I don’t know if this the right place to post this, I think there is a problem with chaotic-aur :floorp
What I experienced:
→ Add Web Panel option in the side bar not working
→ On startup, “http://floorp/” always starts - not that it goes anywhere
N.b: Only happened when I was using the chaotic-aur version, flatpaks is working just fine
Use firedragon ![]()
elaborate
can be changed in the settings
I use firedragon, I love it, infact Its my daily driver
. Just needed to test something out in a browser I could destroy.
When you click on add to panel, a popup comes that gives you the option to add something to the side bar on the left
If it were that easy, I would already have done it. The thing is , it does not do that. You can test it out.
Why do this?
Well, I wanna learn how to mess around with browsers, and of course I don’t want to harm the browser I am currently using. I thought that maybe I could play around with floorp, then I discovered this.
That’s exactly how that’s supposed to work ![]()
Works for me™
. It didn’t for me when I was playing around with it. Will probably try it sometime later and update you.
