Hello.
inxi -Faz:
System: Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_GNOME_SOARING_ quiet systemd.show_status=1 driver=nonfree nouveau.modeset=0
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Alienware product: Alienware m15 R2 v: 1.8.1 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Alienware model: Alienware m15 R2 v: A00 serial: <filter> UEFI: Alienware v: 1.8.1
date: 06/08/2021
Battery: ID-1: BAT1 charge: 54.1 Wh (92.0%) condition: 58.8/76.0 Wh (77.4%) volts: 12.7 min: 11.4
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Charging
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4291 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4291 2: 4300 3: 4229 4: 4329
5: 4334 6: 4050 7: 4089 8: 4005 9: 4331 10: 4153 11: 4196 12: 4249
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Dell driver: i915 v: kernel
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 0000:01:00.0 chip-ID: 10de:1e90 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: modesetting
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3 chip-ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1
Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network: Device-1: Realtek Killer E3000 2.5GbE vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 0000:3c:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp60s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks driver: iwlwifi v: kernel port: 3000
bus-ID: 0000:3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:7
chip-ID: 8087:0029 class-ID: e001
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: intel_nvme_remap v: N/A
port: 5060 bus-ID: 0000:00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
Supported mdraid levels: raid0
Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active size: 953.88 GiB
Info: report: N/A blocks: 1000210432 chunk-size: 64k
Components: Online:
0: nvme0n1 maj-min: 259:1 size: 476.94 GiB
1: nvme1n1 maj-min: 259:0 size: 476.94 GiB
Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 4784 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme1n1 maj-min: 259:0 size: 476.94 GiB state: S
1: nvme0n1 maj-min: 259:1 size: 476.94 GiB state: S
Drives: Local Storage: total: raw: 1011.63 GiB usable: 57.75 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Western Digital model: PC SN730 NVMe WDC 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 11121012 temp: 35.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730 NVMe WDC 512GB
rev: 11121012 temp: 34.9 C
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: HP model: v150w size: 57.75 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.0 C mobo: N/A
Info: Processes: 365 Uptime: 7m wakeups: 2 Memory: 15.42 GiB used: 4.46 GiB (28.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1211 lib: 306
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
Hi everybody, I've recently been trying to install Garuda Linux again. When I install the Dragonized Edition, i can start the boot to the USB with nvidia divers, but at the end it gets stuck on the message:
Starting Terminating Plymouth Boot Screen
However, if I boot from the GNOME version, it boots perfectly and I'm in linux with proprietary drivers, but I want to use the Dragonized edition.
Added nomodeset to the grub boot options
Removed quiet from the grub boot options
Booted with free drivers (it will boot) and then switching to proprietary drivers, but then when I reboot after starting optimus-manager, I will just get a black screen
Started with free drivers and then ran prime-offload and then started optimus-manager, switched to nvidia graphics, rebooted, but still a black screen.
It would be awesome if we could find a solution!
Thanks in advance,
EthtanSnowy
filo
28 August 2021 19:26
2
Maybe you could boot and install with free drivers, update the system after installation and finally switch to proprietary drivers with the Garuda assistant
Just a question, I'm in the Garuda assistant and I can't find where to switch.
Nevermind, I think I found it in the Garuda Settings Manager
I auto installed the drivers and rebooted, it opens and works, but no optimus-manager or Nvidia GPU. I'm doing a system update and I'll try installing the drivers again, but I'm not sure.
Looks like another black screen
Just a suggestion
Check you have fastboot disabled
filo
28 August 2021 21:03
10
Check the suggestions here, especially booting to a tty and then launching startx, to see error messages, logs, etc…
While there are many potential reasons why your installation doesn’t boot to a desktop, the primary reason is that the graphics drivers haven’t loaded correctly so your login/display manager (DM) doesn’t start. This is why you get a “black screen” or stuck at an
[ OK ] Started some service
message.
The normal reason for this is that you have the incorrect driver version for the kernel. This can happens when the mirror you are updating from is not fully synchronised, or times out, and so y…
filo
28 August 2021 22:04
11
It's not exactly your model, but you may want to try the boot parameter suggested here
https://wiki.archlinux.org/title/Alienware_15#Alienware_15_R3
filo
28 August 2021 22:14
13
To test it once, when you are in the grub line for Garuda press button E, then add it at the end of the line starting with linux and press ctrl+x
I can now boot into Garuda Linux, however optimus-manager hasn't started and I'm still on my integrated graphics. If I run optimus-manager I get this error:
ERROR: the latest GPU setup attempt failed at Xorg pre-start hook.
Log at /var/log/optimus-manager/switch/switch-20210828T154003.log
Cannot execute command because of previous errors.
This is from the log file:
[25] INFO: # Xorg pre-start hook
[25] INFO: Previous state was: {'type': 'pending_pre_xorg_start', 'requested_mode': 'hybrid', 'current_mode': None}
[26] INFO: Requested mode is: hybrid
[121] INFO: Available modules: ['nouveau']
[121] INFO: Unloading modules ['nouveau'] (if loaded)
[125] INFO: switching=none, nothing to do
[174] INFO: Nvidia card not visible in PCI bus, rescanning
[174] INFO: Rescanning PCI bus
[218] ERROR: Nvidia card not showing up in PCI bus after rescan. Continuing anyways.
[237] INFO: Loading module nvidia
[237] ERROR: Xorg pre-start setup error
File "/usr/lib/python3.9/site-packages/optimus_manager/hooks/pre_xorg_start.py", line 51, in main
setup_kernel_state(config, prev_state, requested_mode)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 22, in setup_kernel_state
_nvidia_up(config, hybrid=(requested_mode == "hybrid"))
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 95, in _nvidia_up
_load_nvidia_modules(config, available_modules)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 164, in _load_nvidia_modules
_load_module(available_modules, "nvidia", options=nvidia_options)
File "/usr/lib/python3.9/site-packages/optimus_manager/kernel.py", line 241, in _load_module
raise KernelSetupError(
optimus_manager.kernel.KernelSetupError: module nvidia is not available for current kernel. Is the corresponding package installed ?
[238] INFO: Removing /etc/X11/xorg.conf.d/10-optimus-manager.conf (if present)
[238] INFO: Writing state {'type': 'pre_xorg_start_failed', 'switch_id': '20210828T154003', 'requested_mode': 'hybrid'}
Do you know why?
filo
28 August 2021 23:10
15
Sorry, I don't really know...
Maybe give a look at this hint
Didn't work. Thanks for your help anyway.
filo
28 August 2021 23:54
17
EthanSnowy:
My last two dumb hints and I’m crashing into bed
Make sure you are with Nvidia drivers, since I see only nouveau above
Maybe check if the Nvidia card is somehow disabled in the BIOS, since invisible in PCI bus…
Hi, I'm not entirely sure how to do this. Could you give me some guidance? And by the way, I really appreciate your help
filo
29 August 2021 08:10
19
Don't worry, I think the problem is elsewhere or also elsewhere, but this is too technical for me.
When it unloads nouveau, I think this is done to leave only Nvidia loaded, and this should be fixed. But also the Nvidia card not visible in PCI bus should be part of the problem.
I hope someone else who knows better will jump in...
The only suggestion in the meanwhile would be to check the continuation of the GitHub above, with some Xorg configuration hints, and the FAQ, with logs description.
Check also the output of mhwd -li, as I see it could be useful for further future troubleshooting.
Edit: I just realized that the inxi -Fza was still the one from Gnome.
You should provide the one in the Dr460nized installation.
System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-08-28_16-22-33/@/boot/vmlinuz-linux-zen
root=UUID=44050427-6897-438c-abc6-9a8e281d1d52 quiet splash rd.udev.log_priority=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,ssd,subvol=timeshift-btrfs/snapshots/2021-08-28_16-22-33/@
acpi_osi=! "acpi_osi=Windows 2009" nvidia-drm.modeset=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
date: 06/08/2021
Battery: ID-1: BAT1 charge: 46.0 Wh (82.3%) condition: 55.9/76.0 Wh (73.5%) volts: 11.2 min: 11.4
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Discharging
Speed: 4258 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4258 2: 3451 3: 4255 4: 4300
5: 4283 6: 3337 7: 4293 8: 1705 9: 3730 10: 1132 11: 4091 12: 4301
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Dell driver: N/A alternate: nouveau
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Components: Online:
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB
1: nvme1n1 maj-min: 259:1 size: 476.94 GiB
0: nvme0n1 maj-min: 259:0 size: 476.94 GiB state: S
1: nvme1n1 maj-min: 259:1 size: 476.94 GiB state: S
Drives: Local Storage: total: raw: 1.44 TiB usable: 523.51 GiB used: 11.58 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730 NVMe WDC 512GB
rev: 11121012 temp: 36.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital model: PC SN730 NVMe WDC 512GB
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: PSSD T7 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: HP model: v150w size: 57.75 GiB block-size:
Partition: ID-1: / raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 11.58 GiB (2.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 11.58 GiB (2.5%) fs: btrfs
ID-4: /var/log raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 11.58 GiB (2.5%) fs: btrfs
ID-5: /var/tmp raw-size: 465.5 GiB size: 465.5 GiB (100.00%) used: 11.58 GiB (2.5%) fs: btrfs
Sensors: System Temperatures: cpu: 60.0 C mobo: N/A
Info: Processes: 343 Uptime: 1m wakeups: 4 Memory: 15.42 GiB used: 1.66 GiB (10.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1172 lib: 294
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06```
Here is the `inxi -Fza` from a timeshift snapshot, because it refused to boot again.
This is what comes from `mhwd -li`
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.02.19 true PCI
video-nvidia-prime-render-offload 2021.08.05 false PCI
video-optimus -manager 2021.04.19 false PCI
Once again, thanks for your help
