Hi all
Pretty much what it says in the subject line. I was playing games the other day, and a breaker popped at my house, killing power to my machine (which isn't a laptop or on a UPS). After getting the power back on, I tried rebooting, only to have it hang after the screen where I can select a snapshot, which version of the kernel, etc. When I let it just select the defaults, it goes through these steps:
Loading Linux linux-zen ...
Loading initial ramdisk ...
And after that, nothing. There are no errors that I can see, nothing further happens on screen--the monitor just goes black, and then after a while goes into low power mode.
I can successfully boot into old snapshots, and things work fine, so I 'm assuming that something got corrupted when I lost power, but I'm not sure what that is or how to fix it, or even how to figure out what it is. Any help would be great. Thanks!
Here's my garuda-inxi:
╰─λ garuda-inxi
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cf95cbc9-d27b-41f5-acc4-f8824ac2d362 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: Z790 UD AC v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F3k
date: 01/05/2023
Info: model: 13th Gen Intel Core i9-13900K bits: 64 type: MST AMCP
microcode: 0x113
Topology: cpus: 1x cores: 24 mt: 8 tpc: 2 st: 16 threads: 32 smt: enabled
cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32 KiB, 16x64 KiB
L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 3776 high: 5500 min/max: 800/5500:5800:4300 scaling:
driver: intel_pstate governor: performance cores: 1: 5469 2: 3000 3: 5500
4: 3000 5: 5500 6: 3000 7: 5500 8: 3000 9: 5500 10: 3000 11: 5500 12: 3000
13: 5500 14: 3000 15: 5500 16: 3000 17: 4315 18: 4294 19: 1405 20: 3000
21: 3000 22: 4290 23: 4283 24: 3000 25: 3000 26: 3000 27: 3000 28: 3000
29: 3000 30: 3000 31: 3000 32: 4304 bogomips: 191692
Device-1: Intel Raptor Lake-S GT1 [UHD Graphics 770] vendor: Gigabyte
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: none empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:a780 class-ID: 0300
Device-2: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-4,HDMI-A-3
empty: DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1:10
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting unloaded: radeon
alternate: fbdev,intel,vesa dri: radeonsi,iris gpu: amdgpu display-ID: :0
Screen-1: 0 s-res: 4920x2160 s-dpi: 96 s-size: 1300x571mm (51.18x22.48")
s-diag: 1420mm (55.9")
Monitor-1: DP-4 mapped: DisplayPort-3 pos: primary,left
model: Acer XB273K GP serial: <filter> built: 2020 res: 3840x2160 dpi: 163
gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: max: 3840x2160 min: 640x480
Monitor-2: HDMI-A-3 mapped: HDMI-A-2 pos: right model: VG245
serial: <filter> built: 2020 res: 1080x1920 hz: 60 dpi: 92 gamma: 1.2
size: 299x531mm (11.77x20.91") diag: 609mm (24") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.3.0-devel (git-8c62b3938a) renderer: AMD
Radeon RX 7900 XT (gfx1100 LLVM 17.0.0 DRM 3.52 6.4.8-zen1-1-zen)
direct-render: Yes
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: SteelSeries ApS Arctis 7
lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 1038:12ad class-ID: 0300
Device-4: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:12
chip-ID: 13d3:3533 class-ID: e001 serial: <filter>
Local Storage: total: 9.08 TiB used: 1.52 TiB (16.7%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620281WD temp: 57.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR460 size: 5.46 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: <filter> fw-rev: 0601 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1500DL003-9VT16L
size: 1.36 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5900 serial: <filter> fw-rev: CC3C scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Intel model: SSDSC2BP480G4
tech: SSD serial: <filter> fw-rev: 0420 scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 53.07 GiB (88.5%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.76 TiB size: 1.76 TiB (100.00%)
used: 1.24 TiB (70.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%)
used: 53.07 GiB (88.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 60 GiB size: 60 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 60.0 C
mem: 77.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 499
Processes: 554 Uptime: 8m wakeups: 0 Memory: total: 32 GiB note: est.
available: 31.11 GiB used: 3.92 GiB (12.6%) Init: systemd v: 254
pm: pacman pkgs: 2005 libs: 560 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-01-15
Last full system update: 2023-07-31
