oh, it can be worked around? okay thanks, ill wait a bit then ![]()
I'm adding myself to this thread, just as I'm seeing the same problem. I would attempt to fix it, using the same procedure as others in the thread, but I don't want to lose my snapshots. Also: I dual boot with Windows, so that might make things more complicated.
Waiting on the official recommendation, I suppose
I booted to a newly downloaded iso, chose chroot, and ran this in the window after selecting option 0 for Garuda. All is well now.
Before the update, the boot menu appears immediately. After the update, it takes longer for the boot menu to appear after the EFI boot.
efibootmgr
BootCurrent: 0005
Timeout: 0 seconds
BootOrder: 0005,0004,0003,0000,0006,0001,0007,0002,9999
Boot0000* Fedora HD(1,GPT,bab12327-2a57-41cc-8fb4-ff36cb760c67,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0001* Windows Boot Manager HD(1,GPT,8923a35e-a394-4592-a3df-c969394d26d2,0x800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000000000100000010000000040000007fff0400
Boot0002* Internal Hard Disk PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-25-38-8A-11-B2-54-E5)/HD(1,GPT,8923a35e-a394-4592-a3df-c969394d26d2,0x800,0x82000)0000424f
Boot0003* Manjaro HD(1,GPT,bf22cea0-37fc-b64c-94c6-2be069a832b5,0x1000,0x96000)/File(\EFI\Manjaro\grubx64.efi)
Boot0004* opensuse-secureboot HD(1,GPT,bf22cea0-37fc-b64c-94c6-2be069a832b5,0x1000,0x96000)/File(\EFI\opensuse\shim.efi)
Boot0005* Garuda HD(1,GPT,51304c83-721d-3942-8f87-e4af9efea67d,0x1000,0x96000)/File(\EFI\Garuda\grubx64.efi)
Boot0006* ubuntu HD(1,GPT,68e14981-5c5a-401b-ba20-96f69e4464f2,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
Boot0007* Internal Hard Disk PciRoot(0x0)/Pci(0x2,0x3)/Pci(0x0,0x0)/NVMe(0x1,00-25-38-58-01-AD-B8-91)/HD(1,GPT,51304c83-721d-3942-8f87-e4af9efea67d,0x1000,0x96000)0000424f
Boot9999* USB Drive (UEFI) PciRoot(0x0)/Pci(0x1d,0x0)/USB(16,0)0000424f
Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e46fe81f-7dfd-4f6a-a9fb-9cf9d645f98a
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=e912bbf4-d5e0-42e1-9d5e-5f0b144b76b4 loglevel=3
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 wm: kwin_wayland vt: 2 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: HP model: 8902 v: 89.55 serial: <superuser required> UEFI: AMI v: F.16 date: 05/09/2022
ID-1: BAT0 charge: 69.5 Wh (99.6%) condition: 69.8/69.8 Wh (100.0%) volts: 17.2 min: 15.4
model: HP Primary type: Li-ion serial: <filter> status: not charging cycles: 7
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB desc: d-8x32
KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3657 high: 4379 min/max: 1200/4462 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3505 2: 3483 3: 3471 4: 4354 5: 3724
6: 3200 7: 3491 8: 3200 9: 3496 10: 3462 11: 4379 12: 4147 13: 3494 14: 3200 15: 4281 16: 3633
bogomips: 102209
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Hewlett-Packard driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none off: DP-1 empty: HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:73ff class-ID: 0380
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-2 bus-ID: 09:00.0
chip-ID: 1002:1638 class-ID: 0300
Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 30c9:000e class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_wayland
driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu,amdgpu
display-ID: 0
Monitor-1: eDP-1 res: 2560x1440 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.4-zen1-1-zen) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 3-1.3:5 pcie: chip-ID: 0763:410b gen: 4 class-ID: fe01 speed: 16 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci
,snd_sof_amd_renoir pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
Device-5: M-Audio AIR 192 4 type: USB driver: snd-usb-audio
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
chip-ID: 10ec:8852 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Local Storage: total: 1.84 TiB used: 215.69 GiB (11.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
rev: 2B2QEXM7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: MZVLB1T0HBLR-000H1 size: 953.87 GiB
rev: HPS0NEXF temp: 34.9 C scheme: GPT
ID-1: / raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 215.69 GiB (23.6%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:3
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 596 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 215.69 GiB (23.6%) fs: btrfs
ID-4: /var/log raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 215.69 GiB (23.6%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-5: /var/tmp raw-size: 914.67 GiB size: 914.67 GiB (100.00%) used: 215.69 GiB (23.6%)
ID-1: swap-1 type: zram size: 14.98 GiB used: 1.5 MiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16.55 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:4
System Temperatures: cpu: 62.5 C mobo: N/A
Fan Speeds (RPM): fan-1: 0 fan-2: 0
GPU: device: amdgpu temp: 46.0 C device: amdgpu temp: 48.0 C mem: 46.0 C fan: 0 watts: 4.00
Processes: 390 Uptime: 6m wakeups: 1 Memory: 14.98 GiB used: 5.12 GiB (34.2%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pacman: 2438 lib: 581 Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.6.r0.g2987bba-1):
System install date: 2022-04-07
Last full system update: 2022-08-27
Hi all,
I am facing the same issue after running a system update with Garuda Assistant.
Garuda is installed with luks encryption. After entering the passphrase I end up in BIOS as described by others before.
The live USB is running and I am also able to enter the encrypted device with Dolphin. So I hope just grub is broken and can be repaired.
I wanted to follow the steps to repair/reinstall grub but fail to chroot into the encrypted device ( Reinstalling GRUB ).
╭─garuda@garuda in ~ as 🧙 took 4ms
╰─λ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda iso9660 Joliet Extension GARUDA_DR460NIZED_TALON 2022-08-22-02-22-23-00 0 100% /run/miso/bootmnt
├─sda1 iso9660 Joliet Extension GARUDA_DR460NIZED_TALON 2022-08-22-02-22-23-00
└─sda2 vfat FAT12 MISO_EFI 6437-A3CB
zram0 [SWAP]
nvme0n1
├─nvme0n1p1 vfat FAT32 NO_LABEL 47CA-1164
└─nvme0n1p2 crypto_LUKS 1 c14e039f-4227-4a7a-9787-f204dfb04fb6
└─luks-c14e039f-4227-4a7a-9787-f204dfb04fb6
btrfs 34b75142-6036-487e-8e08-d53a930e76b7e code here
╰─λ sudo mkdir -p /mnt/broken
╭─garuda@garuda in ~ as 🧙 took 9ms
╰─λ sudo mount /dev/nvme0n1p2 /mnt/broken
mount: /mnt/broken: unknown filesystem type 'crypto_LUKS'.
dmesg(1) may have more information after failed mount system call.
System infos (Garuda is the only installed OS)
╭─garuda@garuda in ~ as 🧙 took 11ms
╰─λ efibootmgr
BootCurrent: 0018
Timeout: 0 seconds
BootOrder: 0007,0001,0006,0003,0005,0004,0002,0018,0014,0015,0016,0017,0019,001A,0000
Boot0000* Windows Boot Manager HD(1,GPT,aabb9d86-f471-4ddd-87cb-eccd410b63ed,0x800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d0000003ec80100000010000000040000007fff0400
Boot0001* MX19 HD(1,GPT,abb04286-bb0f-49f8-9333-8e74f44a4c0f,0x800,0x80000)/File(\EFI\MX19\grubx64.efi)
Boot0002* Systemd Boot Manager HD(1,GPT,9e37a86d-5d95-c649-b6f8-87cacf60bdf2,0x1000,0x96000)/File(\EFI\systemd\systemd-bootx64.efi)
Boot0003* Manjaro HD(1,GPT,1871b0dd-9e7a-114f-a4c8-a89eafe4521a,0x1000,0x96000)/File(\EFI\Manjaro\grubx64.efi)
Boot0004* ubuntu HD(1,GPT,14a59d6b-2666-4f89-8e66-e4dc71c3deb3,0x800,0x100000)/File(\EFI\ubuntu\shimx64.efi)
Boot0005* Systemd Boot Manager HD(1,GPT,b7c9e561-8a78-ad47-b5cf-2988cd6c47c1,0x1000,0x96000)/File(\EFI\systemd\systemd-bootx64.efi)
Boot0006* Fedora HD(1,GPT,e70335fc-6771-4971-9058-61c619801d34,0x800,0x12c000)/File(\EFI\fedora\shimx64.efi)
Boot0007* Garuda HD(1,GPT,4eae48ea-3ed4-5c4d-8d49-f8042c13cedf,0x1000,0x96000)/File(\EFI\Garuda\grubx64.efi)
Boot0010 Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0011 Boot Menu FvFile(86488440-41bb-42c7-93ac-450fbf7766bf)
Boot0012 Diagnostic Splash FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0013 UEFI Diagnostics FvFile(f8397897-e203-4a62-b977-9e7e5d94d91b)
Boot0014* NVMe: SAMSUNG MZVLB512HBJQ-000L2 PciRoot(0x0)/Pci(0x2,0x4)/Pci(0x0,0x0)/NVMe(0x1,00-25-38-84-01-B5-E0-D4){99191c00-d932-4e4c-ae9a-a0b6e98eb8a4}
Boot0015* ATA HDD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f600)
Boot0016* ATA HDD1: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f601)
Boot0017* ATAPI CD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
Boot0018* USB HDD: JetFlash Transcend 16GB PciRoot(0x0)/Pci(0x8,0x1)/Pci(0x0,0x4)/USB(4,0){aa21e833-33af-47bc-89bd-419f88c50803}
Boot0019* USB FDD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot001A* USB CD: VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
╭─garuda@garuda in ~ as 🧙 took 496ms
╰─λ garuda-inxi
Kernel: 5.19.2-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
tz=Europe/Berlin misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON
quiet systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Type: Laptop System: LENOVO product: 81YQ v: IdeaPad 5 15ARE05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 15ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709WIN
serial: <superuser required> UEFI: LENOVO v: E7CN26WW date: 06/22/2020
ID-1: BAT0 charge: 63.1 Wh (100.0%) condition: 63.1/70.0 Wh (90.1%)
volts: 17.1 min: 15.0 model: SMP L19M4PF1 type: Li-poly serial: <filter>
status: full cycles: 69
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331
Info: model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1524 high: 3001 min/max: 1400/1800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1800 2: 1400
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1397
12: 1400 13: 1400 14: 1400 15: 3001 16: 1400 bogomips: 57489
protection
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1
code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x08e2 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.47 5.19.2-zen1-2-zen)
v: 4.6 Mesa 22.1.6 direct render: Yes
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Sound Server-1: ALSA v: k5.19.2-zen1-2-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-1:10 chip-ID: 0bda:8153 class-ID: 0000
IF: enp3s0f3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-3:2 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 491.34 GiB used: 0 KiB (0.0%)
model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Transcend
model: JetFlash 16GB size: 14.4 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: swap-1 type: zram size: 15 GiB used: 403 MiB (2.6%) priority: 100
System Temperatures: cpu: 73.1 C mobo: N/A gpu: amdgpu temp: 46.0 C
Processes: 330 Uptime: 3h 13m wakeups: 12 Memory: 15 GiB used: 4.04 GiB
(26.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1178 lib: 302 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
System install date: 2022-08-27
Last full system update: 2022-08-27 ↻
Failed units: snapper-cleanup.servicee or paste code here
Do you have any suggestions how to proceed in this case?
Thanks
To chroot you cannot mount the encrypted /dev/nvme0n1p2, you should open it before.
I'm not at all an expert of encryption but I guess with something like
sudo cryptsetup open /dev/nvme0n1p2 crypto_LUKS
It will unlock the device into /dev/mapper/crypto_LUKS and this can be used to mount before chrooting
sudo mount /dev/mapper/crypto_LUKS /mnt/broken
I had to use sudo mount -o subvol=@ /dev/mapper/crypto_LUKS /mnt/broken in order for this to work. After that, executing sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id="Garuda" followed by a reboot fixed the situation.
The steps provided by @filo worked well for me.
After reinstalling grub the system is up and running again. Performed a system update and another reboot and seems to be fixed now.
Thanks for your quick help!
So confused here. The solution at the top says to restore snapshot but now people are saying it's reinstall grub?
I have managed to boot into a fresh live now.
When I click Restore Snapshot button after live usb boot it simply force closes.
Garuda Boot Repair reinstall grub gives three options to install: MBR, root, ESB
No idea which to choose although computer is newish so guessing ESB? Advice on how to proceed would be great thank you.
edit: chroot also force closes when clicked
edit: I deduced that I have EFI based grub setup so tried the boot repair with ESB option selected. This is the result:
Installing for x86_64-efi platform.
Installation finished. No error reported.
/usr/bin/grub-probe: error: failed to get canonical path of `overlay'.
Looks good? What's the error about?
hope this helps
efibootmgr
BootCurrent: 0002
Timeout: 2 seconds
BootOrder: 0000,0002,0001,0003
Boot0000* Garuda HD(1,GPT,b21c250d-1c0c-ef43-aad2-b0e6f34c6bb8,0x1000,0x82000)/File(\EFI\Garuda\grubx64.efi)
Boot0001* UEFI OS HD(1,GPT,b21c250d-1c0c-ef43-aad2-b0e6f34c6bb8,0x1000,0x82000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
Boot0002* UEFI: hp v165w 3276 PciRoot(0x0)/Pci(0x14,0x0)/USB(10,0)/USB(0,0)/CDROM(1,0x4b3990,0x8000)0000424f
Boot0003* UEFI: hp v165w 3276, Partition 2 PciRoot(0x0)/Pci(0x14,0x0)/USB(10,0)/USB(0,0)/HD(2,MBR,0x0,0x4b3990,0x2000)0000424f
sudo fdisk -l
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Samsung SSD 970 EVO Plus 1TB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 41BE325D-B445-7E4F-8F7E-9BB382704D56
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 536575 532480 260M EFI System
/dev/nvme0n1p2 536576 1953520064 1952983489 931.3G Linux filesystem
Disk /dev/sdb: 30.23 GiB, 32463912960 bytes, 63406080 sectors
Disk model: v165w
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 4929935 4929872 2.4G 0 Empty
/dev/sdb2 4929936 4938127 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 14.5 MiB, 15208448 bytes, 29704 sectors
Disk /dev/loop1: 362.83 MiB, 380452864 bytes, 743072 sectors
Disk /dev/loop2: 1.19 GiB, 1272709120 bytes, 2485760 sectors
Disk /dev/loop3: 691.64 MiB, 725237760 bytes, 1416480 sectors
Disk /dev/zram0: 62.44 GiB, 67041755136 bytes, 16367616 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
misobasedir=garuda misolabel=GARUDA_DR460NIZED_TALON quiet
radeon.modeset=1
Type: Mini-pc System: Intel Client Systems product: NUC11BTMi9
v: M26263-302 serial: <superuser required> Chassis: Intel Corporation
type: 35 v: 2.0 serial: <superuser required>
Mobo: Intel model: NUC11DBBi9 v: M17026-302 serial: <superuser required>
UEFI: Intel v: DBTGL579.0050.2021.0802.1933 date: 08/02/2021
Info: model: 11th Gen Intel Core i9-11900KB bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x40
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 3158 high: 3300 min/max: 800/5000:4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1029 2: 3300 3: 3300
4: 3300 5: 3300 6: 3300 7: 3300 8: 3300 9: 3300 10: 3300 11: 3300
12: 3300 13: 3300 14: 3300 15: 3300 16: 3300 bogomips: 105676
Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: HDMI-A-2
empty: DP-4, DP-5, DP-6, DP-7 bus-ID: 00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate]
vendor: eVga.com. driver: nouveau v: kernel non-free: 515.xx+ status: current
(as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2216
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1440x900 s-dpi: 96 s-size: 381x238mm (15.00x9.37")
s-diag: 449mm (17.69")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: Belinea/Maxdata B1925S1W
serial: <filter> built: 2006 res: 1440x900 hz: 60 dpi: 89 gamma: 1.2
size: 410x256mm (16.14x10.08") diag: 502mm (19.8") ratio: 15:9, 16:10
modes: max: 1440x900 min: 720x400
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
bus-ID: 3-11.3:13 alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 0bda:49f1 class-ID: 0300 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio vendor: eVga.com.
Device-3: Realtek USB Audio type: USB
Device-4: Texas Instruments PCM2904 Audio Codec type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-5:4 chip-ID: 08bb:2904
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 58:00.0 chip-ID: 8086:2725
IF: wlp88s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-LM driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 59:00.0 chip-ID: 8086:15f2
IF: enp89s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-12:11 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 961.75 GiB used: 0 KiB (0.0%)
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 46.9 C scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: HP model: v165w
size: 30.23 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 3276 scheme: MBR
ID-1: swap-1 type: zram size: 62.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 322 Uptime: 32m wakeups: 2 Memory: 62.44 GiB used: 4.83 GiB
(7.7%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
Garuda (2.6.6-1):
You'll have to follow this tutorial from the terminal.
https://forum.garudalinux.org/t/how-to-chroot-garuda-linux/4004
The broken partition for you is /dev/nvme0n1p2, the one to mount on /boot/EFI is /dev/nvme0n1p1.
Thankfully the boot repair to ESB worked a treat and I'm back in. Thanks for replying tho. I love Garuda!
First of all thanks for taking the time to work on some fixes. I saw some updates to the garuda-hooks package so I decided to run a garuda-update and this is what I got
also, all those file descriptor errors don't look good.
also when trying to run grub-install so that I don't get a bootloop i get this
[sudo] password for zany130:
EFI variables are not supported on this system.
grub-install: error: efibootmgr failed to register the boot entry: No such file or directory.
So figured out the EFI variable thing. Apparently grub is no longer booting with UEFI support for some reason switched to booting straight from refind and EFI variables work there. Only thing i am missing in refind is Btrfs snapshots but that wasn't working in grub anyway since the grub update
After booting to live USB, using the gui boot repair tool, I did your solution myself after several attempts at the chroot solution not working. Now i it takes several minutes to even get the grub interface, and after selecting an OS or a snapshot, it hangs at Garuda boot with an error:
Loading Linux linux-zen ...
Loading initial ramdisk ...
error: out of memory.
Press any key to continue..._
Cursor not flashing, no other sound or light to indicate disk activity.
For some reason grub remains in a broken state even after running grub-install and making sure grub is selected in the UEFI bootloader
I wonder if there's any solution for those of us other then a full system reinstall.
I'm going to try to get GitHub - Venom1991/refind-btrfs: Generate rEFInd manual boot stanzas from Btrfs snapshots working first but if not I may need to reinstall my system again
You should downgrade your grub to an older version and install it via grub-install again.
yeah, I tried that while that does restore all the missing boot options like snapshots they all become unbootable with an invalid pointer error. Also tried temporaly unistalling refind to see if it would help and still having issues with grub the best I can get is grub booting but with alot of errors and missing boot options
I'm going to try nuking my nobara install since I don't use it anyway to see if the grub install on that disk is somehow messing with the garuda grub copy
Please follow these exact instructions from inside your Garuda Linux system and post ALL logs. Do not do this in a chroot.
garuda-update --noconfirm
sudo SNAP_PAC_SKIP=y pacman -U https://archive.archlinux.org/repos/2022/04/15/core/os/x86_64/grub-2%3A2.06-5-x86_64.pkg.tar.zst
efibootmgr
And post your logs before you reboot, just in case.
here I still have rEFInd installed (installed it again) but nobara was nuked so i guess the boot options for that is just a left over from that
EDIT: YESSSS it worked!!!!! I did a sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id="Garuda" and a grubup after the downgrade and was greeted with a working grub menu on reboot even better I can boot any of the options without any errors or issues
THX @TNE
