I will first post this
╭─fenris@fenris in ~ took 10ms
╰─λ sudo garuda-inxi
[sudo] password for fenris:
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cd6e149b-2970-476f-b742-e3dc1120bedc rw rootflags=subvol=@
quiet rd.luks.uuid=264cadad-c8c3-46fe-b132-32f30ff8b69c
rd.luks.uuid=0dd705d1-74f7-4ae7-8f55-96ae57f524b8
resume=/dev/mapper/luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8 loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x15
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 973 high: 1166 min/max: 700/3400 base/boost: 2871/3400
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 1166 2: 969 3: 707 4: 1052 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: HDMI-A-1 empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46d1
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:8
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer G247HYL serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
chip-ID: 8086:54c8 class-ID: 0403
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.3:7 chip-ID: 0d8c:0102 class-ID: 0300
Device-3: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:5
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0026
Local Storage: total: 3.64 TiB used: 1.99 TiB (54.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 67.8 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000LM048-2E7172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 0202 scheme: MBR
ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
used: 34.91 GiB (3.8%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
maj-min: 254:1 mapped: luks-264cadad-c8c3-46fe-b132-32f30ff8b69c
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
mapped: luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8
ID-2: swap-2 type: zram size: 15.4 GiB used: 4.71 GiB (30.6%)
System Temperatures: cpu: 82.0 C mobo: N/A
Memory: total: 16 GiB available: 15.4 GiB used: 12.23 GiB (79.4%)
igpu: 60 MiB
Processes: 364 Power: uptime: 12m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1798 libs: 473 tools: pamac,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-04-11
Last full system update: 2024-04-27 ↻
Failed units: vmware-workstation-server.service vmware.service
╭─fenris@fenris in ~ as 🧙 took 8s
╰─λ
So here is my scoop, I just installed a program called LibrePCB so I can do all the fancy electronic stuff I do. It took much effort to get it installed but it is, but when I click the menu icon where it installed (Menu/Development/LibrePCB). Nothing happens.
So let me break down what I had to do to get this installed.
- It wanted me to install Debug Edit, don’t know why but it did. I did the following command,
sudo pacman -S debugedit
- Pacman starts downloading the required packages to install LibrePCB and it stalls out because it cannot find the polyclipping packages it needs to install with. So I had to go to Arch Linux User Repository and get that package off of git, from this location Package Details: polyclipping 6.4.2-4. I had done the following steps:
git clone https://aur.archlinux.org/polyclipping.git
cd polyclipping
makepkg -si
- Now that polyclipping is installed, now I can do:
sudo pacman -S librepcb
And that installed with no issues. I then reboot my computer, and try again…nope, it just sits there.
Any ideas?
