Hi.
Whenever I try to install Garuda Dragonized Gaming Edition [03.01.2022 ISO] using proprietary (nvidia) driver it gets stuck and does not do anything at "Terminating Playmouth Boot Screen".
What can I do to install it?
I am using a single SSD drive in my system. Partition table is okay cause I used Erase Disk option.
When I use open source driver it works but it does not work while using proprietary driver.
Kernel: 5.16.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=22d356d9-8602-4ffa-af8f-150a79ea6337 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z370 HD3 v: N/A
Mobo: Gigabyte model: Z370 HD3-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F13 date: 08/13/2019
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
desc: 1x9 MiB
Speed (MHz): avg: 3941 high: 3982 min/max: 800/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 3958 2: 3921 3: 3907
4: 3902 5: 3982 6: 3980 bogomips: 33599
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: HDMI-A-3
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1c03 class-ID: 0300
Device-2: Microdia Webcam Vitade AF type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-3:2 chip-ID: 0c45:6366
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa gpu: nouveau
s-diag: 582mm (22.9")
Monitor-1: HDMI-3 mapped: HDMI-A-3 model: HP 22er serial: <filter>
built: 2017 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 476x268mm (18.7x10.6") diag: 583mm (23") ratio: 15:9 or 16/10
OpenGL: renderer: NV136 v: 4.3 Mesa 21.3.7 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
Device-3: Microdia Webcam Vitade AF type: USB
Device-4: Kingston HyperX Cloud Stinger Core Wireless + 7.1 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:3 chip-ID: 0951:170b
Sound Server-1: ALSA v: k5.16.14-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Local Storage: total: 223.57 GiB used: 31 GiB (13.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS240GSSD220S
type: SSD serial: <filter> rev: 71.1 scheme: GPT
used: 31 GiB (13.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 512 KiB (0.0%)
System Temperatures: cpu: 27.8 C mobo: 16.8 C gpu: nouveau temp: 45.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 743
Processes: 266 Uptime: 3m wakeups: 0 Memory: 15.57 GiB
used: 1.75 GiB (11.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1736 lib: 511 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.6-2):
System install date: 2022-03-15
Last full system update: 2022-03-15
and
neofetch
OS: Garuda Linux
Host: Gigabyte Technology Co., Ltd. Z370 HD3-CF
Uptime: 3 mins
Packages: 1736 (pacman)
Shell: bash
DE: Plasma 5.24.3
WM: KWin
WM Theme: Sweet-Dark
Terminal: konsole
CPU: Intel i5-8400 (6) @ 4.0GHz
GPU: NVIDIA GeForce GTX 1060 6GB
Memory: 1.72GiB / 15.57GiB
