When updating the package "plymounth-git 22.02.122.r170" and then rebooting "garuda-dr460nized-linux-zen" does not start in the graphical shell.
Requires user login-password in the terminal.
Not much of a problem - I restored the system and don't update this package now.
But now I can't install additional programs via "Setup Assistant", because it requires it to update the whole system...
garuda-inxi:
Summary
Kernel: 6.2.8-1-cachyos-bore arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cachyos-bore
root=UUID=15ef6e41-c887-4d69-8765-4ce2d76a9566 rw [email protected]
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z590 GAMING X
serial: <superuser required> UEFI: American Megatrends LLC. v: F7
date: 04/14/2022
Info: model: 11th Gen Intel Core i7-11700K bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x57
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3681 high: 4908 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3600
4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 4908 11: 3600 12: 3600
13: 3600 14: 3600 15: 3600 16: 3600 bogomips: 115200
Device-1: AMD Navi 23 [Radeon RX 6650 XT / 6700S 6800S] vendor: Gigabyte
active: HDMI-A-1 off: HDMI-A-2 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:73ef class-ID: 0300
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary model: NEC EA241F
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: HDMI-A-2 mapped: HDMI-A-1 note: disabled
model: LG (GoldStar) TV SSCR2 serial: <filter> built: 2021 res: 1920x1080
dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon RX 6650 XT (navi23
LLVM 15.0.7 DRM 3.49 6.2.8-1-cachyos-bore) direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
API: ALSA v: k6.2.8-1-cachyos-bore status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
Device-2: Broadcom BCM4360 802.11ac Wireless Network Adapter driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 14e4:43a0 class-ID: 0280
IF: wlp9s0 state: dormant mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-12.2:12 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 100.05 TiB used: 7.27 TiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SFYRD2000G
lanes: 4 type: SSD serial: <filter> rev: EIFK31.6 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST18000NM000J-2TV103
size: 16.37 TiB block-size: physical: 4096 B logical: 4096 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN04 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST18000NM000J-2TV103
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST20000NM007D-3DJ103
size: 18.19 TiB block-size: physical: 4096 B logical: 4096 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN03 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST10000VE0008-2PQ103
size: 9.1 TiB block-size: physical: 4096 B logical: 4096 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: EV02 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST20000NM007D-3DJ103
ID-7: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST12000NM0008-2H3101
size: 10.91 TiB block-size: physical: 4096 B logical: 4096 B speed: 6.0 Gb/s
ID-8: /dev/sdg maj-min: 8:96 vendor: HGST (Hitachi) model: HUS722T2TALA604
type: HDD rpm: 7200 serial: <filter> rev: WA09 scheme: GPT
ID-9: /dev/sdh maj-min: 8:112 vendor: HGST (Hitachi)
model: HUS722T2TALA604 size: 1.82 TiB block-size: physical: 512 B
ID-10: /dev/sdi maj-min: 8:128 vendor: Seagate model: ST4000VX007-2DT166
type: HDD rpm: 5980 serial: <filter> rev: CV11 scheme: GPT
ID-11: /dev/sdj maj-min: 8:144 vendor: HGST (Hitachi)
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 11.98 GiB (0.6%)
used: 11.98 GiB (0.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 34.0 C
Processes: 529 Uptime: 25m wakeups: 0 Memory: 125.67 GiB
used: 5.61 GiB (4.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: 1342 pm: pacman pkgs: 1309
libs: 337 tools: octopi,pamac,paru pm: flatpak pkgs: 33 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-04-04
Last full system update: 2023-04-05
Is partially upgraded: Yes
