Hello Garuda users.
I have issue with WiFi connection. After suspension Network Manager cannot find any connection.
I tried:
Manjaro(KDE)
artix(KDE)
Pop_OS!,
Garuda(cinnamon)
and I didn't have any problems with WiFi after suspension on those distros.
I also tried Garuda KDE Dragonized(I am using gaming version of it) and I had the same problem there.
Before I changed my problematic WiFi driver, this helped me for a while, but it didn't work consistently and i still had to restart my computer in order to get connection back. Now 2 lines in this script needs to be changed in order for it to work and I am not sure with what.
btw I used this which solved WiFi drops on zen kernel.
Thank you in advance.
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=26c9cf0e-2a45-4920-bdf2-0049acb7afeb rw rootflags=subvol=@
loglevel=3 pci=noaer
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706II_FA706II
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA706II v: 1.0 serial: <filter>
UEFI: American Megatrends v: FA706II.316 date: 03/12/2021
ID-1: BAT1 charge: 38.5 Wh (100.0%) condition: 38.5/48.1 Wh (80.1%)
volts: 12.6 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
Device-1: sony_controller_battery_a4:ae:12:a7:31:ef model: N/A
serial: N/A charge: N/A status: full
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600104
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3000 min/max: 1400/3000 boost: enabled
base/boost: 3000/4000 scaling: driver: acpi-cpufreq governor: performance
volts: 1.2 V ext-clock: 100 MHz cores: 1: 3000 2: 3000 3: 3000 4: 3000
5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
bogomips: 71868
Type: retbleed
mitigation: untrained return thunk; SMT enabled with STIBP protection
STIBP: always-on, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 off: HDMI-A-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: amdgpu
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 note: disabled
model: Samsung C27F390 serial: <filter> built: 2021 res: N/A dpi: 82
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP pos: primary model: AU Optronics 0x479d
built: 2019 res: 1920x1080 hz: 120 dpi: 128 gamma: 1.2
size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.14-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 1-2:2 chip-ID: 054c:09cc pcie: class-ID: 0300 gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: DekTec Digital Video B.V. driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_sof_amd_renoir
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
driver: snd-usb-audio,sony,usbhid
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: kernel modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-1:2 chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Local Storage: total: 1.39 TiB used: 208.58 GiB (14.7%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 185d 19h cycles: 1,249
read-units: 18,326,838 [9.38 TB] written-units: 32,550,231 [16.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
family: Mobile HDD size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 0001 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 185d 1h cycles: 1231
read: 4.03 TiB written: 7.57 TiB Old-Age: g-sense error rate: 486 Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: Flash Disk
size: 14.65 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 8.07 scheme: MBR
used: 154.09 GiB (32.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 30.78 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): cpu: 2400
Processes: 301 Uptime: 9m wakeups: 2 Memory: 30.78 GiB
used: 2.89 GiB (9.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1842
lib: 522 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-24
Last full system update: 2022-07-26
