Hello.
during using my laptop system is loosing wifi connection very often. I must turn wifi off and then turn it on to make it work again. That happen ater some of the last updates.
╰─λ garuda-inxi
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=417f187a-a42b-44a5-b6b3-c27517119ed0 rw [email protected]
resume=UUID=8f7c97f0-2758-4001-95b0-57f15fb14228 loglevel=3
Desktop: GNOME v: 42.0 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: HUAWEI product: KLVL-WXX9 v: M1300
Mobo: HUAWEI model: KLVL-WXX9-PCB v: M1300 serial: <superuser required>
UEFI: HUAWEI v: 1.06 date: 09/14/2020
ID-1: BAT0 charge: 35.9 Wh (72.7%) condition: 49.4/54.9 Wh (90.0%)
volts: 8.0 min: 7.6 model: SUNWODA HB4593R1ECW-22S0 type: Li-ion
serial: <filter> status: discharging cycles: 162
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1406 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1397
3: 1398 4: 1397 5: 1396 6: 1397 7: 1406 8: 1397 9: 1396 10: 1395 11: 1397
12: 1392 bogomips: 71865
Device-1: AMD Renoir driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 04:00.0
Device-2: IMC Networks HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 13d3:5451 class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
Screen-1: 0 s-res: 2160x1440 s-dpi: 96 s-size: 571x381mm (22.48x15.00")
s-diag: 686mm (27.03")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0893 built: 2019
res: 2160x1440 hz: 60 dpi: 185 gamma: 1.2 size: 296x197mm (11.65x7.76")
diag: 356mm (14") ratio: 3:2 modes: max: 2160x1440 min: 640x480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
vendor: & Tele RSH driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
bus-ID: 3-3:2 chip-ID: 1358:c123 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 51.83 GiB (10.9%)
model: PC SN530 SDBPNPZ-512G-1027 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21117000 temp: 37.9 C scheme: GPT
used: 51.83 GiB (11.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.2 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 34.0 C
Processes: 323 Uptime: 31m wakeups: 1 Memory: 7.2 GiB
used: 2.96 GiB (41.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1262 pacman: 1257 lib: 327 flatpak: 5 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.15
Garuda (2.6.1-3):
System install date: 2022-04-09
Last full system update: 2022-04-20
Failed units: mnt-Seagate.mount mnt-Toshiba.mount
Regards,
Przemek
