Hello, I just a bought a new laptop (the one mentioned in the title) and I have two really weird issues.
2 WiFi cards are recognized (wlan0 and wlp3s0) and my connectivity is unstable as a result. After suspsension WiFI works but can't connect to any network and after a while all the networks disappear.
My Firefox logins are resetted every time I shut the PC down.
Otherwise the machine works flawlessly but I would really like to make this my main driver so any help is appreciated, Thank you for this amazing distro! \o/
EDIT: The second issue is resolved. Firefox for some reason had the "Delete browsing history when Firefox closes" option enabled.
I have resolved the two wireless adapters problem. It was just the proprietary drivers. The WiFi still can't find any networks after suspend though. Here is the output:
Host: qushy-A15 Kernel: 5.9.13-98-tkg-bmq x86_64 bits: 64 compiler: gcc
v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=b0d456ef-0c78-4f1e-aaa6-8f7f4b0b3dce rw rootflags=subvol=@
resume=UUID=8a1ad434-2f08-42d3-8832-7491e52881bf loglevel=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: ASUSTeK product: TUF Gaming FA506IV_FA506IV v: 1.0
serial: <superuser/root required>
Mobo: ASUSTeK model: FA506IV v: 1.0 serial: <superuser/root required>
UEFI: American Megatrends v: FA506IV.309 date: 07/02/2020
Model: "Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter"
Driver: "rtw_8822ce"
Device File: wlp3s0
Link detected: yes
Driver Status: rtw88_8822ce is active
Driver Activation Cmd: "modprobe rtw88_8822ce"
Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
Driver: "r8169"
Device File: enp2s0
Link detected: no
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Model: "Lite-On Bluetooth Radio"
Hotplug: USB
Driver: "btusb"
Speed: 12 Mbps
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
System install date 2020-12-10
Generally if your WiFi isn't working after suspension then you can correct this by writing a service. The service unloads your network components prior to suspension, and then reloads them after resuming.
