How was your grub install different from the one I told you to do? ![]()
Need some more info here. Need at least your garuda-inxi as well as efibootmgr.
Hey @edu4rdshl I think you owe me a burger??
Hmm, what about you? What did your update messages say? Success or failure?
rechrooted it to execute what you asked
12System:
12Kernel 5.18.16-zen1-1-zen 12arch x86_64 12bits 64 12compiler gcc 12v 12.1.1
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_GNOME_TALON quiet systemd.show_status=1 driver=nonfree nouveau.modeset=0
12Console N/A 12wm gnome-shell 12Distro Garuda Linux 12base Arch Linux
12Machine:
12Type Laptop 12System Razer 12product Book 13 - RZ09-0357 12v 0.04 12serial <filter> 12Chassis 12type 10
12serial N/A
12Mobo Razer 12model MA310 12v 4 12serial N/A 12UEFI Razer 12v 2.00 12date 11/20/2020
12Battery:
12ID-1 BAT0 12charge 26.1 Wh (45.1%) 12condition 57.9/55.2 Wh (104.8%) 12volts 12.4 12min 11.6
12model Razer Blade 12type Unknown 12serial <filter> 12status charging
12CPU:
12Info 12model 11th Gen Intel Core i7-1165G7 12socket U3E1 12bits 64 12type MT MCP 12arch Tiger Lake
12gen core 11 12built 2020 12process Intel 10nm 12family 6 12model-id 0x8C (140) 12stepping 1 12microcode 0xA4
12Topology 12cpus 1x 12cores 4 12tpc 2 12threads 8 12smt enabled 12cache 12L1 320 KiB 12desc d-4x48 KiB; i-4x32
KiB 12L2 5 MiB 12desc 4x1.2 MiB 12L3 12 MiB 12desc 1x12 MiB
12Speed (MHz) 12avg 1291 12high 1302 12min/max 400/4700 12base/boost 2800/4700 12scaling
12driver intel_pstate 12governor powersave 12volts 0.7 V 12ext-clock 100 MHz 12cores 121 1301 122 1301 123 1301
124 1301 125 1277 126 1250 127 1302 128 1301 12bogomips 44851
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type retbleed 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2 12mitigation Enhanced IBRS, IBPB: conditional, RSB filling
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel TigerLake-LP GT2 [Iris Xe Graphics] 12vendor Razer USA 12driver i915 12v kernel
12arch Gen-12.1 12process Intel 10nm 12built 2020-21 12ports 12active eDP-1 12empty DP-1, DP-2, DP-3, DP-4,
DP-5, HDMI-A-1 12bus-ID 00:02.0 12chip-ID 8086:9a49 12class-ID 0300
12Device-2 IMC Networks Integrated Camera 12type USB 12driver uvcvideo 12bus-ID 3-1:2
12chip-ID 13d3:5447 12class-ID fe01 12serial <filter>
12Display 12server X.org 12v 1.21.1.4 12with Xwayland 12v 22.1.3 12compositor gnome-shell 12driver 12X
12loaded modesetting 12alternate fbdev,intel,vesa 12gpu i915 12display-ID :0
12Monitor-1 eDP-1 12model Sharp LQ134N1JW48 12built 2020 12res 1920x1200 12dpi 169 12gamma 1.2
12size 288x180mm (11.34x7.09") 12diag 340mm (13.4") 12ratio 16:10 12modes 1920x1200
12Message Unable to show GL data. Required tool glxinfo missing.
12Audio:
12Device-1 Intel Tiger Lake-LP Smart Sound Audio 12vendor Razer USA 12driver sof-audio-pci-intel-tgl
12bus-ID 00:1f.3 12chip-ID 8086:a0c8 12class-ID 0401
12Sound Server-1 ALSA 12v k5.18.16-zen1-1-zen 12running yes
12Sound Server-2 PulseAudio 12v 16.1 12running no
12Sound Server-3 PipeWire 12v 0.3.56 12running yes
12Network:
12Device-1 Intel Wi-Fi 6 AX201 12driver iwlwifi 12v kernel 12bus-ID 00:14.3 12chip-ID 8086:a0f0
12class-ID 0280
12IF wlo1 12state up 12mac <filter>
12Bluetooth:
12Device-1 Intel AX201 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 3-10:6 12chip-ID 8087:0026
12class-ID e001
12Report bt-adapter 12ID hci0 12rfk-id 0 12state up 12address N/A
12Drives:
12Local Storage 12total 252.8 GiB 12used 17 GiB (6.7%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/nvme0n1 12maj-min 259:0 12model NVMe CA5-8D256 12size 238.47 GiB 12block-size 12physical 512 B
12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD 12serial <filter> 12rev CQ20904 12temp 38.9 C
12ID-2 /dev/sda 12maj-min 8:0 12type USB 12vendor SanDisk 12model Cruzer Blade 12size 14.33 GiB 12block-size
12physical 512 B 12logical 512 B 12type N/A 12serial <filter> 12rev 1.00
12Partition:
12ID-1 / 12raw-size 39.06 GiB 12size 39.06 GiB (100.00%) 12used 17 GiB (43.5%) 12fs btrfs
12block-size 4096 B 12dev /dev/nvme0n1p5 12maj-min 259:5
12Swap:
12Kernel 12swappiness 133 (default 60) 12cache-pressure 100 (default)
12ID-1 swap-1 12type zram 12size 15.39 GiB 12used 0 KiB (0.0%) 12priority 100 12dev /dev/zram0
12Sensors:
12System Temperatures 12cpu 40.0 C 12mobo N/A
12Fan Speeds (RPM) N/A
12Info:
12Processes 267 12Uptime 4m 12wakeups 1 12Memory 15.39 GiB 12used 2.14 GiB (13.9%) 12Init systemd 12v 251
12default graphical 12tool systemctl 12Compilers 12gcc 12.2.0 12Packages 12pacman 1258 12lib 341 12Client Unknown
Client: kthreadd 12inxi 3.3.20
Garuda (2.6.6-1):
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2022-08-25
Relevant software: NetworkManager connman
Running in chroot, ignoring command 'list-units'
BootCurrent: 0003
Timeout: 2 seconds
BootOrder: 0001,0000,0003,0002
Boot0000* Windows Boot Manager HD(2,GPT,f36669ed-e25c-42c5-965c-7c54c6f40ac9,0x203a800,0x32000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d0000002c000100000010000000040000007fff0400
Boot0001* garuda HD(2,GPT,f36669ed-e25c-42c5-965c-7c54c6f40ac9,0x203a800,0x32000)/File(\EFI\GARUDA\GRUBX64.EFI)
Boot0002 Nitrux HD(2,GPT,f36669ed-e25c-42c5-965c-7c54c6f40ac9,0x203a800,0x32000)/File(\EFI\NITRUX\SHIMX64.EFI)
Boot0003* UEFI: SanDisk PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/CDROM(1,0x4871c4,0x8000)0000424f
I'm actually not using nitrux anymore but it still shows up,
when I boot into you just get the grub command line. garuda was working fine, so I don't think that has to do with the problem. the sandisk pciroot is the live usb I am booted into
tried it again and noticed it says
umount: /mnt/broken/@: target is busy.
when typing exit, so I just tired unmounted it manually, but that didn't work, do I just reboot while leaving it mounted?
update:
solved it. after the 6th try, I saw that I never executed grubx update. it all works now
After the update, got some message of "memory error" on reboot and grub was ugly, plain white. Garuda started OK, though.
Rebooted again and everything was normal... ![]()
so how do I get a fully working system now? Like I said I was able to boot into my system but I get a bunch of grub errors and only one boot option (snapshots and everything else is gone)
I launched
sudo pacman -S grub
and after
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id="Garuda"
and after sprezzante del pericolo e sfidando la sorte ( contemptuous of danger and tempting fate) I made a reboot.
and....
I am here. All (I hope) works fine.
Thanks,
LL
Ok so sorta fixed it somehow by restoring a snapshot before this whole mess but then grub would not boot after restoring the snapshot. So I redid the instructions chroot instructions linked above.
But now I have several problems
Grub now takes forever to boot about 2 minutes
It is still showing those errors that it was showing before.
I got all my boot options back (before they're were missing but I can't select anything it will just auto boot my default choice
..... I hate grub
EDIT: new garuda-inxi
Kernel: 5.19.4-269-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq-generic_v3
root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw rootflags=subvol=@
sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
nmi_watchdog=0
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.90 date: 05/18/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 2 microcode: 0xA20120A
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4161 high: 4543 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4500 2: 4517
3: 4028 4: 4517 5: 3924 6: 3605 7: 4525 8: 4503 9: 3610 10: 4543 11: 4063
12: 3601 bogomips: 88899
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 6505x2160 s-dpi: 120 s-size: 1376x457mm (54.17x17.99")
s-diag: 1450mm (57.08")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: LG
(GoldStar) HDR WFHD serial: <filter> built: 2021 res: 2560x1080 dpi: 81
gamma: 1.2 size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes:
max: 2560x1080 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung
serial: <filter> built: 2019 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 1093mm (43") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
3.47 5.19.4-269-tkg-bmq) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.19.4-269-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-8:6 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Local Storage: total: 3.87 TiB used: 3.73 TiB (96.5%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO
250GB size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 38.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
type: HDD rpm: 7200 serial: <filter> rev: CC41 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD10EURX-63UY4Y0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 728.25 GiB
(78.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 16.7 MiB
(5.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 728.25
GiB (78.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 728.25
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 728.25
System Temperatures: cpu: 61.9 C mobo: 36.0 C gpu: amdgpu temp: 55.0 C
mem: 56.0 C
Fan Speeds (RPM): cpu: 2410 fan-1: 0 fan-3: 1319 fan-4: 1503 fan-5: 1230
gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.18 vbat: 3.28 gpu: amdgpu watts: 31.00
Processes: 430 Uptime: 10m wakeups: 2 Memory: 31.27 GiB used: 13.5 GiB
(43.2%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 2441 pacman: 2419 lib: 588
flatpak: 22 Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-05-22
Last full system update: 2022-08-26
Failed units: shadow.service systemd-networkd-wait-online.service
EDIT2: tried reinstalling grub, os-prober and all related stuff (took from the dependices of garuda-grub
and got this
Please run efibootmgr
efibootmgr
BootCurrent: 0000
Timeout: 1 seconds
BootOrder: 0000,000A,0005,000B,0001
Boot0000* rEFInd Boot Manager HD(1,GPT,51359687-0157-a847-beda-4d18b6ee56df,0x1000,0x96000)/File(\EFI\REFIND\REFIND_X64.EFI)
Boot0001 Garuda HD(1,GPT,51359687-0157-a847-beda-4d18b6ee56df,0x1000,0x96000)/File(\EFI\GARUDA\GRUBX64.EFI)
Boot0005 Nobara HD(1,GPT,3aa22cc4-d401-4deb-b152-6744a6f83f63,0x800,0x12c000)/File(\EFI\FEDORA\SHIMX64.EFI)
Boot000A UEFI OS HD(1,GPT,51359687-0157-a847-beda-4d18b6ee56df,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
Boot000B Fedora HD(1,GPT,3aa22cc4-d401-4deb-b152-6744a6f83f63,0x800,0x12c000)/File(\EFI\FEDORA\SHIM.EFI)0000424f
Oh, you're booting grub from rEFInd?
yea I need to because for some reason when I set the ultra-fast boot option in my bios it breaks keyboard support in grub if I boot grub first. refind somehow fixes that
. plus refind looks cooler ![]()
now that you point it out it could be refind mucking up the grub-install and the hooks
OH. That explains why you ended up in this situation in the first place.
The GRUB bootloader could not be updated automatically.
Please reinstall it manually, otherwise the system may face a bootloop that has to be resolved from a setup ISO.
Waiting 10 seconds.
But.. How did you miss this message? It's written in red with sooo many exclamation points.
I'll look into fixing this.
what originally? i did the update before it was even held back in the garuda-update when I was trying to fix latte-dock then i pop in on the telegram to post it was a wayland issue and I see everyone complaing about grub and was like oh oh ![]()
You would have been fine if it weren't for rEFInd.
yeah, prob shouldn't have mixed two bootloaders. i think I'm just going to remove grub as my system is just to slow to boot without the bios option and grub doesn't work with that
No, please keep it. Pffff. Just have a bit of patience, I'm working on some changes.
