Garuda crashing on boot to emergency shell after update
Hello all,
I try to make posting here a last resort to solve my Garuda issues but this really has me stumped.
I got home from vacation about 2 weeks ago and updated from the terminal like I always do (I read an official post stating the preferred way to do it now is with the "garuda-update" command in Konsole) and then it crashed on boot and dropped me into an emergency shell. All I could really think to do at the time was to load a snapshot of a working version and hope the problem fixed itself with a newer update. (There was one time I had issues after an update and then a newer update fixed it, that was my approach to this issue.) Unfortunately, it didn't work. I also noticed some strange comments about the kernels during the update that I normally never see, something akin to, "Good news! this version of kernel xyz matches the current one". It says this for several different kernels including the main zen one I use. I would have to crash my system again as a result of the system update to recreate the comment so I could copy/paste it.
The only other thing I could think to do was to reinstall all of the software packages to see if maybe some settings got messed up that would sort themselves out with a reinstall. (it worked in the past for me when I screwed up some settings). But I'm getting a 404 error returned from the servers when I attempt that which is also first.
*** I hate to come here only when I have problems because I love Garuda so much. I guess I'll consider donating after this gets resolved. The last time I had an issue though I made sure to thoroughly document the solution so that maybe it could help others and contribute, in my own small way, to the community. Also, I am a bit of a newb to Linux which is why my attempted solutions are so basic. People might wonder why I'm using Arch Linux as a newb but Garuda makes it so easy with all of the GUI options and BTRFS snapshots make fatal screwups easy to reverse. It's a testament to how good Garuda is that someone like me uses it with such ease without issue 99% of the time. ***
Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f2c1a4aa-0018-4995-993e-0efeea6378fc rw rootflags=subvol=@
quiet
cryptdevice=UUID=b8e4a7b6-9b6a-44fd-ae21-5f821357034c:luks-b8e4a7b6-9b6a-44fd-ae21-5f821357034c
root=/dev/mapper/luks-b8e4a7b6-9b6a-44fd-ae21-5f821357034c quiet splash
resume=/dev/mapper/luks-ed0733ff-1cdd-4c31-b7eb-37b9edb97f2a loglevel=3
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4801
date: 03/02/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201205
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3712 high: 4664 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3617 2: 3605
3: 3752 4: 3846 5: 3623 6: 3605 7: 3592 8: 3591 9: 3585 10: 3584 11: 3590
12: 3593 13: 3589 14: 3583 15: 3711 16: 3908 17: 4099 18: 3727 19: 3733
20: 3722 21: 3592 22: 3591 23: 4664 24: 3593 bogomips: 177276
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 11:00.0
chip-ID: 1002:73bf class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right
model: Sceptre L27 built: 2020 res: 1920x1080 dpi: 81 gamma: 1.2
size: 600x330mm (23.62x12.99") diag: 685mm (27") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Sceptre L27
serial: <filter> built: 2020 res: 1920x1080 dpi: 81 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6900 XT (sienna_cichlid LLVM 13.0.1 DRM
3.44 5.17.9-zen1-1-zen)
v: 4.6 Mesa 22.1.0 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:ab28
bus-ID: 14:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Hifi Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0d8c:0158
Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-1:2 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 9.1 TiB used: 7.58 TiB (83.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41062C20 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Smart Modular Tech.
rev: 41062C20 temp: 49.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN07 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000NE001-2MA101
type: HDD rpm: 7200 serial: <filter> rev: EN01 scheme: GPT
ID-1: / raw-size: 896.75 GiB size: 896.75 GiB (100.00%)
used: 423.07 GiB (47.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-b8e4a7b6-9b6a-44fd-ae21-5f821357034c
used: 720 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 896.75 GiB size: 896.75 GiB (100.00%)
ID-4: /var/log raw-size: 896.75 GiB size: 896.75 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.75 GiB size: 896.75 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.33 GiB used: 768 KiB (0.0%)
ID-2: swap-2 type: partition size: 34.46 GiB used: 0 KiB (0.0%)
mapped: luks-ed0733ff-1cdd-4c31-b7eb-37b9edb97f2a
System Temperatures: cpu: 48.0 C mobo: 34.0 C gpu: amdgpu temp: 55.0 C
mem: 56.0 C
Fan Speeds (RPM): cpu: 2129 case-1: 1057 case-2: 976 case-3: 795
gpu: amdgpu fan: 0
Power: 12v: 10.08 5v: N/A 3.3v: N/A vbat: 3.23 gpu: amdgpu watts: 21.00
Processes: 579 Uptime: 4m wakeups: 0 Memory: 31.33 GiB
used: 5.03 GiB (16.1%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2153 lib: 586 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date:     2022-04-13
Last full system update: 2022-05-26
How?
Please read and edit your post.
Try
We are considering to provide help only against prepayment.
Maybe you could try installing the linux-lts kernel. Or if you already have it, try booting with It.
Do you have your USB drive with Garuda on it? It might be worth trying the Grub Repair tool from the live environment, or if that doesn't work reinstalling grub altogether from chroot.
I went to the text console using ctrl + alt + f2 and activated the web console then tried to refresh the mirror lists using the "sudo reflector -a6 -f5 --save /etc/pacman.d/mirrorlist" command but every single one failed to rate. So I just went to the garuda assistant to tweak the mirror list and turned on the worldwide setting instead of just the United States and refreshed (my line of thinking was to access as many servers as possible to get the packages I need to ensure a proper update). I'm attempting to update again in Garuda OS right now and it looks like I'm getting some of the same strange comments from the updater as last time. So, if I crash my system and have to load a snapshot I can at least post that. I'm going to restart now and if it goes to the emergency shell I'll try the startx command to see if that's an issue before loading a snapshot.
Error! Module version 6.1.34 for vboxdrv.ko.zst
is not newer than what is already found in kernel 5.17.9-zen1-1-zen (6.1.34).
You may override by specifying --force.
Good news! Module version 6.1.34 for vboxnetflt.ko.zst
exactly matches what is already found in kernel 5.17.9-zen1-1-zen.
DKMS will not replace this module.
Good news! Module version 6.1.34 for vboxnetadp.ko.zst
==> dkms install --no-depmod vboxhost/6.1.34_OSE -k 5.17.14-hardened1-1-hardened
==> dkms install --no-depmod vboxhost/6.1.34_OSE -k 5.18.3-zen1-1-zen
==> dkms install --no-depmod vboxhost/6.1.34_OSE -k 5.15.46-1-lts
==> dkms install --no-depmod openrazer-driver/3.3.0 -k 5.15.46-1-lts
==> dkms install --no-depmod openrazer-driver/3.3.0 -k 5.17.14-hardened1-1-hardened
==> depmod 5.18.3-zen1-1-zen
==> depmod 5.17.9-zen1-1-zen
==> depmod 5.15.46-1-lts
==> depmod 5.17.14-hardened1-1-hardened
(16/42) Restarting cronie for libc upgrade...
(17/42) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-hardened.preset: 'default'
-> -k /boot/vmlinuz-linux-hardened -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-hardened.img
==> Starting build: 5.17.14-hardened1-1-hardened
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [encrypt]
==> WARNING: Possibly missing firmware for module: qat_4xxx
-> Running build hook: [openswap]
==> WARNING: swap_device variable is not set
==> WARNING: crypt_swap_name variable is not set
-> Running build hook: [resume]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-hardened.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-hardened.preset: 'fallback'
-> -k /boot/vmlinuz-linux-hardened -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-hardened-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-hardened-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img
==> Starting build: 5.15.46-1-lts
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts.img
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.18.3-zen1-1-zen
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
(18/42) Refreshing PackageKit...
(19/42) GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-zen-fallback.img
Found linux image: /boot/vmlinuz-linux-lts
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-lts-fallback.img
Found linux image: /boot/vmlinuz-linux-hardened
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-hardened.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-hardened-fallback.img
Found Garuda Linux on /dev/mapper/luks-b8e4a7b6-9b6a-44fd-ae21-5f821357034c
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-06-13 17:33:09 | @/.snapshots/149/snapshot          | pre  | pacman -Su                                                               |
Found snapshot: 2022-06-13 15:52:46 | @/.snapshots/148/snapshot          | post | python2 python2-gobject python2-numpy python2-wxpython3 qt5-script       |
Found snapshot: 2022-06-13 15:52:45 | @/.snapshots/147/snapshot          | pre  | pacman -Rns python2-gobject python2-numpy python2-wxpython3 qt5-script   |
Found snapshot: 2022-06-13 12:48:28 | @/.snapshots/146/snapshot          | post | akonadi-calendar akonadi-contacts akonadi-import-wizard akonadi-mime ako |
Found snapshot: 2022-06-13 12:47:00 | @/.snapshots/145/snapshot          | pre  | pacman -Su                                                               |
Found snapshot: 2022-06-13 12:40:26 | restore_backup_@_125214759         | N/A  | N/A        |
Found snapshot: 2022-06-13 12:33:48 | @/.snapshots/144/snapshot          | post | akonadi-calendar akonadi-contacts akonadi-import-wizard akonadi-mime ako |
Found snapshot: 2022-06-13 12:32:14 | @/.snapshots/143/snapshot          | pre  | pacman -Su                                                               |
Found snapshot: 2022-06-10 13:04:28 | @/.snapshots/142/snapshot          | post | bpytop        |
Found snapshot: 2022-06-10 13:04:28 | @/.snapshots/141/snapshot          | pre  | /usr/bin/pacman -S --noconfirm community/bpytop                          |
Found snapshot: 2022-06-07 12:19:03 | restore_backup_@_124026659         | N/A  | N/A        |
Found snapshot: 2022-06-07 12:11:27 | @/.snapshots/140/snapshot          | post | ananicy-rules-git birdfont dxvk-mingw-git edk2-armvirt edk2-ovmf frei0r- |
Found snapshot: 2022-06-07 12:10:42 | @/.snapshots/139/snapshot          | pre  | pacman -Su                                                               |
Found snapshot: 2022-06-07 12:01:49 | restore_backup_@_121903847         | N/A  | N/A        |
Found snapshot: 2022-05-05 01:16:45 | restore_backup_@_120149576         | N/A  | N/A        |
Found snapshot: 2022-05-05 01:07:36 | restore_backup_@_20220505011645185 | N/A  | N/A        |
Found snapshot: 2022-05-05 00:59:46 | restore_backup_@_20220505010736327 | N/A  | N/A        |
Found snapshot: 2022-05-05 00:56:54 | restore_backup_@_005946249         | N/A  | N/A        |
Found snapshot: 2022-05-05 00:54:35 | @_backup_20220505005654133         | N/A  | N/A        |
Found snapshot: 2022-04-13 23:45:30 | @_backup_20220505005435446         | N/A  | N/A        |
Found snapshot: 2022-04-13 23:40:03 | restore_backup_@_20221304234530414 | N/A  | N/A        |
Found 21 snapshot(s)
Unmount /tmp/grub-btrfs.Lm7KMbAR9O .. Success
done
(20/42) Reloading system bus configuration...
(21/42) Warn about old perl modules
WARNING: '/usr/lib/perl5/5.34' contains data from at least 3 packages which will NOT be used by the installed perl interpreter.
-> Run the following command to get a list of affected packages: pacman -Qqo '/usr/lib/perl5/5.34'
(22/42) Copy FireDragon Distribution Settings
(23/42) Copy Firefox Distribution Settings
(24/42) Updating fontconfig cache...
(25/42) Updating 32-bit fontconfig cache...
(26/42) Foreign/AUR package notification
frozen-bubble 2.2.1beta1-17
kipi-plugins 21.12.3-1
libkipi 21.12.3-1
noisetorch 0.11.5-1
openrazer-daemon 3.3.0-1
openrazer-driver-dkms 3.3.0-1
openrazer-meta 3.3.0-1
perl-alien-sdl 1.446-12
perl-sdl 2.548-6
python-openrazer 3.3.0-1
samba-mounter-git 186.29ebad4-1
sdl_pango 0.1.2-9
(27/42) Probing GDK-Pixbuf loader modules...
(28/42) Probing 32-bit GDK-Pixbuf loader modules...
(29/42) Compiling GSettings XML schema files...
(30/42) Fix 'grub' and 'os-prober'
(31/42) Updating icon theme caches...
(32/42) Updating GTK4 module cache...
(33/42) Copy Librewolf Distribution Settings
(34/42) Orphaned package notification...
ffmpeg-compat-57 3.4.11-1
(35/42) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/pamac.conf.pacnew
/etc/retroarch.cfg.pacnew
Please check and merge
(36/42) Updating the info directory file...
(37/42) Copy Thunderbird Distribution Settings
(38/42) Updating the desktop file MIME type cache...
(39/42) Updating the vlc plugin cache...
(40/42) Updating Vim help tags...
(41/42) Performing snapper post snapshots for the following configurations...
==> root: 150
(42/42) Syncing all file systems...
This is probably what I will end up doing if my last post doesn't shed any light on what's going on.
Use
garuda-update
and please edit your posts, all terminal output between three ~~~ on top and last line.
Sorry about that. I should have been more specific. I edited my post to clarify. I went to the text console using ctrl + alt + f2 and then used the command "sudo reflector -a6 -f5 --save /etc/pacman.d/mirrorlist" but every mirror list failed to rate.
Ok but have you tried using the command
garuda-update
instead of sudo reflector?
I just tried the garuda-update command in the text console and it just did the same update I pasted that's been making my system crash. I think I'm just going to reinstall it.
:point_up_2: Did you try this?
To be clear, I was suggesting reinstalling grub–not reinstalling the entire OS.
I'm really not sure why people are suggesting reinstalling grub. This is very clearly an issue with a required systemd service failing to start and therefore kicking you into an emergency shell. I don't know how reinstalling grub is supposed to change anything there :eyes:
Take a look at your failed systemd services after you enter an emergency shell and their logs.
Probably something like
sudo systemctl list-units --failed
if I am not mistaken.
I gave up and reformatted my hard drive and did a fresh install and get this screen after updating
I also tried updating from text only terminal (ctrl+alt+f2) and using sudo pacman -Syyu
I can't check for errors with systemctl from emergency shell because the keyboard input is really wonky and delayed to where it only seems to pick up random keystrokes.
I checked the grub.cfg file in live environment and the uuid matches up with the uuid of my root partition.
I'm pretty bewildered at this point :frowning:
I'm not sure the uuid for grub boot cfg and other cfgs are correct. I saved copies of fstab, grub, grub-btrfs, lsblk output, garuda boot options kernel parameters, and device info from KDE partition manager.
Welp, I just tried the lts kernel and it booted.
That’s why I suggested it above at the beginning.
I’m not 100% sure this is you case but I’d go for the lts till it gets fixed.
https://bugzilla.kernel.org/show_bug.cgi?id=216096
This is why we try to only suggest reinstalling the OS as an absolute last resort. Not only does it potentially cost you data you may want to keep, it does nothing to teach users how to troubleshoot issues to correct matters.
Nuke and pave is the Windows way. The whole point to using a rolling release distro is that you should never have to reinstall. Some people have kept their initial install of Arch working for a dozen or more years. That is what learning about your system can accomplish for you. Don’t give up so easily, the reward is far greater if you wait.
I'm still learning. But I spent so much time trying to fix this it's definitely going to be ingrained in my memory that such a simple solution was lying right under my nose the entire time. I keep most of my important data on totally separate drives which is why I'm so inclined to nuke and pave. But, even nuking and paving wouldn't initially fix this. That was also a very important lesson.
Since I'm running lts will the issues that were preventing me from using the zen kernel eventually be updated and make it usable again? I only ask because, from my basic understanding, zen is optimized for gaming. I haven't even tried to play anything while using lts yet.
I should have gone with the ockhams razor approach and tried lts first instead of beating myself over the head with these other, more complex, approaches. Your link also seems like it will have an answer to my previous question about zen.
I just wanted to check back in and detail how the issue was solved instead of immediately disappearing back into the ether once everything was working again.
As far as I understand, the kernel bug (first of my two links above) is already fixed, and should get into the next rc for 5.19 (5.19rc3) for the mainline tree, so you could test it when the next linux-mainline release (5.19rc3) will be available in the chaotic-aur.
I don’t think it will enter into a next 5.18.x release, but I don’t know how this is handled.
Whenever it will enter in the linux kernel, I think it could get into the linux-zen. But, also here, I’m not sure.
If this will not be the case, if the fix will work on mainline, it could be fair in my opinion to enter a bug report in the linux-zen archrepo to have it included.
