That's a lot of output, I've had to cut out a ton of similar lines in order to be able to post:
╭─garuda@garuda in ~ as 🧙 took 14ms
[🔴] × sudo btrfs check /dev/nvme0n1p2
Opening filesystem to check...
Checking filesystem on /dev/nvme0n1p2
UUID: cf95cbc9-d27b-41f5-acc4-f8824ac2d362
[1/7] checking root items
[2/7] checking extents
parent transid verify failed on 58818560 wanted 194612 found 556598
Ignoring transid failure
Extent back ref already exists for 7064903680 parent 0 root 477 owner 134852 offset 0 num_refs 1
Extent back ref already exists for 7064903680 parent 0 root 515 owner 134852 offset 0 num_refs 1
Extent back ref already exists for 7064903680 parent 0 root 498 owner 134852 offset 0 num_refs 1
Extent back ref already exists for 7064903680 parent 0 root 502 owner 134852 offset 0 num_refs 1
Extent back ref already exists for 7064903680 parent 603389952 root 0 owner 0 offset 0 num_refs 1
Extent back ref already exists for 7065509888 parent 0 root 477 owner 5520350 offset 131072 num_refs 1
Extent back ref already exists for 7065509888 parent 0 root 515 owner 5520350 offset 131072 num_refs 1
Extent back ref already exists for 7065513984 parent 0 root 477 owner 134875 offset 0 num_refs 1
Extent back ref already exists for 7065513984 parent 0 root 515 owner 134875 offset 0 num_refs 1
Extent back ref already exists for 7065513984 parent 0 root 498 owner 134875 offset 0 num_refs 1
Extent back ref already exists for 7065513984 parent 0 root 502 owner 134875 offset 0 num_refs 1
Extent back ref already exists for 7065513984 parent 603389952 root 0 owner 0 offset 0 num_refs 1
Extent back ref already exists for 7066210304 parent 0 root 477 owner 134876 offset 0 num_refs 1
Extent back ref already exists for 7066210304 parent 0 root 515 owner 134876 offset 0 num_refs 1
Extent back ref already exists for 7066210304 parent 0 root 498 owner 134876 offset 0 num_refs 1
Extent back ref already exists for 7066210304 parent 0 root 502 owner 134876 offset 0 num_refs 1
Extent back ref already exists for 7066210304 parent 603389952 root 0 owner 0 offset 0 num_refs 1
Extent back ref already exists for 7067820032 parent 0 root 477 owner 134877 offset 0 num_refs 1
Extent back ref already exists for 7067820032 parent 0 root 515 owner 134877 offset 0 num_refs 1
Extent back ref already exists for 7067820032 parent 0 root 498 owner 134877 offset 0 num_refs 1
Extent back ref already exists for 7067820032 parent 0 root 502 owner 134877 offset 0 num_refs 1
Extent back ref already exists for 7067820032 parent 603389952 root 0 owner 0 offset 0 num_refs 1
Extent back ref already exists for 7069433856 parent 0 root 477 owner 134878 offset 0 num_refs 1
Extent back ref already exists for 7069433856 parent 0 root 515 owner 134878 offset 0 num_refs 1
Extent back ref already exists for 7069433856 parent 0 root 498 owner 134878 offset 0 num_refs 1
Extent back ref already exists for 7069433856 parent 0 root 502 owner 134878 offset 0 num_refs 1
Extent back ref already exists for 7069433856 parent 603389952 root 0 owner 0 offset 0 num_refs 1
parent transid verify failed on 38232752128 wanted 555178 found 556582
extent back ref already exists...
...for 819970048 parent 277463040 root 0
extent back ref already exists for 820051968 parent 0 root 515
extent back ref already exists for 820051968 parent 277463040 root 0
ref mismatch on [58818560 16384] extent item 0, found 1
tree extent[58818560, 16384] root 515 has no backref item in extent tree
backpointer mismatch on [58818560 16384]
ref mismatch on [818020352 16384] extent item 1, found 0
tree extent[818020352, 16384] root 7 has no tree block found
incorrect global backref count on 818020352 found 1 wanted 0
backpointer mismatch on [818020352 16384]
owner ref check failed [818020352 16384]
ref mismatch on [818413568 16384] extent item 1, found 0
tree extent[818413568, 16384] root 477 has no tree block found
incorrect global backref count on 818413568 found 1 wanted 0
backpointer mismatch on [818413568 16384]
owner ref check failed [818413568 16384]
extent item 818429952 has multiple extent items
extent item 818446336 has multiple extent items
ref mismatch on [818462720 16384] extent item 1, found 0
tree extent[818462720, 16384] parent 818364416 has no tree block found
incorrect global backref count on 818462720 found 1 wanted 0
backpointer mismatch on [818462720 16384]
owner ref check failed [818462720 16384]
ref mismatch on [818479104 16384] extent item 1, found 0
tree extent[818479104, 16384] root 477 has no tree block found
incorrect global backref count on 818479104 found 1 wanted 0
backpointer mismatch on [818479104 16384]
owner ref check failed [818479104 16384]
ref mismatch on [818495488 16384] extent item 1, found 0
tree extent[818495488, 16384] root 2 has no tree block found
incorrect global backref count on 818495488 found 1 wanted 0
backpointer mismatch on [818495488 16384]
owner ref check failed [818495488 16384]
ref mismatch on [818511872 16384] extent item 1, found 0
tree extent[818511872, 16384] root 509 has no tree block found
incorrect global backref count on 818511872 found 1 wanted 0
backpointer mismatch on [818511872 16384]
owner ref check failed [818511872 16384]
extent item 818528256 has multiple extent items
extent item 818544640 has multiple extent items
ref mismatch on [818561024 16384] extent item 1, found 0
tree extent[818561024, 16384] parent 833306624 has no tree block found
incorrect global backref count on 818561024 found 1 wanted 0
backpointer mismatch on [818561024 16384]
owner ref check failed [818561024 16384]
extent item 818577408 has multiple extent items
extent item 818593792 has multiple extent items
ref mismatch on [818610176 16384] extent item 1, found 0
tree extent[818610176, 16384] root 509 has no tree block found
incorrect global backref count on 818610176 found 1 wanted 0
backpointer mismatch on [818610176 16384]
owner ref check failed [818610176 16384]
extent item 818626560 has multiple extent items
extent item 818642944 has multiple extent items
backpointer mismatch on [820445184 16384]
owner ref check failed [820445184 16384]
ref mismatch on [820461568 16384] extent item 1, found 0
tree extent[820461568, 16384] root 7 has no tree block found
incorrect global backref count on 820461568 found 1 wanted 0
backpointer mismatch on [820461568 16384]
owner ref check failed [820461568 16384]
ref mismatch on [7063142400 4096] extent item 1, found 0
data extent[7063142400, 4096] bytenr mimsmatch, extent item bytenr 7063142400 file item bytenr 0
data extent[7063142400, 4096] referencer count mismatch (parent 38011109376) wanted 1 have 0
backpointer mismatch on [7063142400 4096]
owner ref check failed [7063142400 4096]
ref mismatch on [7063146496 4096] extent item 1, found 0
data extent[7063146496, 4096] bytenr mimsmatch, extent item bytenr 7063146496 file item bytenr 0
data extent[7063146496, 4096] referencer count mismatch (parent 38011207680) wanted 1 have 0
backpointer mismatch on [7063146496 4096]
owner ref check failed [7063146496 4096]
ref mismatch on [7063150592 4096] extent item 1, found 0
data extent[7063150592, 4096] bytenr mimsmatch, extent item bytenr 7063150592 file item bytenr 0
data extent[7063150592, 4096] referencer count mismatch (parent 38011207680) wanted 1 have 0
backpointer mismatch on [7063150592 4096]
owner ref check failed [7063150592 4096]
owner ref check failed [7064240128 8192]
ref mismatch on [7064248320 4096] extent item 1, found 0
data extent[7064248320, 4096] bytenr mimsmatch, extent item bytenr 7064248320 file item bytenr 0
data extent[7064248320, 4096] referencer count mismatch (parent 38016843776) wanted 1 have 0
backpointer mismatch on [7064248320 4096]
owner ref check failed [7064248320 4096]
ref mismatch on [7064252416 147456] extent item 1, found 0
data extent[7064252416, 147456] bytenr mimsmatch, extent item bytenr 7064252416 file item bytenr 0
data extent[7064252416, 147456] referencer count mismatch (parent 38016843776) wanted 1 have 0
backpointer mismatch on [7064252416 147456]
owner ref check failed [7064252416 147456]
ref mismatch on [7064399872 4096] extent item 1, found 0
data extent[7064399872, 4096] bytenr mimsmatch, extent item bytenr 7064399872 file item bytenr 0
data extent[7064399872, 4096] referencer count mismatch (root 477 owner 5904005 offset 139636736) wanted 1 have 0
backpointer mismatch on [7064399872 4096]
owner ref check failed [7064399872 4096]
ref mismatch on [7064403968 20480] extent item 1, found 0
data extent[7064403968, 20480] bytenr mimsmatch, extent item bytenr 7064403968 file item bytenr 0
data extent[7064403968, 20480] referencer count mismatch (root 477 owner 5806703 offset 0) wanted 1 have 0
backpointer mismatch on [7064403968 20480]
owner ref check failed [7064403968 20480]
ref mismatch on [7064424448 8192] extent item 1, found 0
data extent[7064424448, 8192] bytenr mimsmatch, extent item bytenr 7064424448 file item bytenr 0
data extent[7064424448, 8192] referencer count mismatch (root 477 owner 5806715 offset 0) wanted 1 have 0
backpointer mismatch on [7064424448 8192]
owner ref check failed [7064424448 8192]
ref mismatch on [7064432640 8192] extent item 1, found 0
data extent[7064432640, 8192] bytenr mimsmatch, extent item bytenr 7064432640 file item bytenr 0
data extent[7064432640, 8192] referencer count mismatch (root 477 owner 5806724 offset 0) wanted 1 have 0
backpointer mismatch on [7064432640 8192]
owner ref check failed [7064432640 8192]
ref mismatch on [7064440832 8192] extent item 1, found 0
data extent[7064440832, 8192] bytenr mimsmatch, extent item bytenr 7064440832 file item bytenr 0
data extent[7064440832, 8192] referencer count mismatch (root 477 owner 5806732 offset 0) wanted 1 have 0
backpointer mismatch on [7064440832 8192]
owner ref check failed [7064440832 8192]
ref mismatch on [7064449024 8192] extent item 1, found 0
data extent[7064449024, 8192] bytenr mimsmatch, extent item bytenr 7064449024 file item bytenr 0
data extent[7064449024, 8192] referencer count mismatch (root 477 owner 5806746 offset 0) wanted 1 have 0
backpointer mismatch on [7064449024 8192]
owner ref check failed [7064449024 8192]
ref mismatch on [7064457216 16384] extent item 1, found 0
data extent[7064457216, 16384] bytenr mimsmatch, extent item bytenr 7064457216 file item bytenr 0
data extent[7064457216, 16384] referencer count mismatch (root 477 owner 5806752 offset 0) wanted 1 have 0
backpointer mismatch on [7064457216 16384]
owner ref check failed [7064457216 16384]
ref mismatch on [7064473600 4096] extent item 1, found 0
data extent[7064473600, 4096] bytenr mimsmatch, extent item bytenr 7064473600 file item bytenr 0
data extent[7064473600, 4096] referencer count mismatch (root 477 owner 5806781 offset 0) wanted 1 have 0
backpointer mismatch on [7064473600 4096]
owner ref check failed [7064473600 4096]
ref mismatch on [7064477696 24576] extent item 1, found 0
data extent[7064477696, 24576] bytenr mimsmatch, extent item bytenr 7064477696 file item bytenr 0
data extent[7064477696, 24576] referencer count mismatch (parent 547258368) wanted 1 have 0
backpointer mismatch on [7064477696 24576]
owner ref check failed [7064477696 24576]
ref mismatch on [7064502272 16384] extent item 1, found 0
data extent[7064502272, 16384] bytenr mimsmatch, extent item bytenr 7064502272 file item bytenr 0
data extent[7064502272, 16384] referencer count mismatch (parent 547258368) wanted 1 have 0
backpointer mismatch on [7064502272 16384]
owner ref check failed [7064502272 16384]
ref mismatch on [7064518656 12288] extent item 1, found 0
data extent[7064518656, 12288] bytenr mimsmatch, extent item bytenr 7064518656 file item bytenr 0
data extent[7064518656, 12288] referencer count mismatch (parent 547258368) wanted 1 have 0
backpointer mismatch on [7064518656 12288]
owner ref check failed [7064518656 12288]
ref mismatch on [7064530944 57344] extent item 1, found 0
data extent[7064530944, 57344] bytenr mimsmatch, extent item bytenr 7064530944 file item bytenr 0
data extent[7064530944, 57344] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064530944 57344]
owner ref check failed [7064530944 57344]
ref mismatch on [7064588288 61440] extent item 1, found 0
data extent[7064588288, 61440] bytenr mimsmatch, extent item bytenr 7064588288 file item bytenr 0
data extent[7064588288, 61440] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064588288 61440]
owner ref check failed [7064588288 61440]
ref mismatch on [7064649728 57344] extent item 1, found 0
data extent[7064649728, 57344] bytenr mimsmatch, extent item bytenr 7064649728 file item bytenr 0
data extent[7064649728, 57344] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064649728 57344]
owner ref check failed [7064649728 57344]
ref mismatch on [7064707072 61440] extent item 1, found 0
data extent[7064707072, 61440] bytenr mimsmatch, extent item bytenr 7064707072 file item bytenr 0
data extent[7064707072, 61440] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064707072 61440]
owner ref check failed [7064707072 61440]
ref mismatch on [7064768512 65536] extent item 1, found 0
data extent[7064768512, 65536] bytenr mimsmatch, extent item bytenr 7064768512 file item bytenr 0
data extent[7064768512, 65536] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064768512 65536]
owner ref check failed [7064768512 65536]
ref mismatch on [7064834048 65536] extent item 1, found 0
data extent[7064834048, 65536] bytenr mimsmatch, extent item bytenr 7064834048 file item bytenr 0
data extent[7064834048, 65536] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064834048 65536]
owner ref check failed [7064834048 65536]
ref mismatch on [7064899584 4096] extent item 1, found 0
data extent[7064899584, 4096] bytenr mimsmatch, extent item bytenr 7064899584 file item bytenr 0
data extent[7064899584, 4096] referencer count mismatch (root 506 owner 6071201 offset 0) wanted 1 have 0
backpointer mismatch on [7064899584 4096]
owner ref check failed [7064899584 4096]
extent item 7064903680 has multiple extent items
data extent[7064903680, 20480] bytenr mimsmatch, extent item bytenr 7064903680 file item bytenr 0
data extent[7064903680, 20480] referencer count mismatch (root 506 owner 134852 offset 0) wanted 1 have 0
backpointer mismatch on [7064903680 20480]
ref mismatch on [7064924160 69632] extent item 1, found 0
data extent[7064924160, 69632] bytenr mimsmatch, extent item bytenr 7064924160 file item bytenr 0
data extent[7064924160, 69632] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064924160 69632]
owner ref check failed [7064924160 69632]
ref mismatch on [7064993792 20480] extent item 1, found 0
data extent[7064993792, 20480] bytenr mimsmatch, extent item bytenr 7064993792 file item bytenr 0
data extent[7064993792, 20480] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7064993792 20480]
owner ref check failed [7064993792 20480]
ref mismatch on [7065014272 16384] extent item 1, found 0
data extent[7065014272, 16384] bytenr mimsmatch, extent item bytenr 7065014272 file item bytenr 0
data extent[7065014272, 16384] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065014272 16384]
owner ref check failed [7065014272 16384]
ref mismatch on [7065030656 16384] extent item 1, found 0
data extent[7065030656, 16384] bytenr mimsmatch, extent item bytenr 7065030656 file item bytenr 0
data extent[7065030656, 16384] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065030656 16384]
owner ref check failed [7065030656 16384]
ref mismatch on [7065047040 12288] extent item 1, found 0
data extent[7065047040, 12288] bytenr mimsmatch, extent item bytenr 7065047040 file item bytenr 0
data extent[7065047040, 12288] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065047040 12288]
owner ref check failed [7065047040 12288]
ref mismatch on [7065059328 16384] extent item 1, found 0
data extent[7065059328, 16384] bytenr mimsmatch, extent item bytenr 7065059328 file item bytenr 0
data extent[7065059328, 16384] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065059328 16384]
owner ref check failed [7065059328 16384]
ref mismatch on [7065075712 73728] extent item 1, found 0
data extent[7065075712, 73728] bytenr mimsmatch, extent item bytenr 7065075712 file item bytenr 0
data extent[7065075712, 73728] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065075712 73728]
owner ref check failed [7065075712 73728]
ref mismatch on [7065149440 69632] extent item 1, found 0
data extent[7065149440, 69632] bytenr mimsmatch, extent item bytenr 7065149440 file item bytenr 0
data extent[7065149440, 69632] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065149440 69632]
owner ref check failed [7065149440 69632]
ref mismatch on [7065219072 61440] extent item 1, found 0
data extent[7065219072, 61440] bytenr mimsmatch, extent item bytenr 7065219072 file item bytenr 0
data extent[7065219072, 61440] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065219072 61440]
owner ref check failed [7065219072 61440]
ref mismatch on [7065280512 49152] extent item 1, found 0
data extent[7065280512, 49152] bytenr mimsmatch, extent item bytenr 7065280512 file item bytenr 0
data extent[7065280512, 49152] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065280512 49152]
owner ref check failed [7065280512 49152]
ref mismatch on [7065329664 57344] extent item 1, found 0
data extent[7065329664, 57344] bytenr mimsmatch, extent item bytenr 7065329664 file item bytenr 0
data extent[7065329664, 57344] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065329664 57344]
owner ref check failed [7065329664 57344]
ref mismatch on [7065387008 61440] extent item 1, found 0
data extent[7065387008, 61440] bytenr mimsmatch, extent item bytenr 7065387008 file item bytenr 0
data extent[7065387008, 61440] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7065387008 61440]
owner ref check failed [7065387008 61440]
ref mismatch on [7065448448 24576] extent item 1, found 0
data extent[7065448448, 24576] bytenr mimsmatch, extent item bytenr 7065448448 file item bytenr 0
data extent[7065448448, 24576] referencer count mismatch (root 506 owner 6071135 offset 0) wanted 1 have 0
backpointer mismatch on [7065448448 24576]
owner ref check failed [7065448448 24576]
ref mismatch on [7065473024 20480] extent item 1, found 0
data extent[7065473024, 20480] bytenr mimsmatch, extent item bytenr 7065473024 file item bytenr 0
data extent[7065473024, 20480] referencer count mismatch (root 506 owner 6071147 offset 0) wanted 1 have 0
backpointer mismatch on [7065473024 20480]
owner ref check failed [7065473024 20480]
ref mismatch on [7065493504 8192] extent item 1, found 0
data extent[7065493504, 8192] bytenr mimsmatch, extent item bytenr 7065493504 file item bytenr 0
data extent[7065493504, 8192] referencer count mismatch (root 506 owner 6071164 offset 0) wanted 1 have 0
backpointer mismatch on [7065493504 8192]
owner ref check failed [7065493504 8192]
ref mismatch on [7065501696 8192] extent item 1, found 0
data extent[7065501696, 8192] bytenr mimsmatch, extent item bytenr 7065501696 file item bytenr 0
data extent[7065501696, 8192] referencer count mismatch (root 506 owner 6071172 offset 0) wanted 1 have 0
backpointer mismatch on [7065501696 8192]
owner ref check failed [7065501696 8192]
extent item 7065509888 has multiple extent items
extent item 7065513984 has multiple extent items
data extent[7065513984, 696320] bytenr mimsmatch, extent item bytenr 7065513984 file item bytenr 0
data extent[7065513984, 696320] referencer count mismatch (root 506 owner 134875 offset 0) wanted 1 have 0
backpointer mismatch on [7065513984 696320]
extent item 7066210304 has multiple extent items
data extent[7066210304, 1609728] bytenr mimsmatch, extent item bytenr 7066210304 file item bytenr 0
data extent[7066210304, 1609728] referencer count mismatch (root 506 owner 134876 offset 0) wanted 1 have 0
backpointer mismatch on [7066210304 1609728]
extent item 7067820032 has multiple extent items
data extent[7067820032, 1613824] bytenr mimsmatch, extent item bytenr 7067820032 file item bytenr 0
data extent[7067820032, 1613824] referencer count mismatch (root 506 owner 134877 offset 0) wanted 1 have 0
backpointer mismatch on [7067820032 1613824]
extent item 7069433856 has multiple extent items
data extent[7069433856, 1654784] bytenr mimsmatch, extent item bytenr 7069433856 file item bytenr 0
data extent[7069433856, 1654784] referencer count mismatch (root 506 owner 134878 offset 0) wanted 1 have 0
backpointer mismatch on [7069433856 1654784]
ref mismatch on [7071088640 57344] extent item 1, found 0
data extent[7071088640, 57344] bytenr mimsmatch, extent item bytenr 7071088640 file item bytenr 0
data extent[7071088640, 57344] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7071088640 57344]
owner ref check failed [7071088640 57344]
ref mismatch on [7071145984 57344] extent item 1, found 0
data extent[7071145984, 57344] bytenr mimsmatch, extent item bytenr 7071145984 file item bytenr 0
data extent[7071145984, 57344] referencer count mismatch (parent 550158336) wanted 1 have 0
backpointer mismatch on [7071145984 57344]
owner ref check failed [7071145984 57344]
owner ref check failed [7072714752 40960]
ref mismatch on [7072755712 16384] extent item 1, found 0
data extent[7072755712, 16384] bytenr mimsmatch, extent item bytenr 7072755712 file item bytenr 0
data extent[7072755712, 16384] referencer count mismatch (parent 544194560) wanted 1 have 0
backpointer mismatch on [7072755712 16384]
owner ref check failed [7072755712 16384]
ref mismatch on [7072772096 8192] extent item 1, found 0
data extent[7072772096, 8192] bytenr mimsmatch, extent item bytenr 7072772096 file item bytenr 0
data extent[7072772096, 8192] referencer count mismatch (root 506 owner 6093813 offset 0) wanted 1 have 0
backpointer mismatch on [7072772096 8192]
owner ref check failed [7072772096 8192]
ref mismatch on [7072780288 16384] extent item 1, found 0
data extent[7072780288, 16384] bytenr mimsmatch, extent item bytenr 7072780288 file item bytenr 0
data extent[7072780288, 16384] referencer count mismatch (root 506 owner 6093989 offset 0) wanted 1 have 0
backpointer mismatch on [7072780288 16384]
owner ref check failed [7072780288 16384]
ref mismatch on [38232752128 16384] extent item 0, found 1
tree extent[38232752128, 16384] root 515 has no backref item in extent tree
backpointer mismatch on [38232752128 16384]
ERROR: errors found in extent allocation tree or chunk allocation
[3/7] checking free space tree
[4/7] checking fs roots
Wrong key of child node/leaf, wanted: (256, 1, 0), have: (818020352, 169, 0)
Wrong generation of child node/leaf, wanted: 556582, have: 555178
ERROR: errors found in fs roots
found 45363429376 bytes used, error(s) found
total csum bytes: 42676440
total tree bytes: 1535442944
total fs tree bytes: 1390886912
total extent tree bytes: 85409792
btree space waste bytes: 253757960
file data blocks allocated: 55594999808
referenced 80138268672
Is it worth trying to scrub again without being mounted?
EDIT: here's a pastebin of the whole thing: ╭─garuda@garuda in ~ as 🧙 took 14ms[🔴] × sudo btrfs check /dev/nvme0n1p2Ope - Pastebin.com
