Strange bricked boot/grub issue consitently happening almost all reboots
Hi there, I have a very bizarre issue that has been consistent for quite some time now. At first, it would boot into a post screen saying
“Loading Linux linux-zen …
452: out of range pointer: 0x87be7020
Aborted. Press any key to exit._”
and I was able to fix it thanks to this lovely forum post htps://forum.garudalinux.org/t/error-on-booting-452-out-of-range/22109/
However, recently it started occurring more often, especially after long periods of PC usage. If I use my PC for many hours and then turn it off, the likelihood of the issue appearing is quite high.
This no longer gives me any post errors or messages, it simply freezes on my bios logo screen being completely unresponsive. I can’t enter bios and can’t input anything. What I have to do is turn off the PC, unplug both of my system drives, plug in a live ventoy bootdrive with garuda on it, turn it on and then it off once on the ventoy screen. Once that is done, I plug in my drives and this somehow refreshes my uefi and gets me into the next screen. After, I can get past the bios/into the bios but I then get a new message error at post.
Booting -garuda linux
Loading linux linux-zen …
error: symbol -grub_is_shim_lock_enabled" not found
loading initial ramdisk…
error: symbol -grub_is_shim_lock_enabled" not found.
press any key to continue
failed to boot both default and failback entries
press any key to continue.
No snapshots work at this point
I update my PC quite regularly but I have slowed down because after every update it would cause the issue to appear again and I would have to manually update grub every time.
I have read the wiki and searched this issue online numerous times but I can never seem to find a long term solution, it always tells me to chroot and update grub. Which I always do but it is only a temporary fix until the next boot. What is strange is that this issue happens unprovoked. I can go a few days without upgrades/installing any updates and it would still happen making me believe this is not linked to garuda-update.
I tried many forum posts on here too. Like this one Error on booting "452 out of range" - #11 by advancedcaveman and this one Can't boot after update: symbol 'grub_is_shim_lock_enabled' not found But they don’t seem to cover a long term solution.
Including the steps above, this is what I have to do in a live garuda session every time
sudo mkdir -p /mnt/broken
sudo mount /dev/sdb2 /mnt/broken
sudo garuda-chroot /mnt/broken/@
mount /dev/sdb1 /boot/efi
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=garuda --recheck
update-grub
I am quite at a loss here. Any ideas? Thanks a lot.
Edit: As I rebooted to get a fresh inxi, it happened again and I had to liveboot. Any help will be greatly appreciated.
Kernel: 6.7.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=bec9422a-d102-4b77-900d-522e97b1d1f8 rw rootflags=subvol=@
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: Z97-P v: Rev X.0x serial: <superuser required>
part-nu: All uuid: <superuser required> UEFI: American Megatrends v: 2907
date: 03/11/2016
Info: model: Intel Core i5-4690K bits: 64 type: MCP arch: Haswell
desc: 1x6 MiB
Speed (MHz): avg: 3718 high: 3735 min/max: 800/3900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3734 2: 3707 3: 3698
4: 3735 bogomips: 27984
vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
ports: active: HDMI-A-1 empty: DP-1, DP-2, DVI-D-1, HDMI-A-2
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 34.0 C
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Sony TV serial: <filter>
built: 2010 res: 1920x1080 hz: 60 dpi: 30 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 16.0.6 DRM 3.57 6.7.6-zen1-2-zen) device-ID: 1002:67df
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.276 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 24.0.2-arch1.1
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.1 (LLVM
Device-1: Intel 9 Series Family HD Audio vendor: ASUSTeK 9
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.7.6-zen1-2-zen status: kernel-api with: aoss
vendor: ASUSTeK AM1I-A driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
IF-ID-2: ztyouusv64 state: unknown speed: 10000 Mbps duplex: full
mac: <filter>
Local Storage: total: 2.29 TiB used: 415.67 GiB (17.7%)
model: WD2003FZEX-00Z4SA0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1E.8
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 3.0
size: 14.41 GiB block-size: physical: 512 B logical: 512 B type: USB
scheme: MBR
used: 415.67 GiB (89.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 596 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.56 GiB used: 13.2 MiB (0.1%)
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1761
Memory: total: 16 GiB available: 15.56 GiB used: 2.04 GiB (13.1%)
Processes: 260 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2307 libs: 617 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2022-12-01
Last full system update: 2024-03-01
Failed units:            preload.service wg-quick@wg0.conf.service
Have you tried just running the lts kernel
I have not actually, would that be a good idea? Can give it a go if it does not cause further issues
grub_is_shim_lock_enabled gives some search results, also on Arch BBS.
e.g. GRUB update - symbol "grub_is_shim_lock_enabled" not found / Pacman & Package Upgrade Issues / Arch Linux Forums ← page 2, last two comments
(I actually have no idea though, my potato does not UEFI)
Please do and report back with your finding.
Gonna give this a go, thank you for your suggestion. Will report as soon as I can
I have this one actually bookmarked. Bit overwhelming for me at the moment but will definitely will be giving these suggestions a go if the LTS kernel does not fix it.
Which directories would be safe to remove on garuda as suggested in that post? I do not have the technical knowhow to retrace their steps without a guide. Do not want to accidentally remove something vital.
Thanks for reminding me about this though
I have changed my kernel to LTS and gave it a few test reboots and so far so good. Will report back after longer usage/updates this weekend.
I might want to install & run MEMTEST for 18-24 hrs, see if the RAM is flaky or not.
Is 2016 the latest BIOS available for your rig?
EDIT: Is fastboot/fast boot disabled in your BIOS? And SecureBoot?
Sadly yes 2016 is the latest.
And correct just double checked - both disabled
