got the same issue here
Hyprland ISO
We believe you even without this photo.
Photos of terminals are unnecessary.
Always.
Images can be read worse, are not searchable and copyable for further search.
Got it
Ok, understood. Thanks . ![]()
Edit: the reconstruction of the PKGBUILD suddenly added a new dependency which isn’t required during the build process, leading to this situation. I’ve added the needed pkgbase, which gets flutter going again ![]()
I was wondering if mercury-browser-bin could be added to the Chaotic-AUR. It’s automatically updated with the new releases from Mercury’s GitHub by maintainer xiota.
Iirc we had this in repo a while back and removed it. Will ask xiota about it since they are also a Chaotic-AUR maintainer ![]()
I didn’t know that! If xiota is reading this, thank you for your AUR package! I’ve been using it for a minute and it’s been very helpful! ![]()
I showed them the thread, so yes
there was already an issue with the explanation:
So yeah, sadly not going to add this one again.
That’s totally fine. It doesn’t take that long to build anyways. Thank you for your help.
Hey guys,
Dracula’s theme seems to be broken.
I get this issue when Syu’ing:
:: File /var/cache/pacman/pkg/dracula-gtk-theme-git-r358.18350ca-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (checksum)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package)
I tried many standard methods, such as:
sudo pacman -Syy
sudo pacman-key --refresh-keys
sudo pacman-key --populate archlinux chaotic
sudo pacman -Sc
And also the initial setup process from Chaotic website.
But still, it’s not working.
Should be working again, thanks for reporting ![]()
could you add this?
If you do, check out the comments, as there is a line you need to edit in /etc/makepkg.conf for the time being to get it to actually build
Next time actually put the name of the app in your post and not just link to it.
are you unable to click the link?
Hi!
Could you please add xpipe? ![]()
https://github.com/xpipe-io/xpipe
https://aur.archlinux.org/packages/xpipe
> ERROR: Cannot find the debugedit binary required for including source files in debug packages.
Error: 'xpipe-git-r11.60b0aec-1' could not be created:
Error: Could not create packages: xpipe-git-r11.60b0aec-1
As a side note of this thread
I noticed that librepcb is in Chaotic-AUR, but failed in the logs due to missing packages
https://builds.garudalinux.org/repos/chaotic-aur/logs/librepcb.log
error: target not found: polyclipping
warning: pkgconf-2.1.1-1 is up to date – skipping
error: target not found: fontobene-qt-qt6
A post was split to a new topic: Problem with chaotic-aur :floorp
