foxlink) [] driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
chip-ID: 05c8:0382 class-ID: 0e02
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: crocus wayland: drv: crocus x11:
drv: crocus inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 405 (BSW)
device-ID: 8086:22b1 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 405 (BSW) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:22b1 surfaces: xcb,xlib,wayland device: 1 type: cpu
name: llvmpipe (LLVM 16.0.6 128 bits) driver: mesa llvmpipe
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8723be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b723
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Realtek [] driver: btusb v: 0.8 type: USB rev: 2.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-5.3:5 chip-ID: 0bda:b006 class-ID: e001
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 238.47 GiB used: 4.04 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 model: NFORCE 256 256GB - THY16
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
used: 4.04 GiB (1.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 196 Uptime: 4m wakeups: 1 Memory: total: 8 GiB note: est.
available: 7.61 GiB used: 2.01 GiB (26.4%) Init: systemd v: 254
pm: pacman pkgs: 1187 libs: 351 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date:     2023-11-22
Last full system update: 2023-11-22
Does it change anything if you select the x11 session in the login screen instead of Wayland?
i never tried changing it ( i did not even know that it could be changed)
i tried it after your reply but it also froze after a few mins after starting
There is a very extensive guide to troubleshoot freezes.
Give a look at it.
Possibly, I’d start from the BIOS, which seems to be very old.
Maybe the CPU and GPU are a bit weak for the dr460nized edition.
How does it work in the live USB?
You could also try a live USB for a different distro. The same problem would suggest an HW issue.
It would be also useful to fully update the system and try the LTS kernel, but I understand that if the freezes are so immediate an update might be risky.
nvm it started working automatically :slight_smile:
ty for the advice though
