I'm very new to linux so this may be a very obvious fix. I've been using Garuda for a month now with zero problems, it's the only OS installed on my PC. Today I try to boot up and get this error message before I can even get the OS running.
"Loading Linux linux-zen ...
452: out of range pointer: 0x87be7020
Aborted. Press any key to exit._"
I tried restarting and using one of the snapshots but it just brings me back to the same error.
Thanks for your help,
I just tried that. Tried the most recent one, as well as several others going back more than a week. No matter which one I try, I just get looped back to the same error message.
Snapshot restore worked for me - however you have to go into your bios and select a previous UEFI option for it to bypass the error you're describing, which I have been dealing with all morning on my laptop.
There is an option to select for "UEFI firmware settings" in the boot menu... is that what you mean? If I select that it just takes me into the BIOS I'm not sure what it means to "select a previous UEFI option"
Ok i've got this tutorial pulled up on my laptop, sitting next to my linux computer. I've literally never used a terminal before I'm completely new to linux. I booted into the Garuda live USB, opened up a terminal and typed in lsblk -f, it printed out a bunch of stuff looks like it's listing the drives I have on my computer? In the tutorial it says to look for something starting with "/dev/" but I'm not seeing anything starting with /dev...?
╭─garuda@garuda in ~ as 🧙
╰─λ lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /run/miso/sfs/livefs
loop1
squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2
squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3
squash 4.0 0 100% /run/miso/sfs/rootfs
sda iso966 Jolie GARUDA_DR460NIZEDGAMING_TALON
2022-07-17-09-17-44-00 0 100% /run/miso/bootmnt
├─sda1
│ iso966 Jolie GARUDA_DR460NIZEDGAMING_TALON
│ 2022-07-17-09-17-44-00
└─sda2
vfat FAT12 MISO_EFI 04A6-82CE
sr0 udf 1.02 JOHN_MAYER_ANY_GIVEN_THURSDAY
3e0785535f5f5f4d
zram0
[SWAP]
nvme0n1
├─nvme0n1p1
│ vfat FAT32 NO_LABEL 5D38-F71C
└─nvme0n1p2
btrfs 87a0d3a8-a8fd-4a06-9a5e-45c4ec78aff7
╭─garuda@garuda in ~ as 🧙 took 3ms
╰─λ
Cool, I didn't know you could do that.
So I'm assuming I just type in the stuff you just posted starting with "sudo", and pressing enter after each line? I know this is super basic stuff I just don't want to mess anything up
╰─λ sudo mkdir -p /mnt/broken
╭─garuda@garuda in ~ as 🧙 took 5ms
╰─λ sudo mount /dev/nvme0n1p2 /mnt/broken
╭─garuda@garuda in ~ as 🧙 took 65ms
╰─λ sudo garuda-chroot /mnt/broken/@
sh-5.1# mount /dev/nvme0n1p1 /boot/efi
sh-5.1# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=garuda --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
sh-5.1# update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: amd-ucode.img initramfs-linux-zen-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2022-08-26 21:32:32 | @/.snapshots/64/snapshot | post | dxvk-mingw-git garuda-hooks garuda-libs garuda-setup-assistant garuda-we |
Found snapshot: 2022-08-26 21:31:56 | @/.snapshots/63/snapshot | pre | /usr/lib/packagekitd |
Found snapshot: 2022-08-25 21:27:46 | @/.snapshots/62/snapshot | post | ananicy-rules-git btrfs-assistant cups-filters dxvk-mingw-git ethtool fi |
Found snapshot: 2022-08-25 21:27:41 | @/.snapshots/61/snapshot | pre | /usr/lib/packagekitd |
Found snapshot: 2022-08-24 00:13:35 | @/.snapshots/60/snapshot | post | ananicy-rules-git bolt dxvk-mingw-git geoip-database lib32-mangohud paho |
Found snapshot: 2022-08-24 00:13:34 | @/.snapshots/59/snapshot | pre | /usr/lib/packagekitd |
Found snapshot: 2022-08-22 22:07:10 | @/.snapshots/58/snapshot | post | akonadi-mime ark baloo-widgets binutils bomber bovo btrfs-assistant ca-c |
Found snapshot: 2022-08-22 22:06:41 | @/.snapshots/57/snapshot | pre | /usr/lib/packagekitd |
Found snapshot: 2022-08-18 20:12:41 | @/.snapshots/56/snapshot | post | ananicy-rules-git bind bluetooth-support brave-bin btrfs-progs candy-ico |
Found snapshot: 2022-08-18 20:12:14 | @/.snapshots/55/snapshot | pre | /usr/lib/packagekitd |
Found snapshot: 2022-08-15 22:00:33 | @/.snapshots/54/snapshot | post | attica baloo bluez-qt brave-bin breeze-icons cifs-utils cython dhclient |
Found snapshot: 2022-08-15 22:00:28 | @/.snapshots/53/snapshot | pre | /usr/lib/packagekitd |
Found 12 snapshot(s)
Unmount /tmp/grub-btrfs.5UgQur7p7c .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
sh-5.1#
ok I typed in all that stuff and this is where it took me, does this mean I can boot up normally now?
Nice! I'm back to my normal desktop now.
Is there something I should do different to prevent that happening again? Was it just some problem with updates?
Ok so I just restarted my computer again and back to the same error message...
do I have to go through this entire process every time I start my computer now? Until this bug is fixed? That can't be right
