inxi -Fza
System: Kernel: 5.13.8-2-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=d705e742-9d27-4001-909a-c8b33abd69ac rw rootflags=subvol=@ quiet splash
resume=UUID=d2c6afb2-b903-4bf2-9889-2eb2819f64fa loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: X510UA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <filter> UEFI: American Megatrends v: X510UA.312
date: 04/29/2020
Battery: ID-1: BAT0 charge: 10.0 Wh (31.9%) condition: 31.3/42.1 Wh (74.4%) volts: 11.5 min: 11.5
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging cycles: 383
CPU: Info: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check family: 6 model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23199
Speed: 759 MHz min/max: 400/2700 MHz Core speeds (MHz): 1: 759 2: 784 3: 642 4: 800
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.13.8-2-cacule running: yes
Network: Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040 bus-ID: 02:00.0
chip-ID: 8086:24fd class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:3
chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 704.24 GiB used: 56.48 GiB (8.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
ID-2: /dev/sdb maj-min: 8:16 vendor: Micron model: 1100 MTFDDAV256TBN size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: A020
Partition: ID-1: / raw-size: 448.43 GiB size: 448.43 GiB (100.00%) used: 56.48 GiB (12.6%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 563 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.43 GiB size: 448.43 GiB (100.00%) used: 56.48 GiB (12.6%) fs: btrfs
ID-4: /var/log raw-size: 448.43 GiB size: 448.43 GiB (100.00%) used: 56.48 GiB (12.6%)
ID-5: /var/tmp raw-size: 448.43 GiB size: 448.43 GiB (100.00%) used: 56.48 GiB (12.6%)
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 15.53 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2500
Info: Processes: 233 Uptime: 15m wakeups: 1 Memory: 15.53 GiB used: 3.24 GiB (20.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1403 lib: 345
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
â•─adamj@adam in ~/.local/share/applications took 2s
Hey, so first of all I want to say that Garuda has become my favourite Linux Distro. It’s the only one based on Arch where I haven’t had problems, even when Manjaro has in the past. And I love the theming and GUI tools and customisation and basically everything about it. Just wanted to make that clear so that it’s understood I do love the distro and appreciate the work from the developers and testers.
I do have one sllght problem though. Garuda is exceptionally higher in terms of boot time and shutdown time than Manjaro, KDE, Ubuntu, Debian, PopOS and basically any distro I have used in the past. I don’t know why this is as there is a focus on performance so I figured it would be faster not slower. Is it because the distro is sloghtly bloated with a lot of software? Or something to do with Btrfs filesystem maybe? I ask, because similar posts have been made but with no real answer as to why this is the case and how to potentially get boot and shitdown times on a similar level of other distros. Some information would be apprecaiated as to why it is significantly slower and potential ways to decrease these times would be great.
Here a couple of threads reviews to show it is not just a couple of people but a possible majority if not all?
All issues related to Garuda Linux and its assistance
#systemd-analyze blame
1min 19.194s upower.service
11.027s NetworkManager-wait-online.service
2.911s systemd-swap.service
1.939s lvm2-monitor.service
1.77…
Slow Boot & Suspect of Misconfiguration
Soec : Intel Pentium Quad Core 2.7 GHz with 500 HDD ,UEFI (FastBoot-On, Secure Boot-Off)
Having Dual-Boot with Windows 10 & Garuda (Dragonised) .Kept select time for choosing os to 1 sec In GRUB. Black screen with text for 10-15sec .
Loading linux-zen
Booting to Garuda
Then splash screen for 15 sec and then again above black screen for 5 sec and plasma loading screen 10sec . After password entry , widgets loading for 15 sec. Never experienced this …
I have an i5 9600k, 16gb of RAM and a SSD.
It takes a lot of time to boot the install desktop and forever to install.
After reboot, I can switch to my user and then that's it, I can not do anything else.
Is there a way for me to change that?
Blockquote “Garuda Linux also advertises itself as a performance-focused distro, but I didn’t feel any of that. Quite the contrary, to some extent. For example, boot time is very long . I run KDE Neon on the same machine, and it boots noticeably faster . Shutdown time is also longer.” https://averagelinuxuser.com/garuda-linux-distro/
SGS
7 August 2021 19:40
2
I am fine
systemd-analyze
Startup finished in 12.008s (firmware) + 6.711s (loader) + 2.058s (kernel) + 2.044s (userspace) = 22.822s
graphical.target reached after 2.007s in userspace
Post your systemd-analyze blame
â•─sgs@i3 in ~ took 3ms
╰─λ systemd-analyze blame
561ms mnt-sda3.mount
434ms udisks2.service
154ms dev-nvme0n1p2.device
144ms mnt-sda1.mount
123ms mnt-sda2.mount
121ms pamac-cleancache.service
104ms memavaild.service
89ms cups.service
83ms systemd-zram-setup@zram0.service
80ms systemd-journal-flush.service
68ms systemd-remount-fs.service
67ms user@1000.service
61ms systemd-modules-load.service
51ms systemd-udev-trigger.service
34ms accounts-daemon.service
30ms systemd-timesyncd.service
29ms systemd-journald.service
27ms systemd-logind.service
27ms systemd-vconsole-setup.service
27ms upower.service
26ms mnt-nvme1.mount
25ms polkit.service
25ms NetworkManager.service
24ms systemd-udevd.service
19ms systemd-fsck@dev-disk-by\x2duuid-B3B3\x2dD44D.service
19ms lightdm-plymouth.service
19ms boot-efi.mount
19ms dev-zram0.swap
19ms mnt-sdb2.mount
18ms sys-fs-fuse-connections.mount
18ms plymouth-quit-wait.service
17ms lm_sensors.service
14ms systemd-random-seed.service
14ms plymouth-start.service
11ms avahi-daemon.service
11ms systemd-tmpfiles-setup.service
10ms plymouth-read-write.service
9ms systemd-tmpfiles-clean.service
6ms colord.service
6ms udisks2-zram-setup@zram0.service
5ms systemd-tmpfiles-setup-dev.service
5ms modprobe@fuse.service
4ms linux-modules-cleanup.service
4ms systemd-sysctl.service
4ms user-runtime-dir@1000.service
3ms dev-hugepages.mount
3ms dev-mqueue.mount
3ms root.mount
3ms sys-kernel-debug.mount
3ms systemd-fsck@dev-disk-by\x2duuid-35075ddb\x2dbcf7\x2d47aa\x2da43a\x2de759a082>
3ms srv.mount
3ms home.mount
3ms kmod-static-nodes.service
2ms var-cache.mount
2ms modprobe@configfs.service
2ms systemd-update-utmp.service
2ms modprobe@drm.service
2ms var-log.mount
2ms systemd-user-sessions.service
2ms rtkit-daemon.service
2ms tmp.mount
2ms var-tmp.mount
1ms systemd-rfkill.service
863us sys-kernel-config.mount
Startup finished in 3.764s (firmware) + 8.260s (loader) + 1.608s (kernel) + 33.240s (userspace) = 46.873s
graphical.target reached after 33.240s in userspace
30.539s systemd-networkd-wait-online.service
4.039s NetworkManager-wait-online.service
1.852s lvm2-monitor.service
1.718s dev-sda2.device
1.514s linux-modules-cleanup.service
969ms systemd-remount-fs.service
621ms grub-btrfs.service
359ms systemd-logind.service
256ms systemd-modules-load.service
245ms plymouth-start.service
234ms systemd-tmpfiles-clean.service
207ms tlp.service
207ms systemd-udev-trigger.service
194ms polkit.service
156ms ModemManager.service
145ms upower.service
143ms NetworkManager.service
137ms avahi-daemon.service
120ms user@1000.service
114ms memavaild.service
113ms systemd-binfmt.service
112ms bluetooth.service
108ms systemd-user-sessions.service
107ms plymouth-deactivate.service
106ms plymouth-quit-wait.service
104ms plymouth-quit.service
90ms udisks2-zram-setup@zram0.service
85ms plymouth-read-write.service
81ms systemd-fsck@dev-disk-by\x2duuid-C67B\x2d1D79.service
72ms systemd-journal-flush.service
69ms systemd-timesyncd.service
67ms sys-fs-fuse-connections.mount
66ms systemd-tmpfiles-setup.service
66ms sys-kernel-config.mount
66ms smb.service
65ms proc-sys-fs-binfmt_misc.mount
65ms udisks2.service
59ms systemd-networkd.service
59ms systemd-udevd.service
58ms systemd-vconsole-setup.service
57ms systemd-journald.service
48ms systemd-guest-user.service
46ms systemd-guest-config.service
45ms nmb.service
32ms systemd-zram-setup@zram0.service
27ms systemd-backlight@backlight:intel_backlight.service
23ms systemd-rfkill.service
22ms srv.mount
21ms pamac-daemon.service
20ms systemd-sysctl.service
19ms var-cache.mount
18ms dev-binderfs.mount
18ms dev-hugepages.mount
18ms var-log.mount
17ms dev-mqueue.mount
17ms boot-efi.mount
17ms sys-kernel-debug.mount
16ms home.mount
15ms kmod-static-nodes.service
15ms root.mount
14ms modprobe@configfs.service
13ms tmp.mount
13ms colord.service
13ms var-tmp.mount
13ms cups.service
12ms modprobe@drm.service
11ms modprobe@fuse.service
11ms user-runtime-dir@1000.service
11ms systemd-backlight@leds:asus::kbd_backlight.service
9ms systemd-random-seed.service
9ms systemd-update-utmp.service
9ms systemd-tmpfiles-setup-dev.service
8ms dev-disk-by\x2duuid-d2c6afb2\x2db903\x2d4bf2\x2d9889\x2d2eb2819f64fa.swap
7ms dev-zram0.swap
7ms home-guest.mount
5ms rtkit-daemon.service
4ms wpa_supplicant.service
Not sure what you mean in terms of the first part of that comment. And I don’t kow if my Wifi is doing what you are saying or if I can check that or fix it or not.
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @33.240s
└─multi-user.target @33.240s
└─smb.service @33.173s +66ms
└─nmb.service @33.126s +45ms
└─network-online.target @33.123s
└─systemd-networkd-wait-online.service @2.583s +30.539s
└─systemd-networkd.service @2.522s +59ms
└─systemd-udevd.service @2.457s +59ms
└─systemd-tmpfiles-setup-dev.service @2.443s +9ms
└─kmod-static-nodes.service @1.463s +15ms
└─systemd-journald.socket @1.458s
└─system.slice @1.454s
└─-.slice @1.454s
â•─adamj@adam in ~ took 314ms
SGS
7 August 2021 19:58
6
Mask or disable everything you do not use, check what you have in other distros critical-chain.
Honestly I don't have a clue. I'll take a look but I'm confused as hell haha
Naman
7 August 2021 20:26
8
You reach graphical target (DM mostly) in 31 seconds.
networkd-wait-online takes 30.5 of them.
If you disable it, usually nothing goes wrong.
Disable the service and reboot to check.
If something breaks (on your system), re-enable it (in TTY, if you get in trouble).
Arch is for the brave! No risk, no knowledge, no gain.
Ask elsewhere, if you don’t trust.
One thing I always do is maskimg lvm2-* services as I don’t use them (comparable to systemd-networkd-wait-online).
Definetly True
But which contributes more , user intervention needed or lack of systemd maintenance software like in Task Manager ( Service ) . Yes there is terminal way , Service , task isn’t documented , Yet atleast need some clue ryt like User , essential system process like load mount ,non essential system process plymoth , user essential like plasma & user non essential like ufw uf not used
Are you using dual boot? If yes you are going to encounter this issue.
Make sure fast boot and secure boot are turned off.
system
Closed
24 August 2021 03:33
13
